What gearing is ideal for 33's (255/85/16 or 33x10.5)
Discussion in '1st Gen. Tacomas (1995-2004)' started by finslayer83, Mar 22, 2024.
  1. Mar 22, 2024 at 8:26 AM
    finslayer83
    finslayer83 [OP] Well-Known Member
    TN
    TRDP 4runner / 01 Taco
    A lot
    Contemplating going to 255/85/16's or 33x10.5x15's.
    2001, auto, 4.10's is the current setup.
    This gets driven several days a week and all good trailheads are 3-5 hours away via interstate (Windrock, DBB, KAT).
    Goal is to offset gearing power loss going from a 235/85/16 to a 33".
    4.56?
    4.88?
    I've run 33x10.5's on a Jeep LJ before and loved the size, notably the C load range, just seems very hard to actually pin down what brand/model of 15" wheels work with the 1st gen caliper / disc size. I hate spacers.
    Thanks in advance!
  2. Mar 22, 2024 at 9:34 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    4.88 all the way. If you run a lot of weight, I'd even do 5.29. Should be fine since you're auto, your highway RPM's will be lower than a manual with 4.88.
  3. Mar 22, 2024 at 1:50 PM
    Gen1andDone
    Gen1andDone Well-Known Member
    2002 4wd Tacoma TRD v6
    I'm on 33's and 4.10's too, manual trans and 3.4l though. If I were to regear it would be 4.56's. If mostly an offroad toy I might consider lower gearing.
  4. Mar 22, 2024 at 4:27 PM
    OLDHMECH61
    OLDHMECH61 Well-Known Member
    Andy
    Odessa FL
    99 Prerunner Std cab green
    1UZ swap, trutrac diff, tundra brakes, 3 lift, FJ rims
    Im on 255/85R16 I went to 4:56 and its perfect (auto trans) it corrected my speedo made it spot on correct, at highway speeds 75-80 mph tach is around 2500 rpm, you go to 4:88 and your highway rpm will climb up to 2800+ at highway speeds, 4:88 would be really good off road thpugh.
  5. Mar 22, 2024 at 4:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't regear for 33s :rofl:
  6. Mar 22, 2024 at 4:58 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Bad advice.
  7. Mar 22, 2024 at 5:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll reiterate.
    From a financial standpoint, it makes more sense to regear for a larger tire (than 33's) and just go full ham to add lockers as well.
    A regear in itself is something anyone can benefit from, but for that level of work, may as well go all the way rather than open up the diffs again to get it locked later...or regear again for larger tires once those 33s are up.
    OLDHMECH61 likes this.
  8. Mar 22, 2024 at 6:31 PM
    Austintaco
    Austintaco Well-Known Member
    Patrick
    Austin,TX
    03 DC TRD with some stuff
    King coilovers, Tundra brakes, All pro Expo springs, Timbrens, ARB bumper, All Pro Sliders and Rear bumper, Landcruiser wheels, sold my Flippac, regeared to 4.88’s, ARB front Locker
    Been running 4.88’s with 255/85/16 for 12 years. 2003 DC Auto, lots of gear, bumpers, Flippac. Truck weighs 5200 lbs when not completely loaded. Great for highway/Colorado camping etc…would do it again.
  9. Mar 22, 2024 at 7:19 PM
    OLDHMECH61
    Andy
    Odessa FL
    Just curious whats your rpms at 75mph on freeway ?
  10. Mar 22, 2024 at 8:54 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Weight is more of a factor than "bigger tires". I hated how my truck drove when I installed load E tires and steel wheels. Also when I filled the truck up with parts, camping stuff, etc. Once I regeared it was like a whole new vehicle.
    I agree though, it would be a huge waste of time and money if you didn't do lockers while regearing.
  11. Mar 23, 2024 at 5:13 AM
    finslayer83
    TN
    A lot
    Rear is already locked and I'm not a fan of locked IFS.
    (have had several ARB's installed over the years in various rigs)
    You are right though, good buddy owns the local shop and he also said, save the coin and pay for the worse MPG.
    A 33x10.5 might be the ticket, skip the gears. Now to find a 15" wheel that works
  12. Mar 23, 2024 at 4:34 PM
    whitetaco01
    whitetaco01 Well-Known Member
    So Cal
    01 Prerunner
    Mid Travel Stuff
    My set up as well, also 33s. I like 4.56 for the daily driving around
