What gas are you pouring in your 16?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by strictlys, Oct 3, 2015.
  1. Oct 5, 2015 at 10:53 AM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Why is it always regular or premium? I've been using 89 mid-grade, or plus as they call it since I bought he truck. Works great.
  2. Oct 5, 2015 at 10:56 AM
    NoDak
    NoDak Well-Known Member
    JR
    Minot, ND
    16 Tacoma TRD Sport 4x4 Blazing Blue
    87 or 89 10% eth still gets worse mpg than straight 87. only way to get straight gas is to go premium and it will usually get better mpg than any 10% eth gas.
    but that is the only benefit you will get.
    Herniator likes this.
  3. Oct 5, 2015 at 11:05 AM
    Shelf Life
    Rob
    Central Oregon
    To each his own. I get worse mileage with 87. I don't see a difference in mileage between 89 and 91, but the truck dogs with 87. Eth free gas is pretty spendy and hard to find.
    steven15sport likes this.
  4. Oct 5, 2015 at 11:09 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I've used 87 and 91 in my vehicles. Never could tell a difference at all.
    And certainly not anything that could justify that price difference
  5. Oct 5, 2015 at 11:10 AM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    The 4.0 engine is optimized to use 91 octane. The computer software allows it to detune itself a bit to allow the use of 87. You won't notice a difference by switching between the 2 for one tank. It takes the Tacoma computer a bit to adjust itself for a different octane. For best performance, 91 is the way to go.
  6. Oct 5, 2015 at 11:11 AM
    smmarine
    Melbourne FL
    I tried non-ethanol 87 in my 3.4 a few times. It took a few tanks before I noticed an increase in mpg. And it was 1-2 mpg at best. Wasn't worth the extra dollar per gallon
    smitty99 likes this.
  7. Oct 5, 2015 at 11:12 AM
    NoDak
    JR
    Minot, ND
    tracking my mpg's 89 w/ 10% gets maybe 1-2 mpg more easily than 87. 91 gets about 1 maybe 2, but its more work to consistently get 1-2 mpg more.
    are you using an app to track your mpg or is this based on seat measurements ?
  8. Oct 5, 2015 at 11:42 AM
    smitty99
    Scottsdale
    Just logging my odometer and using phone calculator on fill ups.
  9. Oct 5, 2015 at 12:14 PM
    LtTaco
    LtTaco Well-Known Member
    Tennessee
    2016 SuperWhite Limited 4X4
    Is the 10% eth gas actually bad for a motor or just not as efficient?
  10. Oct 5, 2015 at 12:14 PM
    viking15
    viking15 Well-Known Member
    Joe
    Exactly. If Toyota is telling you to use 87 then 87 it should be. Who would know better than the maker of the truck.
    bdunna likes this.
  11. Oct 5, 2015 at 12:19 PM
    Shelf Life
    Rob
    Central Oregon
    Pretty much all modern cars past 2001 I believe, are configured to run on 10% eth.
  12. Oct 5, 2015 at 12:28 PM
    LaPorta
    LaPorta Well-Known Member
    Source for his? Would be interested to read.
  13. Oct 5, 2015 at 12:40 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    Yup!
    The 4.0 produces 236 hp @ 5,200 and 266 lb ft @ 4,000 on 87. Using 91 it produces 239 hp @ 5,200 and 278 lb ft @ 3,700.
    That said, I have no idea what the deal is with the 3.5. It may indeed be pointless to run anything more than 87. For what it's worth, I've always run 91 in my truck. It just seemed to have slightly better response and when I actually tracked my mileage, it was also better than with 87 (although in fairness the price differential probably made it a wash).
  14. Oct 5, 2015 at 12:43 PM
    viking15
    Joe
    Can you provide us the source of where you obtain this information from
  15. Oct 5, 2015 at 12:43 PM
    #35
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    How does a slower burning fuel in a cylinder deliver "better response" AND better MPGs??
    bdunna likes this.
  16. Oct 5, 2015 at 1:06 PM
    #36
    smmarine
    Melbourne FL
    quote from Wiki: The 1GR-FE is the 4.0 L (3956 cc) version, designed for longitudinal mounting in RWD and 4WD pickup applications. It has a 94 mm bore and a stroke of 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's VVT-i, variable valve timing system on the intake cam and a compression ratio of 10.0:1.
  17. Oct 5, 2015 at 1:08 PM
    #37
    smmarine
    Melbourne FL
  18. Oct 5, 2015 at 1:25 PM
    #38
    viking15
    Joe
    Oh really......Let's see the last time I looked at my owners manual I could have swore it said 87 octane. Let me look at it again tonight to confirm. I will let you know tommorrow
  19. Oct 5, 2015 at 1:25 PM
    #39
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    I run 91
    For me the choice has nothing to do with performance or MPG gain, but more how it sounds.
  20. Oct 5, 2015 at 1:33 PM
    #40
    Hans Moleman
    Hans Moleman Well-Known Member
    Bay Area, CA
    2023 F-150 Powerboost
    The ecu can compensate for increased octane by advancing the timing which increases power. But that doesn't matter because you don't need the extra power since you drive like gramps and take 6 minutes to get up to speed on the freeway.
