What grade of fuel do you use?
Discussion in '1st Gen. Tacomas (1995-2004)' started by agrant2312, Mar 1, 2012.
  1. Mar 7, 2012 at 8:00 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
    There's a difference between a manufacturer recommending 87, vs saying you CAN run 87, but suggests 91+
    On some cars, going above 87 will give you absolutely nothing, whereas on others like ours, it does make a difference. I only run premium.
  2. Mar 8, 2012 at 2:00 AM
    01TacoBuz
    01TacoBuz Well-Known Member
    In the woods
    01 Tacoma SR5
    K&N drop in filter, URD rear simulator, Deck plate mod/home made CAI, No rear cat, MagnaFlow muffler
    Been running 87 forever, every now and then I may run a tank with an additive through it
  3. Mar 8, 2012 at 6:24 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    I fill lowest grade unless it calls for premium. My taco isn't a high comp race car so no need for premium. No problems after 180k.
    Now my other cars with 10:1+ i use premium for sure
  4. Mar 8, 2012 at 12:00 PM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I actually got better MPG running the lower octane than 93 premium. I was shocked.
  5. Mar 8, 2012 at 3:57 PM
    Stew
    Stew Well-Known Member
    Stew
    Greenville, NC
    White 04 Single Cab 2.7 4x4
    2.5in ^, debadged, fog light mod, deck plate, line-x, tool box
    +1
    Higher octane requires more spark to ignite, we don't have specialized engines which require/accept higher octane so there are no benefits of using it. I've done a lot of gas research lately, on many sites and that is the consensus. If you want to do something good for your motor www.pure-gas.org fill up with pure gas(most is ethanol blend of some level) and see if that helps your fuel economy/how your motor runs. Remember that driving technique and conditions are also very important relevant factors(flooring it, hauling/weight, temp, weather, amount of time sitting still in traffic)and one tank is not enough for statistically relevant data so run a few tanks of pure then compare it to a few tanks of something else(all the same grade). I'm in the process of running only from a pure gas station and so far I am very happy with the results( 3 weeks).
  6. Mar 8, 2012 at 4:41 PM
    Adam Baum
    Adam Baum Well-Known Member
    PCS
    01 PreRunner SR5 debadged
    87 because I experienced no benefit after 6 months of premium. 140,000 miles and the only thing that changed my MPG was switching from the stock Dueler 265/70/16 to really crappy Firestone Destination LE 265/75/16. Went from 300 per tank to 260 if I'm lucky. Oh...and these are supposedly highway tires. Will never buy them again.
