what happens if u turn on engine while pumping gas into tank?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoManTaco, Jan 28, 2019.
Thread Status:
Not open for further replies.
  1. Jan 28, 2019 at 12:47 PM
    #41
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    The release of Static Electricity is a very high probability at the pumps at a gas station and doesn't take much to ignite fuel vapors !!!!
    r1200gs4ok likes this.
  2. Jan 28, 2019 at 12:49 PM
    #42
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    True, still what is the ignition source?
    Spark plugs are at top of motor, fuel vapors pool at the ground .
    There is no risk.
  3. Jan 28, 2019 at 12:50 PM
    #43
    Rome604
    Rome604 I am the Captain now
    Dave
    Alexandria, VA
    2023 TRD Pro Sequoia
  4. Jan 28, 2019 at 12:50 PM
    #44
    shadyfist1511
    shadyfist1511 Well-Known Member
    DANIEL
    2016 TACOMA TRD OFF ROAD 2WD
    oh fuck!!!!
  5. Jan 28, 2019 at 12:51 PM
    #45
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Mid-Overland 3rd Gen refueling?... :burnrubber:
    ninernation likes this.
  6. Jan 28, 2019 at 12:52 PM
    #46
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    You sir my corner the market on this venture
    Paul631[QUOTED] likes this.
  7. Jan 28, 2019 at 12:53 PM
    #47
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Getting in and out of your vehicle is enough to create a static charge . This is why it's recommended to touch a metal part of your vehicle to release this charge prior to fueling
    I've seen and witnessed a fuel flash fire from this !!!
    Just last week I saw a lady behind me do this ( getting in and out of her car during fueling) and I yelled at her not to be so F'n stupid
  8. Jan 28, 2019 at 12:58 PM
    #48
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    static electricity is like a match......it has electrical charges that are the ignition source.....spark plugs get electrical charge from the ignition coil......if one of those coil wires is cracked or has exposed wire it could short out which combined with gas fumes will ignite......so you hypothesis is all wrong. vapors tend to rise upward
    cosmicfires and US Marine like this.
  9. Jan 28, 2019 at 1:04 PM
    #49
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Back in the day of carbureted engines, chances of throwing sparks from a backfire were much higher than they are now.
    Nowadays, as others have said, it's static buildup. A vehicle with a loose ground wire (could be age, could be from a bad subwoofer install) has a higher chance of static discharge when the engine is running. Think balloon on head, but with motor mounts on frame. Add that to gas fumes on a dry day, and whumph...
    US Marine likes this.
  10. Jan 28, 2019 at 1:06 PM
    #50
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Another stupid thing I see at gas stations is people filling up those ABS plastic 5 gal fuel containers in the bed of a p/up . They're supposed to take them out of the p/up bed and place them on the ground prior to refueling
    r1200gs4ok, Jester243 and Paul631 like this.
  11. Jan 28, 2019 at 1:09 PM
    #51
    ripcalifornia
    ripcalifornia Trok
    Cal (Kyle)
    HB CA
    2014 AC
    patches
    You either die or survive long enough to harness the power of the engine and the gas pump simultaneously effectively becoming an all-powerful immortal diety
    cruxofthebisquit and stun gun like this.
  12. Jan 28, 2019 at 1:19 PM
    #52
    Hstone556
    Hstone556 Ain’ters gonna ain’t
    Hunter
    Austin
    2019 Ram 2500 Laramie
    Raceline 17" Gauge's 37x12.50 Toyo's RT, Carli King 2.5s
    The government says this is only recommended when you have a plastic or carpeted bed liner. :notsure:
    US Marine[QUOTED] likes this.
  13. Jan 28, 2019 at 1:20 PM
    #53
    beers@1600
    beers@1600 Well-Known Member
    North Carolina (some of the time)
    2017 TRD OR DCSB MT 4x4 MGM
    Now I can't confirm this, but I did read that in California it has been known to cause cancer.
    stun gun likes this.
  14. Jan 28, 2019 at 1:28 PM
    #54
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    What he said ^
  15. Jan 28, 2019 at 1:30 PM
    #55
    lynlan1819
    Tacoma
    Lifted
    From a LARGE FIRE.
  16. Jan 28, 2019 at 1:31 PM
    #56
    melikeymy beer
    melikeymy beer Hold my beer and watch this
    2019 Tundra
  17. Jan 28, 2019 at 1:31 PM
    #57
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Yes with bed liners or carpet and have seen them ignite and subsequent flash fire from static Electricity while refueling in the bed of a p/up
  18. Jan 28, 2019 at 1:34 PM
    #58
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    This is the 2nd time I’ve seen this thread on this forum. Judging by the last one, it could get fun.
  19. Jan 28, 2019 at 1:40 PM
    #59
    NM Lance
    NM Lance Well-Known Member
    Not the best idea, but I do it occasionally. Allegedly the fumes can get sucked into the intake causing a backfire (not afterfire). No biggie with a diesel, probably not the best idea with gasoline.
Thread Status:
