What gearing do I have?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Jul 13, 2010.
  1. Jul 13, 2010 at 6:07 AM
    ywen
    ywen [OP] Well-Known Member
    03 v6 auto 4x4 with TRD OR package.
    I'm trying to fig out between
    *FGR=43:11=3.909,W(A.D.D)
    *FGR=41:10=4.100,W(A.D.D)
  2. Jul 13, 2010 at 6:09 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
  3. Jul 13, 2010 at 6:10 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    You should have a 4 digit gear code on the door sticker. It will be like this:
    B04A
    See what code you have, and use this:
    http://www.tacomaterritory.com/wiki/index.php/Gear_Codes
    First digit:
    • A = 7.5" ring gear
    • B = 8" ring gear
    Next two digits:
    • 01 = 3:42
    • 02 = 3:58
    • 03 = 4:10
    • 04 = 4:56
    • 05 = 3:15
    • 06 = 3:91
    • 07 = 4.30
    Last digit:
    • A = 2 Pinion, Open
    • B = 4 Pinion, Open
    • C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.
    Edit by Ed Quinones on 10-7-05: I used to own a 99 Prerunner ext cab 2.7L with auto tranny and gear code of B07A. It came from the factory with a 4.56 gear ratio.
  4. Jul 13, 2010 at 6:11 AM
    ywen
    Thanks!
  5. Jul 13, 2010 at 11:01 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    The 1st gen Tacomas with TRD electronic locker came with the older differential housing and the 7.5" ring gear and always with the 4.10 gear ratio.
    The 3.90 gear ratio equipped Tacomas came with the larger differential housing with the 8" ring gear. No factory lockers with these, only aftermarket.
  6. Jul 13, 2010 at 12:05 PM
    pittim
    pittim mittip backwards
    Pink slider.
    All the ring gears in the rear are 8". Front are 7.5"
    If your R&P are factory, and you have an elocker, you have 4.10s.
  7. Jul 13, 2010 at 12:07 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  8. Jul 13, 2010 at 1:49 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Thanks for clarifying guys. Sorry for the miss information.:eek:
