What gear ratio 2004 Tacoma 3.4 V6 Supercharged 4.10 Gears Penny for your thoughts
Discussion in '1st Gen. Tacomas (1995-2004)' started by Q Source, Jan 10, 2014.
  1. Jan 10, 2014 at 8:39 PM
    Q Source
    Q Source [OP] Well-Known Member
    California
    04 PreRunner
    Supercharged, TRD Headers, URD 7th/SHORTIE 800cc injector, Snow Performance Water/Meth Kit, Deaver FJ59, Icon UCA, Fox Extended Travel Remote Resi, TG Front and Rear Bumpers, Deckplate Mod
    Hey All,
    Auto - Prerunner.
    I am looking to get a little input on your thoughts.
    Current ratio is 4.10
    Im thinking I should regear the truck since when I'm @ 70MPH in overdrive I'm @ 2250RPM's.
    Im thinking either 4.56 or 4.88 any ideas?
    I am running 265/75/R16 Wheels/tires.
    My goal is to make it more drivable, I know that sounds weird but going up a small hill @ 2000RPM's with the SC and putting 2-4PSI of boost before the tranny changes doesn't seem right. I would rather boost at a higher RPM Range.
    Any thoughts?
    Thank you.
  2. Jan 10, 2014 at 8:58 PM
    604YOTA
    604YOTA Well-Known Member
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    Grey wire mod, eibach, 5100's & 5125's, ome Dakar leafs, 1.25 rear shackle, Gibson exhaust, ram air intake, throttle body spacer, boot slide mod, poly bushing kit, extended brake lines.
    What size tires are you running?
  3. Jan 10, 2014 at 9:10 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    Are you trying to make the engine turn more or less rpms? I turn somewhere around 2800 rpm give or take a few with a 5 speed manual at around 70mph.
  4. Jan 10, 2014 at 9:13 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    What is your overall goal?
  5. Jan 10, 2014 at 9:29 PM
    tomtom
    The Desert SW
    2012 FJ
    Everything else held equal:
    4.56 will give you approx. 2500 rpms at the same speed.
    4.88 will give you approx. 2680 rpms at the same speed.
  6. Jan 10, 2014 at 9:41 PM
    Q Source
    California
    04 PreRunner
    More.
    I put it into overdrive off and I was at 3250@ 75mph which I feel is OK.
    With OD on it seems super low for the engine specs, I go into boost regularly around 2000 2250 rpm's@65-70 MPH
    With the overdrive on the tranny keeps me @2250 during normal 4th gear operation @70 MPH.
  7. Jan 10, 2014 at 9:45 PM
    2000GTacoma
    Snow Hill NC
    Have you got that reversed? Overdrive off and you turn 3250@ 75?
    OD on you are at 2250@70?
  8. Jan 10, 2014 at 9:49 PM
    Q Source
    California
    04 PreRunner
    Thanks TT, So if I read your post correctly…
    @ 70MPH in overdrive ON I'm @ 2250RPM's.
    W/4.56 2500 rpms
    W/4.88 2680 rpms
    Call me stupid but how did you come to that conclusion?
    I checked quite a few gear ratio calculators and none of them(that I found) take into consideration that the Auto Tranny in 3rd is 1-1 but in 4th(overdrive is .705)
  9. Jan 10, 2014 at 9:54 PM
    Q Source
    California
    04 PreRunner
    Correct Sir!
    Hit the OD button turns it OFF and RPM's go up….
    Hit it again and OD is ON RPM's go down…
  10. Jan 10, 2014 at 9:55 PM
    tomtom
    The Desert SW
    2012 FJ
    as stated above, something ain't right because in O/D you should be at your lowest RPMs at highway speed. This is due to the 1:0.7 ratio.
    As for the calculation, I assumed the RPMs given were readouts from your tach at speed. Then just divided out 4.1 and multipied by the new ratios (4.56 and 4.88).
  11. Jan 10, 2014 at 9:57 PM
    604YOTA
    Disco Stu
    Vancouver, BC
    04 TRD SR5
    What about more boost? Find a smaller pulley?
  12. Jan 10, 2014 at 10:18 PM
    Q Source
    California
    04 PreRunner
    Yup, User error.
    I hit the OD button and type that it is off when is is the opposite.
    With the Auto tranny OD is always On. Until you hit the button and then it is OFF.
    Wish it was the opposite.
  13. Jan 10, 2014 at 10:27 PM
    Q Source
    California
    04 PreRunner
    Man I am annoying myself.
    If I don't touch anything my RPM are 2250 @ 70mph.
    If I hit the OD OFF button the Rpm's jump up.
    I would like to be around 2750 Rpm's to 3000 Rpm's @ 70 MPH.
    So 4.56 or 4.88?
  14. Jan 10, 2014 at 10:30 PM
    davidpick
    davidpick NWXPDTN
    David
    Leavenworth, WA
    1988 Pickup 22R 5sp 2wd
    Weber 32/36, RV Cam, LCE exhaust headers, Desmogged
    i have a supercharged 04 4x4 with 285/75r16s and regeared to 4.88s and absolutely love it. not sure it'd be worth it to regear with 265s though...
  15. Jan 10, 2014 at 10:32 PM
    2000GTacoma
    Snow Hill NC
    I would leave it to be honest. That's where the engine was designed to be at with the auto transmission. If you need more go just kick it out of overdrive or put your foot down and it will shift.
  16. Jan 10, 2014 at 10:39 PM
    Q Source
    California
    04 PreRunner
    Why not?
    Your tires are only 3.7% bigger than mine?
    Im almost 32 and you are almost 33?
    265/75-16 285/75-16 Difference
    Diameter inches (mm) 31.65 (803.9) 32.83 (833.9) 1.18 (30) 3.7%
  17. Jan 10, 2014 at 11:17 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If a 32 is the largest tire you ever intend to run, then 4.56s will put you back close to where it was with 31s.
  18. Feb 10, 2014 at 9:37 PM
    Digiratus
    Roaming the PNW
    The RedHead
    What is written on your "door tag" under A/TM?
  19. Feb 10, 2014 at 10:51 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    4.10's are good for 32's..
  20. Feb 12, 2014 at 8:47 AM
    Taylor
    Taylor Check out NASA Spec3!
    Taylor
    Vienna, Virginia
    NASA Spec3 RaceCar
    Yeah, why would you want to be turning almost 3000 RPM? Excessive wear to the engine and shitty mileage are a'comin.
