What fuse runs my trailer lights
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ricky B, Jul 21, 2009.
  1. Jul 21, 2009 at 12:52 PM
    Ricky B
    Ricky B [OP] Well-Known Member
    Arkansas
    1998 XCAB
    Ok guys. I have a 2001 DC v6 and when I got the truck it was wired up for a trailer. It has the trailer pigtail plug right behind the bumper. I don't have juice coming from the plug below my bumper and I think it's called the male plug. So I'm trying to trace where my problem is. First trace is to look at the fuse and make sure it's OK. The diagram doesn't show a trailer fuse so thought one of you may know which one runs the trailer lights. Thanks Rick
  2. Jul 21, 2009 at 3:18 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
    Brake lights?
  3. Jul 21, 2009 at 4:05 PM
    Rtrn2taco
    Rtrn2taco Nostalgia...
    Philadelphia
    08 DC PreRunner (silver)
    Did you buy the truck new? Are you certain its a factory install? have you taken the taillight out?
  4. Jul 22, 2009 at 2:00 PM
    Ricky B
    Arkansas
    1998 XCAB
    Not really sure if it came from Factory. I bought it second hand. Rick
  5. Jul 22, 2009 at 2:40 PM
    Rtrn2taco
    Philadelphia
    The tacomas require a convertor box (modulite) to convert the wiring from a 3 wire system ( seperate turn signals) to a 2 wire system (brake and turns combined). These convertors are notorious for going bad and causing the same issues your are having. Crawl under the truck or in the taillight area and look for the box.
    Chances are it has gone bad and needs to be replaced.
