what gears does my truck have?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Apr 28, 2010.
  1. Apr 28, 2010 at 9:01 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i have an 04 4X4 SR5 four cyl and i am just wondering what gears i have in my truck?
    'm going to upgrade from my 265/70's to 32x11.5 r15's this summer and just wondering if i will keep enough power to get around fine?
  2. Apr 28, 2010 at 9:56 PM
    Mr.Fahrenheit
    Mr.Fahrenheit Dennis = sinneD
    American Canyon, California
    01 Taco 3.4L 5spd TRD
    K&N CAI, HUSKY LINERS, LOW PRO TOOL BOX, GRAY WIRE MOD, OPTIMA RED TOP, GOODRIDGE STEEL BRAKE LINES, FAB TECH LIFT,
    THIS CHART IS FOR '95.5-04 MODELS ONLY!
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    A = 7.5" ring gear
    B = 8" ring gear
    Next two digits:
    01 = 3:42
    02 = 3:58
    03 = 4:10
    04 = 4:56
    05 = 3:15
    06 = 3:91
    07 = 4.30
    Last digit:
    A = 2 Pinion, Open
    B = 4 Pinion, Open
    C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.
  3. Apr 29, 2010 at 9:18 AM
    TacomaGus
    Gus
    Morgantown, WV
    i found that chart in another thread but i don't have my truck with me now so i was just wondering if someone else knew that had the same truck as mine
  4. Apr 29, 2010 at 9:33 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Manual or automatic?
  5. Apr 29, 2010 at 9:36 AM
    TacomaGus
    Gus
    Morgantown, WV
  6. Apr 29, 2010 at 9:37 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Moat likely 4.10
  7. Apr 29, 2010 at 9:48 AM
    TacomaGus
    Gus
    Morgantown, WV
    if thats what u have then most likely b/c we have the same truck u just have the V6
  8. Apr 29, 2010 at 10:02 AM
    EnolaGaia
    Midwest USA
    '01 & '04 S-Runners
    A 2004 3RZ XtraCab 4X4 manual (non-TRD) should have a 3.91 final gear ratio.
  9. Apr 29, 2010 at 10:31 AM
    TacomaGus
    Gus
    Morgantown, WV
    so if i put 32's on it would i still be ok? as of now my speedometer says i'm going faster than what i really am with the 265/70's on. It has to be around 69 on the speedo for me to be actually going 65
  10. Apr 29, 2010 at 11:51 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    32's should just about perfectly correct your speedo. And yes, I have 4.10's
  11. Apr 29, 2010 at 1:18 PM
    TacomaGus
    Gus
    Morgantown, WV
    i was debating going with 33x10.5's but i figure that would kill my power and mileage so i'm going with the 32's
  12. Apr 29, 2010 at 4:55 PM
    derekp
    derekp giddy up!
    Derek
    Grand Forks, ND
    2001 X-Cab 4x4 TRD V6 5Spd
    Deck plate, Flowmaster Delta-Flow 40 series, 265/75-16 Wrangler TDs, more to come...
    I understand the lower the ratio the better the fuel economy; the higher the ratio the better for towing (or something similar). What do the other two gears do? I have a code B03A (2001 V-6 TRD 5spd).
