What gears and locker??
Discussion in 'Louisiana' started by Honey badger, Jun 13, 2012.
  1. Sep 4, 2012 at 8:25 PM
    Honey badger
    Honey badger [OP] Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    With the 3.4 and all the added weight of armor I'll be adding 4.88's should be good.
  2. Sep 4, 2012 at 8:28 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    Id go 4:88s. It would be a little over kill but perfect when you upgrade to 35s :D
  3. Sep 4, 2012 at 8:30 PM
    Brandon H
    Brandon H Well-Known Member
    Newhall, CA
    07 DC Offroad
    2017 4Runner TRD Offroad Premium. Icon stage 7, RCI skids, SCS SR8 wheels, budbuilt sliders, 285/70/17 BFG Ko2s (Old rig) 07 Taco TRD Offroad FUlly Locked, Icon Extended Travel CO's w/ remote resis., Alcan AAL's,Icon Remote Resi Rear Shocks, All Pro Front bumper w/ warn 9.5xp,winchline synthetic winch cable,All Pro IFS Skid plate, OME Shims, OME Carrier Bearing drop, Trail Gear Sliders, Yakima Load Warrior Basket, OEM Roof Rack, Hi Lift Extreme, Cobra model 19, Wilson Lil Wil Antenna, Yaesu ft-7800
    Ok man. Just telling you ahead of time. Its gonna be too low. But what do I know. Good Luck man
  4. Sep 4, 2012 at 8:40 PM
    Honey badger
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    I wasn't being a dick and not listening to your advice. Just simply saying that I'll be packing around a lot of weight as well as going with a 34-35 inch tire when these wear down. Also the only time I drive my truck is to go to the trails.
  5. Aug 9, 2014 at 11:28 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    So how did this all turn out?
    What locker combination did you go with?
    How are the 4.88's working out?
  6. Aug 10, 2014 at 7:14 PM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    I don't know what Bon did, if anything. But I installled 4.88's with the arb up front and the small arb comp. and love it. I'm running some high rpms on the interstate which kill mpgs but if I can keep it at around/under 55, I can get upwards of 17-18mpgs, its just difficult for me to do that lol.
  7. Aug 10, 2014 at 9:59 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    What tires are you running, and are you an auto?
  8. Aug 11, 2014 at 5:57 AM
    Southern01Taco
    Sean
    Holden, La
    I'm running 285/75/16 Goodyear MTR's and I'm manual. I'm also 1st gen with the 3.4.
  9. Aug 11, 2014 at 7:36 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    I would have thought that tire with your stick and the 3.4 would would have mated well with the 4.88's.
  10. Aug 11, 2014 at 9:40 AM
    Southern01Taco
    Sean
    Holden, La
    I personally think that the combo is perfect but because there are so many people out there with these trucks that are worried about mpg's more than they are power and torque then they won't like this combo. Here is a post I made earlier in the thread back when I was researching before I did anything and it turned out to be dead accurate.
  11. Aug 11, 2014 at 2:42 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    That's actually right on par for what I am thinking about the 4.56 with 33's. I think it will wake up this motor on the low end, I don't go much over 55. Or should I say where I live the max posted speed limit is normally 55 with the exception of the Interstates being 70.
    2nd Gen 4.0 with Automatic 5sp
    Stock 3.73 Gears with 265/65/16
    25mph = 880 RPM
    55mph = 1935 RPM
    70mph = 2463 RPM
    4.10 Gears with 285/70/17
    25mph = 874
    55mph = 1923
    70mph = 2247
    4.56 Gears with 285/70/17
    25mph = 972 RPM
    55mph = 2138 RPM
    70mph = 2721 RPM
    The 4.10 with 33's esentially returns the truck to stock feeling, factory tire with factory 3.73 gears.
    So in my opinion jumping to 4.56 is the only jump up in gear that is present and makes sense. Other wise I'm simply returning to stock.
  12. Aug 11, 2014 at 3:10 PM
    Southern01Taco
    Sean
    Holden, La
    Yea that sounds right. 4.56's was going to put mine right about where it was, stock. So I bumped up one more gear ratio to give me some extra torque. And honestly, other than the high rpms at interstate speeds, I noticed a difference but it wasn't a huge difference. But once I locked it into 4lo, that's where they shined the most to me. It feels so much lower than it was before the 4.88's. It's awesome lol.
  13. Aug 1, 2016 at 1:40 PM
    Scribbles
    Scribbles Well-Known Member
    LoUiSiAna
    2010 SR5 PreRunner
    None yet
    Daaaang!
