What grade of fuel do you use?
Discussion in '1st Gen. Tacomas (1995-2004)' started by agrant2312, Mar 1, 2012.
  1. Mar 1, 2012 at 6:49 AM
    agrant2312
    agrant2312 [OP] Well-Known Member
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Intake, Flowmaster Exhaust
    I usually run premium and sometimes I feel like my gas mileage is worse. What do you guys use and what's your mpg usually like?
  2. Mar 1, 2012 at 6:50 AM
    resq330
    resq330 El' Capi-Tan
    Josh
    VA
    13 MGM DCSB TRD-Sport
    K&N Drop-In, Dick Cepek 'Torque' Wheels, Wet Okole Seat Covers, LED Interior
    I always run regular 87...My mpg isn't great. Usually around 250-260 miles on one tank.
  3. Mar 1, 2012 at 11:37 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I am mixing every other fill up 87 reg and 89 ethanol, just to see if my mileage slips, summer in town no highway 17.6.
  4. Mar 1, 2012 at 11:43 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    I always run premium......truck and car like it better,and its not that much more on a fill up. Mileage is good with it as well.
  5. Mar 1, 2012 at 12:33 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I run whatever is cheapest. I don't notice a difference between them.
  6. Mar 1, 2012 at 2:04 PM
    Wild Card
    Wild Card Truck yeah!
    Doug
    Portland, MI
    02 TRD SR5 4x4 V6 Xtra Cab 5spd
    6" Deckplate. Trimmed TB gasket. Grey wire. Disable DRL's.
    Virgin goat blood?
  7. Mar 1, 2012 at 2:09 PM
    medic2230
    Murph
    Bama! Roll Tide
    I run 87. Truck only has 3200 miles on it but it's getting there. 18.2 last fill up.
  8. Mar 1, 2012 at 2:20 PM
    Graham
    Graham Pay it Forward
    Western New York
    2005 4x4 TRD Black V6 6 speed manual
    I run 87
  9. Mar 1, 2012 at 2:24 PM
    BVCOTaco
    BVCOTaco Well-Known Member
    BV, CO
    02 Xtra Cab SR5 TRD
    ARB Bullbar
    I run 85, except this last tank I ran 87 because I grabbed the wrong pump!
  10. Mar 1, 2012 at 6:04 PM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I run the cheapest possible which is normally 87 I think. I get like 350-400 miles per tank.
  11. Mar 1, 2012 at 6:47 PM
    Madjik_Man
    Colorado Front Range
    copypasta
  12. Mar 1, 2012 at 8:55 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    If the engine doesn't require 91, then running 91 is not going to benefit.
    Ethanol has a raw octane rating of around 118... but it's BTU content (actual power) is only around 75% that of gasoline (meaning worse fuel economy).
    But ethanol is cheap... and it is often used as an octane booster.
    Today's 91 is not the same as the "premium" of 35 years ago.
    IF... and only if... your engine is on the edge of pinging on 87 (or 85), then running 89/91 might improve mileage slightly because under load, the computer will be able to maintain more spark advance.
  13. Mar 1, 2012 at 9:00 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Manual says 87 for the truck, so thats what I run.
    Bike is high compression so it gets 91+ like the manual says.
  14. Mar 1, 2012 at 9:03 PM
    rbeezy
    rbeezy Well-Known Member
    Ron
    Bay Area
    2011 Tacoma SR5
    x2!!
  15. Mar 1, 2012 at 9:11 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    I don't always fill up my tank,
    But when I do, I prefer gas.
    I haven't noticed any difference in fuel economy from one to the other. So 87 is what I normally run. 91 at shell with the nitrogen fuel boost rocket powder additive. (not sure that's the technical term)
  16. Mar 1, 2012 at 9:11 PM
    4x4jeep
    4x4jeep Well-Known Member
    Kyle
    Destin FL.
    I run water
  17. Mar 1, 2012 at 9:12 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    I use premium now cause really it's only about $4 more each time u fill up
  18. Mar 1, 2012 at 10:08 PM
    Afraz
    Afraz Well-Known Member
    Toronto
    03 Double Cab TRD
    Projector H.I.D
    I use regular 87, but every 5 or so fill ups put in SHell V Power. I find with the higher octane i get better mileage overall, but not a significant improvement in performance.
  19. Mar 5, 2012 at 5:29 PM
    t3hWIT
    t3hWIT Well-Known Member
    Wit
    Central PA or wherever the wind blows me
    Rusty '98 Tacoma
    My 3.4 ticks, so I run 89 to cut down on it. Premium if I'm hauling in a hilly area.
  20. Mar 7, 2012 at 5:19 AM
    Air_Ops
    Air_Ops Active Member
    Peter
    N.W. VT
    01 Ltd Dbl Cab
    TRD Headers, Cat Back Exhaust, Airaid Intake Tube, LC Engineering Throttle Body Gasket, Bilstein 5100 Series Shocks, Wheeler's Add-A-Leaf, LC Engineering Tundra Brake Kit, Re-Framed
    Switched to premium, previously used mid-grade 89 from new in 2001. Truck would do a double down shift on the steep grades. After switching to the premium the truck downshifts a lot less and even wants to up shift on the hills, proof enough for me that it makes a difference. Fuel mileage wise not a big difference but drivability improvement was huge. The 3.4 has 9.6:1 compression, with regular (87) or mid-grade (89) the knock sensors will cause the computer to dial back the performance back to compensate for the lower grade fuel. Toyota is not going to tell you that the truck needs a higher grade because it may effect your purchase decision. Made the switch after I got the truck back from the frame recall, and I had a set of TRD headers and an Airrad intake tube installed. The truck now drives like I always thought it should.
    MainerDave19995VZ likes this.
