What gas are you pouring in your 16?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by strictlys, Oct 3, 2015.
  1. Oct 3, 2015 at 7:52 AM
    strictlys
    strictlys [OP] Well-Known Member
    2016 Super White Tacoma DC TRD OR SB
    I been experimenting with 87 gas and 91 gas. Not sure if there is even a difference.
    Shell Gas
    Getting about 21.5mpg.
    I have about 860 miles now approximately.
  2. Oct 3, 2015 at 8:05 AM
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    85 octane from a Terrible Herbst gas station in Vegas
    only the best!
    greeneggsnspam and .28 like this.
  3. Oct 3, 2015 at 11:12 AM
    Ndanger
    Ndanger Active Member
    Hawaii
    08 Tacoma 4x
    Quick question, how are you calculating the mileage, manually or by the computer and could I ask what speeds and type of driving hwy or city that allows your mileage?
  4. Oct 3, 2015 at 11:27 AM
    .28 TacoRunnerCamry
    miguel
    Texas
    2016 TRD Offroad DC 4x4
    Fuckin A! The finest of wines.. lmao!
    Z50king[QUOTED] likes this.
  5. Oct 3, 2015 at 2:59 PM
    strictlys
    Doing it by computer and its just highway. Still breaking it in. Prob 60-70 mph
  6. Oct 3, 2015 at 3:08 PM
    Bgil
    Bgil Well-Known Member
    Camano island wa
    buying 2016 DCSB Sport
    What octane gas does the owners manual specify?
  7. Oct 3, 2015 at 3:18 PM
    strictlys
    87 min
  8. Oct 3, 2015 at 3:18 PM
    tincan
    tincan Well-Known Member
    Jim
    Tulsa, OK
    2018 CEMENT 7544, OF, TP
    87 (Research Octane number 91) or higher. Pg 570 in OM
  9. Oct 3, 2015 at 4:03 PM
    LaPorta
    LaPorta Well-Known Member
    No point to putting anything higher than what's recommended unless you have re-tuned an engine with higher compression ratios. Just a waste of money.
    Vietguy, CanadaToy, bdunna and 3 others like this.
  10. Oct 4, 2015 at 8:36 PM
    Z50king
    Eric
    Southern California
    Stock and loving it
    Please quote your source on that information
  11. Oct 4, 2015 at 8:51 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    +1
  12. Oct 5, 2015 at 2:34 AM
    LaPorta
    It has to do with the organic chemistry behind how Octane affects combustion. This is a rudimentary explanation of how octane rating works:
    http://auto.howstuffworks.com/compression-ratio-octane-ratings.htm
    Here are a few quotes:
    "Quite simply, octane ratings are a measurement of a gas's ability to resist detonation."
    "Putting high-octane fuel into a car that only needs low-octane fuel is a total waste of money,"
    Basically, the higher octane rating, the more that the gasoline resists spontaneous combustion without first being ignited by the spark plug. If this is the case, the gas and air mixture can be compressed even tighter before exploding, obtaining more released energy when it is exploded. Most engines today do not have high compression ratios, and 87 octane is all that is required to prevent the gas from detonating prematurely. On the other hand, high compression engines that do require high octane can spontaneously combust lower octane, causing engine knocking.
    Simply put: all the folklore about putting in high octane "now and then" to "clean" the engine or get better performance is all nonsense. If your manual says you need 87, 87 is all you need. If it says you need 93, 93 is the minimum you better use.
    bdunna and Rocky5000100 like this.
  13. Oct 5, 2015 at 3:38 AM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    +2, I use 93 in boat only because I have milled heads and running high compression. Ran some 93 once in Tacoma with no MPG increase and nothing on butt dyno. Why waste money for no gain.
  14. Oct 5, 2015 at 4:10 AM
    Penten
    Penten Well-Known Member
    Peter
    Iowa
  15. Oct 5, 2015 at 6:14 AM
    Ron62
    Ron62 Well-Known Member
    Ron
    Fort Worth, Texas
    The guys who insist on putting premium in their Tacomas are probably the same guys who change the oil at 3000 miles. Both are a complete waste of money.
  16. Oct 5, 2015 at 6:33 AM
    SDTaco4x4
    SDTaco4x4 Well-Known Member
    San Diego
    2016 Black TRD Sport 4x4
    I haven't had to fill up yet, but I'm just gonna use regular Costco gas.
  17. Oct 5, 2015 at 6:33 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    true
  18. Oct 5, 2015 at 7:16 AM
    trdguy82
    trdguy82 Well-Known Member
    Tulsa
    16 Tacoma Limited 4X4 MGM | 93 MR2
    You're much better off using ethanol-free gasoline than using a higher octane gasoline. 87 100% gas is your best bet. Your truck will thank you.
  19. Oct 5, 2015 at 7:20 AM
    SDTaco4x4
    San Diego
    There is no choice here in CA. We have to use the crap ethanol gas, unless there is some magical gas station somewhere I haven't seen. lol
  20. Oct 5, 2015 at 10:46 AM
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
