What gears are you running?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by woody6047, Oct 17, 2010.
  1. Oct 17, 2010 at 5:36 AM
    woody6047
    woody6047 [OP] McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    When i was on leave last time, i got some BFG 285's i feel like i lost alot of power and am kinda putting some strain on my rear end. I would like to know what some of you have re-geared to, and a good place to get some gears. Any input is appreciated on this, because i really dont know much about gears. Thanks guys
  2. Oct 17, 2010 at 7:00 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I'm still running stock gears with the same tires as you. However I do have a set of 4.10 gears that I picked up from a member on this board. The 4 bangers (4x4) came with 4.10 gears while our 6's came with 3.73. Due to your new tire size your truck acts as if it has some 3.50 gears. With the 4.10 it will make your truck act almost stock again.
    You have quite a bit more weight than I do, with the allpro and winch.
  3. Oct 17, 2010 at 7:10 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Yea man i honestly have no idea what my truck has back there. I know its not LSD or anything so im going to lock the rear soon. I did some research and found eastcoastgearsupply.com. What all needs to be replaced the carrier? Ring and pinon? Should i get this all together with the locker? Would 4.10 be a good size ya think? I saw somewhere about some 4.11's
  4. Oct 17, 2010 at 7:19 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I choose the 4.10 because it is a stock option for our trucks. If I'm not mistaken it is just a gear swap. I could be mistaken because I haven't done my swap yet. Being a 4x4 your truck has 3.73 gears. When you call to get the gears I would ask them what all needs to be swaped out also. There may be more envolved because you will be locking your rear at the same time I assume.
    I think the 4.10's would be fine if your like me and only do moderate wheeling. I drive on black top more often than Offroad thus the 4.10's make my truck act as if it were stock. If you want to step it up a notch you could go up to some 4.56 gears. These are just my thoughts and opinions. You could pm chris4x4 and he can give you better and more indepth info than myself.
  5. Oct 17, 2010 at 7:24 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Thanks i will. Yes my truck is mainly a DD. I just want it to drive stock again. When i call to get some quotes and info ill let you know.
  6. Oct 17, 2010 at 7:30 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    I just learned that eastcoastgearsupply.com will ship you a third member, locked and regeared. Then you remove the one in your truck and send it back to them as a core. I don't know about prices but that would make it easy on you.
  7. Oct 17, 2010 at 7:51 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    From what i read its 550 for the locked 3rd member and 400 if you dont have the diff out of your truck already.
  8. Oct 17, 2010 at 7:52 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Ill have to call and ask them about it. And im almost positive i have to do the front and rear at the same time. I dont know if i want the front locked as well though, heard some negative feedback on that.
  9. Oct 17, 2010 at 8:05 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    You could order the front and have it regeared, not locked or go with a selectable locker up front. Have your rear with a selectable locker and gears. I would assume that that is what they are reffering to when they say you have to do the front and rear at the same time (gears) as you would not be able to use 4wd if you had 4.10 in the rear and 3.73 in the front.
  10. Oct 17, 2010 at 8:29 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Thats what the winch is for [​IMG] haha but i wouldnt want to do anything half ass. Just got some information from Chris. So im going to call a few places tomorrow and when i get home i may go to a few local shops.
  11. Oct 19, 2010 at 12:51 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    So what i found out is 4.56 are probably the best bet. Im getting it from east coast gears. Im buying the rear 3rd member already locked for the rear and just the ring and pinion for the front. You can do one at a time but you better not put it in 4wd.
  12. Oct 19, 2010 at 12:53 AM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    I'm running 4.56s now.
  13. Oct 19, 2010 at 1:02 AM
    Matic
    Matic Locked and Lifted "02" DC TRD.
    Rich
    Greenville,sc
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    I'm running 4.56 with 33's. The gears are stock in my" 02" pre runner, Trd 4 banger. They seem to be a good combo for me with 50/50 on/off road. I know your 2nd gen and not sure of the weight differance but I think you will be happy with 4.56 gears.
    If you live in an area (when your home) where you get snow and ice, I would not opt for a full time locker in the rear.
  14. Oct 19, 2010 at 1:06 AM
    Matic
    Rich
    Greenville,sc
    Nm. I see your home is texas.
    I'm running a powertrax no slip full time locker.
  15. Oct 19, 2010 at 1:09 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    How do you like it compared to stock?
  16. Oct 19, 2010 at 1:09 AM
    chilidogrc
    chilidogrc Play stupid games, win stupid prizes
    Rodrigo
    San Diego
    2016 4Runner
    Are the 4.10 gears out of a stock 4cyl interchangeable with the v6's?
  17. Oct 19, 2010 at 1:10 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Yea not so much on the snow and ice down here in Texas, haha. Yea im debating on it. I dont really see where it would be a problem for me. I just really need to get locked because dog legging up these hills is killing me.
  18. Oct 19, 2010 at 1:11 AM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Freakin love it! Thank god i did it too! I have a 34 inch tire and I've gotten alot of power back and mpg. Since you have a 33 inch tire your going to be literally next to stock power and mpg. HUGE Difference imo.... Well worth the 1k I spent. Gears is gonna definitely my most favorite mod haha until I get my Relentless bumper.
  19. Oct 19, 2010 at 1:13 AM
    woody6047
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Nice, im glad to hear that. I was told its the best dollar for dollar mod you can do. And getting back the power and MPG i had at stock will be awesome! The RPMs dont run high at high speeds do they?
  20. Oct 19, 2010 at 1:17 AM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Mines running at 2300 to 2800. Thats not high is it? I could double check again tomorrow.
