What gears are u running?
Discussion in '4 Cylinder' started by dillonk1602, Feb 3, 2015.
  1. Feb 3, 2015 at 5:46 PM
    dillonk1602
    dillonk1602 [OP] Well-Known Member
    dillon
    san diego
    tacoma 5 lug
    Vehicle Modifications: TACOMA 2007 FRONT TOTAL CHAOS 5LUG ,LONG TRAVEL KIT 13" OF TRAVEL KING COIL OVER (550 POUND SPRING RATE) (18 INCH COIL) REAR BED CAGE 16" SMOOTH BODY FOX SHOCKS 2.5 2.0 / 2.5 BUMP STOPS FOX ICON ADD LEAF PACK WITH OEM SPRING 11" OF TRAVEL TRUCK COMES SPRING UNDER BY MANUFACTURE TOYOTA REGEAR TO 4.0 WITH AUBURN UNIT ENGINE 2TR-FE WITH AFE COLD AIR IN TAKE DOUG THORLEY HEADER MAGNAFLOW EXHAUST TIRE S NEW KO2 32/11.5 METHOD RIM 15" WITH -20MM OFF SET
    I got a 2007 5lug 2.7 I have 32 and can't decide on what gear s I want 4.10 or 4.30?
  2. Feb 3, 2015 at 5:54 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I have 3.58s right now, but I purchased a set of 4.30s from another TW member. You cannot get 4.30s from aftermarket companies (have to get lucky and find em on here or another recycle place), 4.10s should be pretty easy to find for a five lugger though and would certainly help run 32s but some may recommend even higher. I got the 4.30s to run 32s in the future.
