what gear oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TaCo07, Apr 11, 2011.
  1. Apr 11, 2011 at 3:58 PM
    07TaCo07
    07TaCo07 [OP] Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    Im looking to change the gear oil and transfer case oil. Red line has two types: one for lsd and one not and u can add their lsd additive and Valveline synthetic is for lsd. My question is if the oil is for the axels with a lsd do u still have to put friction modifier in with. Also do u want that oil for lsd in the transfer case and front diff?
  2. Apr 11, 2011 at 8:18 PM
    rossk35
    rossk35 Do Work Son!
    hawaii
    07 TRD Sport Supercharged
    TRD S/C/TRD Intake/TRD Boost Gauge/DT Headers/OEM TL/ZKW retro/Pioneer DVD w/Ipod/Magnaflow/20% Tint/BHLM/JL 10" sub, JL VR components, JL 450/4 amp/Helwig Sway bar/Viper 791/ 18" limited 4runner rims
    if you have a lsd on your truck get the redline 75-90 with the additive already in it. You don't need to add extra. I got valveline gear oil and added the additive separately and it chattered real bad, so I ended up getting redline and it went away instantly. The trans uses mt-90 which you can also get from redline. Not sure on the transfer case, but I would assume its the same as the trans. The front diff doesn't require additive.
