What fuel stabilizer do you use?
Discussion in 'Technical Chat' started by CUtacomaTIGER, Sep 29, 2012.
  1. Sep 29, 2012 at 10:07 AM
    CUtacomaTIGER
    CUtacomaTIGER [OP] Unprofessional Driver
    San Diego
    '01 4X4 SR5 Chrome Stepside
    Black Wheels Tow Hitch w/4 Pin Weathertech Floor Mats Flowmaster Deck Plate Mod Window Tint Rear Diff Breather Mod Blacked out Badges Window Rain Guards Bed Liner
    I like to keep a 2.5 gallon tank of gas tied up in my bed just in case I run out. I do this b/c my low gas light doesn't work and I like to push the limit on miles per tank.
    That said, I know letting gas just sit in a tank can cause extra water to develop and other negative things, especially with E10 fuel. So what stabilizer would you recommend adding to the extra tank.
    I've heard startron was pretty good.
  2. Sep 29, 2012 at 1:27 PM
    tex
    tex Well-Known Member
    Fort Worth, TX
    2006 V8 Sport 4Runner
    Just refill it every time you fill up.
    First pour the 2.5 gallons into your tank and then put fresh gas in the can.
    I use Stabil made for ethonal in my lawn mower gas. Seems to work good.
  3. Sep 29, 2012 at 1:30 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    Star tron is what i use
    cryptolime likes this.
  4. Sep 30, 2012 at 10:26 AM
    mike92y
    mike92y Well-Known Member
    Michael
    Glendale, AZ
    2018 TRD OFF ROAD
    OME all around. SPC UCA. This and that.
    Nice step side by the way. I don't see a whole lot of them around. I use Stabill in the wife's and my car when we went to Iraq for a year. worked good.
  5. Oct 1, 2012 at 7:18 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I use Seafoam, mostly since that way I have one product that I use as a fuel additive and a fuel stabilizer. Works in the truck, the motorcycle and the generator.
  6. Oct 1, 2012 at 9:06 AM
    CUtacomaTIGER
    San Diego
    i thought of just putting in the 2.5 gallons before i fill up but i'm lazy and sometimes i'm gone for a month or so and the trucks just sits
    thanks i've only seen 1 other stepside in person
    i'll have to check the diff. btwn stabill and startron
    i've been kind of chicken to use seafoam but may eventually try it come thanksgiving time. most review are positive
  7. Oct 1, 2012 at 9:09 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you keep the tank full, there's no space for condensation to develop and get water in the gas.
    I use Startron to help with the E10 issue and it seems to work pretty well.
  8. Oct 1, 2012 at 9:33 AM
    Warhorseforever
    Warhorseforever Will The Thrill
    Will
    Sand Lapper
    2001 Toyota Tacoma Pre-Runner SR5
    Kenwood KDC-348U HU Kicker DS65 Front Doors Only 2 Polk Audio MM840 Kenwood KAC 8105D for subs SuperCrewSound.com behind rear seat sub box
    We put Stabil in the gas of a Yamaha 90hp 2-stroke and ran the motor on a hose for a few minutes before putting it up for winter. It sat for 2 years without running then I pulled it out and ran the hose to the motor it started on the first few cranks.
  9. Oct 1, 2012 at 10:03 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    BTW, I would have absolutely no probelm running Stabil, Startron or Seafoam, I just choose Seafoam for the "one product" thing mentioned earlier.
    My generator is my extreme case. It's an emergency generator that normally sits all year long (only had one emergency so far). Every spring I drain the fuel tank, change the oil, refill the fuel tank with fresh gas and Seafoam. I then let it run for 20 minutes or so, shut it down, top it off, and back into storage it goes. Over the last 5 years it always starts up on the second pull after sitting all year.
    Seafoam also works great on the motorcycle's CV carb. Keeps the jets clean and "jetting".
  10. Oct 1, 2012 at 10:11 AM
    Pugga
    Massachusetts
    Thanks for the reminder to pull out the generator and make sure it's still working :thumbsup:
  11. Oct 1, 2012 at 10:13 AM
    Amo-cat3
    Amo-cat3 Wizard Sleeve Master
    Maui, Hawaii
    07 TRD Blown dubcab
    TRD Supercharged 4.0 w/ 2.5" Quick change Pulley, UCON EMS, URD 7th injector, AFE Stage II intake, DT Longtubes, MBRP 2.5" dual exhaust w/ Vibrant Ultra resonator, URD Y-pipe w/ vibrant v-bands (Cat free), Walboro 255 fuel pump, SS Oil catch can, Aeroforce gauges, Icon CDC 2.5 coilover set at 3", 1.5" Wleelers Progressive aal, Light racing uca, 17x8.5 Fuel Anza 4.5" backspace/-6 mm offset, Kelly Safari a/t 265/70/17, scanguage 2, AMP electric steps, bed extender, Low-pro tonneau cover, 20% tinted windows/headlights/taillights, tacoma seat covers, Image dynamic sound system w/ Pinoneer avh3200 head, assrtd stickers................
    Per google search gas with E10 has a max shelf life of 3 months.
  12. Oct 1, 2012 at 7:07 PM
    CUtacomaTIGER
    San Diego
    2 months is prob the longest i've waited to use the extra gas
    i keep it nearly full but the max fill line is obviously below the close valve and so there is going to be some air left inside.
    i'm not really concerned just thought i'd take precaution cause i can. and if i ever get a small motor of some sort i'd def use a stabilizer and in theory know what works or not
  13. Oct 2, 2012 at 5:37 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Should have said that first. I would not worry a bit about 2 months assuming that the container is reasonably full. Only time I would run anything if waiting two months is for my bike, and that's only due to the CV carb jets liking to clog up if it's not run regularly. If it was FI, I'd have no additives.
