What happens when I turn switch to 4WD?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joe54tacoma, Feb 13, 2012.
  1. Feb 13, 2012 at 4:03 PM
    #41
    PreRunner03
    PreRunner03 Hail State
    03 PreRunner Double Cab TRD
    That was actually kinda clever...
  2. Feb 13, 2012 at 4:32 PM
    #42
    TacoDawgs
    TacoDawgs Well-Known Member
    2008 Radiant Red DCSB TRD OR 4x4
    Front 5100s at 1.75. Rear TSB. LoRider tonneau cover. OEM bed mat. OEM bug deflector. Illuminated 4x4 switch. In cab AC outlets. 400W anytime. EGR in channel window visors. Black badges. Rear weathertech liners.
    Since the OPs question has been answered I'm going to thread jack a little...though it's on the same lines. Why does Toyota's turn knob 4wd system not lock in immediately? At work I have a 2002 F150 with the 4wd shifter in the floor. I can be at a complete stand still stuck in mud and shift to 4wd and it locks immediately. It seems with the Tacoma the truck has to be moving for my 4wd to lock in. I've tried to shift when at a complete stand still (not stuck in mud just in case it didn't lock) and all that would happen is the 4x4 light would blink. But as soon as I started moving it locked in. I know you are supposed to prepare and shift to 4x4 BEFORE trouble sets in. But it seems Toyotas system needs to be perfected to lock in immediately. Is this a Tacoma thing, an issue with my truck, or something that will work better in the future with more use of the 4wd system? Thanks.
  3. Feb 13, 2012 at 4:37 PM
    #43
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    +1 for being the only person to give him an actual answer
  4. Feb 13, 2012 at 5:20 PM
    #44
    bluedust
    bluedust Well-Known Member
    Patrick
    Pittsburgh
    '12, Access, TRD, Off Road, ,
    Wet Okole Seat Covers, Charcoal & Black "TRD" stiching Stuby Ant., Husky Mud Guards WeatherTech Floor liners
    I could use four inches
  5. Feb 13, 2012 at 5:35 PM
    #45
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    With the floor shifter you do not have a little electric motor locking it into 4X4.That little motor is not as fast as your direct link of the floor shifer.The F150s with the electric 4X4 lock up is just like the Tacomas or at least the 2011 F150 I had was that way.
  6. Feb 13, 2012 at 5:46 PM
    #46
    TacoDawgs
    Why did manufacturers go away from that design then if it seems to work better (i.e. lock in immediately)? Usually designers update vehicles with new electronics and motors to increase functionality and update an outdated system. In this case, it seems to have the opposite effect. Takes longer to lock in, thus a less effective system than previous ones. JMO.
  7. Feb 13, 2012 at 5:46 PM
    #47
    joes06tacoma
    Joe
    Central Coast, CA
    I believe the transfercase shifts first, then the ADD.
    If you visualize what's happening in 2WD: one wheel is connected to the diff, the other side is disconnected. The side that is connected spins the spider gears in the diff. If you visualize how that works, you'll realize that the disconnected axle shaft stub coming out of the diff is actually spinning in reverse direction from the second half of the axle shaft on that side. So, it can't shift first. The driveshaft is stationary until the transfercase shifts. The syncro inside the transfercase brings the front driveshaft up to road speed and the differential carrier spins up to road speed. As this is happening, the spider gears cease spinning, and all the axle shafts inside the front diff assembly spin the correct direction. Only then can the ADD shift successfully.
  8. Feb 13, 2012 at 6:40 PM
    #48
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Couldn't have said it any better!
