What Happens Exactly With No Differential Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rondoggnuts, Jun 9, 2013.
Thread Status:
Not open for further replies.
  1. Jun 9, 2013 at 5:17 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Cheesy hahaha
  2. Jun 9, 2013 at 6:18 PM
    rondoggnuts
    rondoggnuts [OP] Member
    San Diego
    08 TRD Sport D-Cab L-Bed
    Bone stock
    OMFG! I guess the guy in the vid had severely impaired hearing? Either that, or he let his GF drive, lol ;-) Thanks for the link, Mr. Albertos delivery driver.
    To Porno with a 4th X, I had no idea there was a front differential (and yes, it's an 08' Sport). I was under the impression there may be a transfer case, but I never messed with it (very low miles logged). But the rear diff. was changed to M1 75w-90 LS, at about 7,000 miles on the odometer.
    To the very wealthy guy, I take it they call you Max? Thanks for the clarity, but it seems to me that extensive damage should never occur, for anyone conscientious (I think the word someone used?), at least.
    To the guy who apparently treats medical conditions (the TX?) with tacos (the food?), you said the "LS" in M1 is NOT suitable for LSD's? That's precisely what I put in at 6-7k mi, but I'm utterly ignorant at detecting any problems. Likewise, I've used Amsoil Severe Gear 75w-90, in non Tacomas, but rather, in 2 RWD sedans. Neither logged many miles yet (maybe 15k or so), so I can't really attest to anything, besides the fact that at least 1 sedan (mine) SEEMED fine for about 35k mi (i.e. I ran RP Synchromesh from 25k to 60k (the current mileage), and never noticed anything that worried me, just the symptoms that everyone at the table brings up, so I look to obviously have a monster, LOL. Poker is $hit, because it assures that I will go home with an empty wallet. C'est la vie. Boohoo...
  3. Jun 9, 2013 at 6:24 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    The other function of diff oil is to act as a heat sink. The hypoid gears used in 90-deg differentials cause about 11-13% frictional loss. So if your truck is using 100 hp to move along, then 11-13 hp (9000 W) worth of heat needs to be dissipated through the oil. No oil - gear teeth overheat, soften, then break.
  4. Jun 9, 2013 at 6:29 PM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    It may just be me, but why does it seem weird that someone would set up a video camera under their truck, then proceed to intentionally grenade their differential (or transmission, it's hard to tell what is being destroyed)??
  5. Jun 9, 2013 at 6:35 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Cause there:crazy:
  6. Jun 9, 2013 at 6:48 PM
    rondoggnuts
    San Diego
    Bone stock
    Thanks for bringing a good point, something I've contemplated plenty before. In other words, I arrived at the conclusion that just about every oil in modern cars supports that hypothesis, no? Wait, nevermind, please ignore my idiotic posts. I'm happy with merely knowing that the water in our engine cooling system dissipates heat, so long as the water pump is working, lol. Beyond that, my brain will surely explode. As such, dozens of people will know you're guilty of murder. ;-)
  7. Jun 9, 2013 at 7:08 PM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Just hearing that makes my asshole pucker
  8. Jun 9, 2013 at 7:14 PM
    KenLyns
    Belly of the Beast
    Yes. Coolant cools the outside of cylinders (hence water jacket). Engine oil cools the inside of pistons. The older 993-era Porsche 911s weren't really air-cooled; they were oil-cooled. :)
  9. Jun 9, 2013 at 10:01 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    This is incorrect.
    The wheel bearings are sealed from the axle tube and gear oil and run in grease.
    These axles do not use a c-clip to retain the shaft. The only way the wheel will fall off is if that shaft fails AT the bearing. Or the bearing fails catastrophically.
  10. Jun 9, 2013 at 10:06 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I won't say all (of the ones marked LSD compatible) but I know that M1 and Valvoline both include friction modifier. You may need more, and it should be real apparent if you do. YMMV.
  11. Jun 9, 2013 at 10:09 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Heh, if you mean me, I do wonder how you concluded I was very wealthy, hah! Must be my support for guns, liquor, and whores, huh? I wish I were but I'm not. :p Regardless, yes, I agree for anyone who pays attention you should never have this problem. Sadly some don't! :bananadead:
  12. Jun 9, 2013 at 10:28 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    My dad was a mechanic and one of his tools was a 4 inch or so long magnet...once the oil is drained swirl the magnet around the bottom of the pan. Check for debris.
  13. Jun 10, 2013 at 6:40 AM
    BamaToy1997
    Bill
    Navarre, FL
    Janster only said it was a friend with a old pickup. She didn't mention if it was a Toyota, or perhaps a Chevy, that does have a c-clip system in the rear diff. I was going by the belief that she was talking about the latter myself. Perhaps I am wrong. Not sure until she comes back.
  14. Jun 10, 2013 at 7:05 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The first thing that will happen you'll burn up the ring and pinion and it will howl like a cat. If you have a diff that acts fine and you find bits of metal you can do two things, panic or forget it they all have little bits of metal in them particularly on the first drain.
  15. Jun 10, 2013 at 7:13 AM
    #35
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    It was an old Ford. So, in that situation...yes, he had a C clip and the oil lubricates the bearings.
    I had always assumed that gear oil lubricates the bearings - but perhaps that's old school based on the rigs I've worked on. I didn't realize toyota used sealed bearings. Learn something new everyday!! ;)
  16. Jun 10, 2013 at 7:43 AM
    #36
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    I have been behind an F250 on the highway and saw what I thought was
    water dripping down the back. They took the same exit I was taking and
    when off ramp at a light, saw clearer that the pumpkin had just grenaded
    and was pissing oil on the pavement. bro-tato kept driving along and I
    got alongside at the next light, and motion to roll down window and I said
    'did ja know your rear end was blown ?' ...got an 'Eh ?' and they drove off
    it sounded like a brick in a washing machine...I didn't hang out but i bet
    they got maybe one mile further before they were forced to use 4wd as FWD.
    it literally was pissing fluid on the road for a good 2 miles
  17. Jun 10, 2013 at 9:07 AM
    #37
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Which is fine but I didn't want anyone to confuse your anecdote for something that might happen in their Tacoma.
    That is a bit "old school" and something you don't see too often anymore.
  18. Jun 10, 2013 at 10:31 AM
    #38
    BamaToy1997
    Bill
    Navarre, FL
    Today's Chevrolet 1/2 ton truck axles still use c-clip axle shafts, and their axle bearings are lubricated by the differential oil. So it is still pretty common. Not my favorite axle system for durability and strength, but they sure are easy as heck to work on!
  19. Jun 10, 2013 at 10:43 AM
    #39
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    They were probably convinced you were Charlie Sheen.
  20. Jun 10, 2013 at 4:45 PM
    #40
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Yeah bearing goes bad you get to replace the axle too while it's all apart.
Thread Status:
