What happens when I turn switch to 4WD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joe54tacoma, Feb 13, 2012.
  1. Feb 13, 2012 at 8:41 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    well that's just South Carolina for you. :p
    :stirthepot:
  2. Feb 13, 2012 at 8:45 AM
    pancho
    pancho Go home Nubbs, street lights are off!
    Pancho
    Southern California
    18 Cement OR 4x4 DCSB
    Black out emblems. TRD Pro grille.
    You sir drank tiger blood. Winner!
  3. Feb 13, 2012 at 8:47 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    1. 4wd ECU gets input from 4wd switch telling it to go to 4wd mode (blinking 4hi light goes on)
    2. 4wd ECU sends power input to the motor ADD on front axle. its momentary so motor turns and then switches off when reaches max position . this is to constantly put pressure on the spring.
    3. Once splines align and ring locks front axle. Position switch in ADD tells 4wd ECU that front engaged.
    4. 4WD ECU now activates 4wd motor in transfer case. its momentary so motor turns to put the tension on the spring to move fork inside the transfer case.
    5. Once splines lined up 4wd gear moves into the 4wd position. 4wd switch tells ECU that 4wd engaged (4hi light goes solid)
    ...or something along the lines ;)
  4. Feb 13, 2012 at 8:52 AM
    joe54tacoma
    joe54tacoma [OP] Joe in Indiana
    Joe
    New Albany Indiana
    2012 DOUBLE CAB TRD Sport
    Thanks BlueT!
    I'm a Mechanical Engineer by trade & I like to envision what takes place.
    It also helps to know when you have trouble.
  5. Feb 13, 2012 at 8:59 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    and you just came up with that on the spot? that was pure genius. you have captured all that is off roading!!! :bowdown:
  6. Feb 13, 2012 at 9:05 AM
    BlueT
    NorthEast
    I hear ya. I dont like magical things either so spend time to learn.
    Key items to remember is none of the motors are directly connected. Rather they expect spring tension to do the work. ECU expects input from switches on ADD and transfer case to tell it when either is in lock or unlock position.
    Going off the 4wd is pretty much reverse order 5 ....1
    4L only pushes fork into extra position but it does not touch front axle.
  7. Feb 13, 2012 at 9:08 AM
    greenguy3
    greenguy3 BOOM goes the dynamite!
    Ian
    Arkansas
    Dirty A$$ TRD
    Mud and dirt
    You sir are a man among men!
  8. Feb 13, 2012 at 9:28 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :rofl: The word Genius comes to mind when reading this! +1
  9. Feb 13, 2012 at 9:53 AM
    rolltyd
    rolltyd Well-Known Member
    Jay
    Overland Park, Kansas
    2013 Off Road 4x4 Hankook Dynapro ATM
    That was awesome
  10. Feb 13, 2012 at 10:53 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    its too bad it took 25 posts for him to get a real answer though. theres a lot of wasted space here lately. can we not stay on topic?
    bluet youre the man !
  11. Feb 13, 2012 at 10:56 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    :rolleyes:
  12. Feb 13, 2012 at 11:01 AM
    BlueT
    NorthEast
    :thumbsup:
    My pleasure. I figured man deserves real answer. I am assuming once ATRAC gets mentioned we will reach 20 pages in no time :D
    ooops I did it again
  13. Feb 13, 2012 at 11:06 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    At least it was positive good natured wasted space instead of nasty comments we see so often.
  14. Feb 13, 2012 at 11:08 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    2021 GMC Sierra 1500 AT4 (Prev 09 Access Cab V6 4X4)
    Starting over with a new GMC AT4 Satin Steel Metallic Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Falken Wildpeak AT3W, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings.
    I don't know what you're talking about. Every time I "turn switch to 4WD" that happens. If it doesn't for you ... you're pushing the wrong button.
  15. Feb 13, 2012 at 1:07 PM
    #35
    fixer5000
    massachusetts
    ok you got me there lol
  16. Feb 13, 2012 at 1:58 PM
    #36
    Namyo
    Namyo -
  17. Feb 13, 2012 at 2:03 PM
    #37
    PreRunner03
    PreRunner03 Hail State
    03 PreRunner Double Cab TRD
    You sir are quite correct! :thumbsup:
  18. Feb 13, 2012 at 2:58 PM
    #38
    fixer5000
    massachusetts
    theres a fact. second one in this thread
  19. Feb 13, 2012 at 3:00 PM
    #39
    BlueT
    NorthEast
    Would be nice though if people kept offtopic to minimum you know or at least allowed answer at the beginning.
    Litteraly when you read a lot of topics it seems people are so into the mods and dont get laid or something. :D
  20. Feb 13, 2012 at 3:08 PM
    #40
    Fightnfire
    Marysville, WA
    :yawn:
