what gasket material to use
Discussion in '1st Gen. Tacomas (1995-2004)' started by da0023, May 12, 2009.
  1. May 12, 2009 at 9:26 AM
    da0023
    da0023 [OP] The One, The Only
    Drew
    Alabama
    99 PreRunner SR5
    none
    i am planning on dropping my oil pan this weekend to redo the old gasket that has developed a small leak. i just wanted to get some suggestions from folks who know, so what do ya'll recommend? I almsot forgot, how tight do i need to get the nuts/bolts when i reinstall the pan, is there a certain ft./lbs to torque it to, or just watch unitl the gasket starts coming out.
  2. May 12, 2009 at 9:45 AM
    98tacoma27
    Ben
    Not Beech Creek
    I prefer a rubber gasket. If you use cork, I suggest coating the entire gasket in RTV, top and bottom.
  3. May 12, 2009 at 9:47 AM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    i can't seem to find a rubber gasket, everybody has told me that you have to get some permatex and make your own.
  4. May 12, 2009 at 9:48 AM
    98tacoma27
    Ben
    Not Beech Creek
    Can you get a cork one?
  5. May 12, 2009 at 9:53 AM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    not even a cork.
  6. May 12, 2009 at 10:26 AM
    98tacoma27
    Ben
    Not Beech Creek
    You can purchase gasket material (usually) at your local parts store, cork included. I am assuming they are only offering a thin felt/paper type of gasket? No matter what material you end up with, I would suggest coating the entire gasket in this stuff, especially if it is a paper type gasket.
  7. May 13, 2009 at 4:25 AM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    98tacoma, i did some checking yesterday and found a rubber replacement gasket by felpro. i will probably go this route, what do you think.
  8. May 13, 2009 at 4:55 AM
    98tacoma27
    Ben
    Not Beech Creek
    :thumbsup:
    I would go that route. Rubber lasts longer than other materials.
  9. May 13, 2009 at 2:26 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    is there any tips/tricks to make the gasket stick to one surface during install, that it will not move out of place while i'm getting the nuts/bolts started, and how tight to i need to get the nuts/bolts.
  10. May 13, 2009 at 7:13 PM
    98tacoma27
    Ben
    Not Beech Creek
    You can use that gasket stuff I referenced earlier. Make sure both surfaces are clean. Wipe the bottom of the block with the gasket stuff and press the new gasket to it. It should hold it in place. The stuff is really tacky. Line your holes up so you don't pinch the gasket with the bolts.
    I believe they are only M6 or M8 bolts. They don't require a lot of load to torque them down, some where between 10-20 ft/lbs. I generally put enough pressure on the bolt so the gasket compresses a little, meaning it will start to squish outward. Too much and you will damage the gasket.
  11. May 13, 2009 at 7:18 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    I believe the pan bolts are @ 10ft/lbs
  12. May 13, 2009 at 7:47 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    thanks for all the helpful advice guys :)
  13. May 13, 2009 at 7:54 PM
    98tacoma27
    Ben
    Not Beech Creek
    Any time Gunny. Thats what we are here for.
  14. May 13, 2009 at 7:59 PM
    da0023
    Drew
    Alabama
    99 PreRunner SR5
    none
    Ooh Rah!
