What happened after my coil swap?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dentpusha, Apr 26, 2017.
  1. Apr 26, 2017 at 1:28 PM
    dentpusha
    dentpusha [OP] Well-Known Member
    TEXAS
    16 ORAC
    I had a shop pull my king coils off my truck the other day and when they got done I ended up with a abs light on. The cruise control and 4wd are also not functioning. Any ideas on what could have happened? I see no damage to wires and saw no blown fuses. Any info would be appreciated.
  2. Apr 26, 2017 at 1:32 PM
    phillstill
    phillstill Long hair don't care
    Phill
    Tulsa
    LT35TANK
    Everything
    I would check the sensors on the side of your spindles. Make sure they are plugged in correctly.
  3. Apr 26, 2017 at 1:40 PM
    dentpusha
    TEXAS
    16 ORAC
    I'll look again but that was first thing I checked and they were tight and in good shape.
  4. Apr 26, 2017 at 2:05 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    Call the shop. They might know if they did anything.
  5. Apr 26, 2017 at 2:10 PM
    dentpusha
    TEXAS
    16 ORAC
    He was trying to scan it when I showed up but I was in a hurry and told him id bring it back. At the time it was only abs/traction light but I soon realized I had no cruise control or 4x4. I'm taking it back soon for him to check it out but I figured I'd check around and see if it was something common or a simple fix.
    nDub[QUOTED] likes this.
  6. Apr 26, 2017 at 2:12 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Might have stretched one of the sensor wires and broke the conductor inside of it.
    Hiluxski, 12TRDTacoma and 1bad2k like this.
  7. Apr 26, 2017 at 2:16 PM
    phillstill
    Phill
    Tulsa
    LT35TANK
    Everything
    This is what I'm thinking. ^^^
  8. Apr 26, 2017 at 2:46 PM
    dentpusha
    TEXAS
    16 ORAC
    I'm guessing this is probably what's going on because it's the only wire near the coils.
    Hiluxski and adanfon[QUOTED] like this.
  9. Apr 26, 2017 at 3:21 PM
    adanfon
    adanfon YNWA
    Adán
    Hanford, CA
    '11 Tacoma DCLB 4x4
    Same thing happened on my uncles tundra. He fixed it himself, even though I told him he should take it back. The shop should replace it.
    dentpusha[QUOTED][OP] likes this.
  10. Apr 26, 2017 at 4:50 PM
    Omar RVA
    Omar RVA Well-Known Member
    Omar
    OR
    2020 Ram 2500 Power Wagon; 2019 Land Cruiser
    I don't have much experience with lifting Tacomas, but in the 4Runner world that screams of the ABS sensor wire. It's already been stated above, but those sensor wires become brittle and kinked and can easily be damaged during suspension work (stretching them too much is enough). A Toyota diagnostic device would be able to tell you which specific wire; it's a relatively simple fix if you DIY and buy the part (edit: and have the shop pay).
    http://parts.toyotaofdallas.com/aut...5l-v6-gas-engine/brakes-cat/front-brakes-scat
    (part 14 in the diagram - side specific)
    OA
