What gear for towing?
Discussion in 'Towing' started by Nixinus, Jan 14, 2013.
  1. Jan 14, 2013 at 1:55 PM
    Nixinus
    Nixinus [OP] Well-Known Member
    I am about to move from LA to Temecula (about 150 miles) and will be using a 5'x8' U-Haul trailer. The trailer weighs 900 lbs. empty. I assume the cargo will be anywhere from 1/2 - 1 ton total (high estimate), placed both in the trailer and the bed of my truck. Most of the way is flat land with the occasional up and down grades. I have a 2010 V6 Sport with tow package and Trans & Rear Leaf TSB. This will be my first time towing and I would like to know of any advice you may have for me. I have read the towing bible thread, as well as many others on this forum. I am confident that it should be simple as I am well below tow capacity. My question is:
    Gear selection: I want to be in 4th for any uphills but would you recommend OD for flat land? I would like the better MPG but not if it is at the risk of over stressing the transmission. Should I try to leave the truck in D and monitor the Trans Temp and shifting of the truck? If the trans stays in a good temp range and the trans doesnt hunt, is there any risk to wear by driving in D?
    I am being cautious here and just looking for advice on anything I may be overlooking.
    Thank you.
  2. Jan 14, 2013 at 2:00 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    As long as the transmission isn't hunting for gears, I keep it in D for towing. On extended uphills or downhills, I'll go to 4. Just be mindful when you load the trailer. How you load the trailer could be the difference between a nicely tracking trailer and fighting it 100% of the time. You want a little more weight in front of the trailer axles vs behind. If you overload the rear, it can start swinging.
  3. Jan 16, 2013 at 9:50 AM
    Nixinus
    Thanks for the reply. Loaded up the truck and trailer to the max. Had a little sag in the rear but the little taco held up very well. I was surprised at how easy she pulled everything and at times I had to look back and make sure the trailer was still there because it didn't feel as if I was towing at all. I spent time planning the weight distribution, which kept the trailer tracking with minimal sway. Trans temp stayed below 140 the whole way including uphill climbs and stop and go street traffic. Good job Toyota.
  4. Jan 16, 2013 at 9:55 AM
    Brunes
    Brunes abides.
    Rotorhead
    Good job to you too man. Too many folks think they can just throw shit in a trailer and the bed and drive off. Taking time to plan it is important.
    Glad you made it safe and good luck settling in!!
  5. Jan 16, 2013 at 10:02 AM
    Pugga
    Massachusetts
    F-150 Mod
    Success :woot:
  6. Jan 16, 2013 at 10:16 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I was told by my transmission instructor to never tow in overdrive. The lightweight aluminum planetary gear carriers can't hold up to the constant jerking the trailer gives the drivertrain. He showed me an example. It was ugly. The man had 20yrs experience in rebuilding transmissions in a trans-only shop. I tend to believe him.
    Go 55-60 and take it easy. Follow Nixinus' suggestions, but weigh it, to make sure you're not overloading the rear axle, or tongue.
  7. Jan 16, 2013 at 12:54 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    You did your homework and did it right. One thing I always try to do when towing or hauling heavy loads is to keep the engine in the powerband and not lug it(2000-2400 RPM) for our engines.
  8. Jan 17, 2013 at 1:31 PM
    Nixinus
    I would like to know more about this. If there is a problem with components of the drive train not taking the push-pull motion well, wouldn't it affect all gears? Or are you referring to the push-pull of gear hunting?
  9. Jan 17, 2013 at 1:36 PM
    Nixinus
    One more thing I want to add is that the transmission stayed at a constant temp regardless of what gear I was in. I assume that was the case because of the relatively lighter load I was carrying.
    I don't quite understand where 5th gear Heya used in our trucks, considering its a 6 speed and we don't have a 5th gear manual option. I found that if I left it in OD and applied throttle then the truck would downshift. I assumed it went into 5th because in that situation I could manually put it in 4th and it would do another downshift.
    Mileage was very good too. I averaged about 16mpg with some hills, some city driving and a fwy detour because of a closure. I chalk that up to the lighter load and an average fwy speed of 55-60 mph.
  10. Jan 17, 2013 at 2:02 PM
    Warped
    Warped N4LJ
    Jim
    Eastern Ky
    2016 AC 4X4 2.7 Auto
    Its a 5 speed with a lockup torque converter.
    You were mistaking the unlocking of the
    torque converter as a down
    shift from a non existent 6th gear
  11. Jan 17, 2013 at 2:03 PM
    Pugga
    Massachusetts
    F-150 Mod
    The Toyota has a locking torque converter. When you first apply the throttle when in O/D, you are feeling the torque converter unlock, causing the RPMs to raise. Then, when you shift to 4th, that is an actual downshift.
  12. Jan 17, 2013 at 6:06 PM
    Nixinus
    Thank you for the clarification. I did wonder why the last "gear" was only a short drop in rpm but it all makes sense now.
  13. Jan 17, 2013 at 6:24 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    I pulled 5k lbs with mine across the country PCS awhile back and you wouldn't even think you had a load behind it. I dropped out of overdrive once just to take it easy on the tranny, but 90 thru the rockies was nothing.
  14. Mar 25, 2013 at 11:44 AM
    jdavis92
    jdavis92 Well-Known Member
    Flagstaff, AZ
    05 Tacoma V6 SR5 Package #8 Debadged
    URD TCAI, aFe 2.5" exhaust, UltraGauge, Weathertechs, Wet Okoles
    How did you monitor your tranny temp?
  15. Mar 25, 2013 at 11:47 AM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    probably a scanguage or ultragauge
  16. Mar 25, 2013 at 11:49 AM
    jdavis92
    Flagstaff, AZ
    How? I have an Ultragauge and my 05 V6 does not feed it tranny temp.
  17. Mar 30, 2013 at 5:57 AM
    killbeal
    killbeal New Member
    08 TRD Offroad
    3" suspension lift
    I have a v6 tacoma and in my manual it says to tow in 3rd gear but everybody on here is saying 4th. I usually use 4th cause in third the rpm stay around 3500 and it sounds like it wants to change gears. not to mention the gas sucking issues....any thoughts?
  18. Mar 30, 2013 at 6:26 AM
    rickmeseke
    rickmeseke subaru of america
    Ricky
    Brunswick, GA
    a white truck
    Just keep it in the highest gear unless on a hill
  19. Mar 30, 2013 at 6:47 AM
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    n00b question, but I drive an 01 v6 prerunner automatic. Am i able to shift gears on the fly? Or do I need to pull over, shift, then go again? About to make a cross country move, and have never towed anything before.
  20. Mar 30, 2013 at 7:13 AM
    95 taco
    95 taco Battle Born
    The scan gauge might have more features than the ultra gauge :notsure:
    He might also have the torque app for android devices.
    Shift on the fly, but the 1st gen autos are 4 speed instead of 5 like the 2nd gens.
    Basically all you have to do is push the o/d button on the shifter and it will limit the transmission to 1-2-3 gears.
