What fuel treatment do you use?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtgroce, Feb 26, 2012.
Which do you prefer?
Poll closed Mar 28, 2012.
  1. Lucas Fuel Treatment
    71 vote(s)
    25.6%
  2. Seafoam
    52 vote(s)
    18.8%
  3. Chevron Techron
    41 vote(s)
    14.8%
  4. Gum Out
    8 vote(s)
    2.9%
  5. Other fuel treatments
    27 vote(s)
    9.7%
  6. None
    78 vote(s)
    28.2%
  1. Feb 27, 2012 at 5:55 AM
    TheMike515
    TheMike515 Well-Known Member
    Phoenix AZ
    OME Coilovers and Dakar Leafs
  2. Feb 27, 2012 at 6:12 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Chevron techron!
  3. Feb 27, 2012 at 6:13 AM
    Omar
    Omar Well-Known Member
    New Jersey
    TRD Sport Access Cab
  4. Feb 27, 2012 at 6:36 AM
    crazyengineer
    crazyengineer Well-Known Member
    patrick
    Bristol, TN
    05 Tacoma SR5 TRD Offroad
    K&N Cold Air Intake, Warn Winch and Bumper Guard, Wet Okole Seat Covers, Undercover Bed Cover, TRD Kenwood Head Unit, Infiniti Speakers, JL 13.5 inch pancake sub
    Sea Foam
    I've watched it make mowers that were running rough start running better just because the gasoline used was mixed with the seafoam.....I have used it in my truck and need to start again....once a month it was dumped it.
    good question, has anyone? If they have, did it help?
  5. Feb 27, 2012 at 2:09 PM
    jtgroce
    jtgroce [OP] Got R Did
    In the Foothills, NC
    '12 Taco MGM TRD Off Road
    K&N Air Filter Husky Floor Liners Weathertech Vent Visors LED Map/Dome Light Mod Chrome Door Handles AVS Bugshield Bed Mat Fog Light Anytime Mod DTRL LED's Flowmaster Super 40
  6. Feb 27, 2012 at 3:13 PM
    amain
    amain Well-Known Member
    Brian
    Anacortes, Washington USA
    07 SC TRD FJ - The Black Lemon
    Fender Cracks
    I use it every 4k miles on my engine that now has 130k miles and I think its the best additive on the market... And I have used them all.....
  7. Feb 27, 2012 at 3:23 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    marvel mystery oil!
  8. Feb 27, 2012 at 3:25 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    That's what we use in the continental 220 7 cylinder radials we run on our Waco UPF-7s. Does work.
  9. Feb 27, 2012 at 3:48 PM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    BG-44k in the Tacoma.
    Seafoam in the lawn mower, leaf blower and weed whacker.
  10. Feb 27, 2012 at 4:01 PM
    Thorpedo26
    Thorpedo26 Well-Known Member
    Brandon Thorpe
    Justin TX
    2006 silver 4 cylinder
    Blacked out badges, weathertechs, painted grill, cut tailpipe, removed mud flaps, black head lights, red calipers, tinted tails, front and rear bilsteins are here along with fatbobs spacer and aal awaiting install, also a set of 16 inch pro comps are here and 265/75/16 dynapros
    seafoam pre oil change, lucas every now and then. last time i seafoamed when i drove out of my drive way it looked like there was a wildfire on my block and i smoked out all the little kids on the bikes and scooters.
  11. Feb 27, 2012 at 4:38 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Fuel in the fuel tank, oil in the crankcase, coolant in the radiator.
    Anything else is a band-aid for a needed mechanical repair, or a prophylactic that protects against nothing.
  12. Feb 27, 2012 at 5:22 PM
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    Amsoil PI here. Every oil change. I think I remember seeing that most dealerships (it might be in the owners manual?) add a fuel additive every oil change. And P.I. is the best you can get IMO. :cool:
  13. Feb 27, 2012 at 5:36 PM
    elmo7
    elmo7 Easily Replaceable Member
    SC
    07 DC TRD OR 4x4
    Is there a good reason to? Besides reading the side of their bottle?
  14. Feb 27, 2012 at 5:47 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i have only used a treatment once or twice in my truck, I use Star-Tron enthanol enzyme treatment in all my other stuff (mower, generator, trimmer, blower, ATC's - yes i have 3 wheelers...) i have tossed some in the truck for a few tanks
  15. Feb 27, 2012 at 5:48 PM
    #35
    pudge151
    Sean
    Connecticut
  16. Feb 27, 2012 at 5:52 PM
    #36
    jackhart
    jackhart Well-Known Member
    11 DCLB
    most quality name brand gasolines already have good detergent in them so i don't feel the need to add a fuel additive all the time or even every oil change. maybe once every 20-30K miles i'll add Techron just to be sure. i think it is cheap insurance.
  17. Feb 27, 2012 at 6:17 PM
    #37
    1980
    1980 Well-Known Member
    The Dust Bowl
    Just because a truck smokes when Seafoam is sprayed in doesn't mean that that smoke is coming from burned-off deposits. Most if it is probably coming from the burning the Seafoam itself. I'm of the opinion that if you use good gas in a new truck then you shouldn't need cleaners; the exception would be if you have let your truck sit all winter (but if you are going to do that you should use a fuel stabilizer). On an old used vehicle that's running rough carb cleaners can work well though. I used a spray-in cleaner on a '50 Desoto that had set in a barn for 30 years and it ran a whole lot better.
  18. Feb 27, 2012 at 7:09 PM
    #38
    1980
    The Dust Bowl
    Do a search on "fuel injector cleaner study," read through the .pdfs that you find, and you will begin to see that most of the people who promote cleaners also are involved in manufacturing or selling them.
    While manufacturer's/seller's study results should be taken with a grain of salt, you can get a good overview of how fuel injectors work, why they might clog and what can be done to unclog them if you read enough of these articles though.
    What I've ascertained so far is that these cleaners have a lot in common with paint stripper, lacquer thinner and Goof Off and can do a world of damage to rubber and plastic in the vehicle if not used properly.
    Carb and injector cleaners seem to work well for older vehicles where varnish has been allowed to build up but there are mixed results for newer engines. Engines that have done a lot of short-trip long-storage driving might benefit from an occasional cleaning. However, several auto manufacturers tested engines for huge amounts of run-time without a single failure due to a clogged injector.
    Some studies have said that, while some engines do have deposits, these don't really affect performance all that much. However, when these deposits are stripped off then redeposited they sometimes can cause more problems than if they were left alone.
  19. Feb 27, 2012 at 10:08 PM
    #39
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Techron every 5k miles.
  20. Feb 27, 2012 at 10:23 PM
    #40
    TS1980
    TS1980 Well-Known Member
    South Florida
    2019 Tacoma DC 4x4
    I put a bottle of Lucas Fuel Treatment in about every oil change interval.