  9. Feb 14, 2012 at 12:25 AM
    #49
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    Sir, u have just gained REP +1:woot:
  10. Feb 14, 2012 at 2:38 AM
    #50
    Enzo
    Enzo Well-Known Member
    Opie
    Bedford, Va
    2012 FJ Cruiser
    2012 FJ Cruiser Maggiolina Medium Grand Tour w/winter hood National Luna dual battery split charging system ABR Sidewinder Aux battery tray ARB 50qt Fridge w/Transit Bag Bajarack flat rack w/ladder Crawlarado flat black hood blackout TRD exhaust Trasharoo Outback FJ roof console
    Most people that buy a 4wd these days either never use 4wd or wouldn't know how to use the manual shift. Also not everyone uses their truck to go mud bogging either and couldn't care less about how long it takes for 4wd to engage. Toyota was one of the last few company's to still use the manual lever. You can still get the manual 4wd shifter in the TE 4Runner and FJ Cruiser.
  11. Feb 14, 2012 at 2:46 AM
    #51
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    You must be new here
    This is not a new phenomena, nor will it ever be stopped
    Taking a thread deep into the magical offtopic pixie dust land is the way of Tacomaworld
  12. Feb 14, 2012 at 5:35 AM
    #52
    WV150
    South Carolina
    To make it more car like I guess and for those who want everything simple without having to think for theirself.I prefer the floor shifter but just try to find a modern truck with it.A super duty Ford is the only ones I know of that still uses locking hubs.Future trucks may not even have a knob to turn.That would require too much effort and thought.A simple voice cammand will take care of it.
  13. Feb 14, 2012 at 6:01 AM
    #53
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  14. Feb 14, 2012 at 6:06 AM
    #54
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    I don't even care about the content, but points for turning that phrase correctly!
    "I could care less." Well, it doesn't bother you much does it? :D There is hope for society.
  15. Feb 14, 2012 at 6:16 AM
    #55
    kroving
    kroving Well-Known Member
    Ken
    Duluth, MN
    07 DCSB 4X4
    Cooper Discover AT3 4S Yokohama Geolander ATS
    Thanks, I just choked on my coffee laughing. I could of drowned... :rofl:
  16. Feb 14, 2012 at 6:39 AM
    #56
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I can't tell you how many times I've had to sit and wrestle with a floor shifter to get a truck in 4wd. The new switch, for my use, is much easier. I wouldn't mind having the manual hubs again because it would mean I can have 2Lo (and avoid the ADD actuator problems a lot of people seem to have) but other than that, I'm fine with the newer systems. If Toyota had kept the old floor shifter, they would be left behind their competition since everyone else these days has either a push button, a switch or an AWD option.
  17. Feb 14, 2012 at 6:43 AM
    #57
    98tacoma27
    Ben
    Not Beech Creek
    Saves $$$$
  18. Feb 14, 2012 at 7:01 AM
    #58
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    I bought this truck and I've never used 4wd and STILL haven't. I plan to learn soon when I go out with my friends at the end of the month. It had a great price on it and was less expensive than one that was without and one year newer. Yes, I may be an idiot for not knowing how to operate 4wd but I figured I got a better deal than the guy that bought the other one, considering they were both brand new.
    I also bought a motorcycle having only ridden a mini bike before. I had no problem adjusting to the size difference as long as I switched to a Corbin seat. From a lawn mower engine to an 1100 was only a matter of learning never to drop it and to leaaaaan and counter steer as much as my arms and legs would allow.
    Call me an idiot but one thing is for sure. I'm constantly learning rather than sitting back and saying "Oh gee, I better not, I don't know what to do..."
  19. Feb 14, 2012 at 7:03 AM
    #59
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Solution to this is different transfer case. My wifes truck has option for AWD 4L which means it can be driven on pavement in 4L mode. So plenty of torque to wheels and no binding. I had been trying to get my 4runner case for long time and so far had no luck :D
  20. Feb 14, 2012 at 7:10 AM
    #60
    Pugga
    Massachusetts
    A very expensive solution! I want 2Lo for maneuvering trailers around, it seems like the reverse gear isn't very low and has some trouble backing heavy trailer up hills. I'm not going to drop in a new transfer case just for that purpose. Someone did a write up on how to put a switch on the ADD actuator so you can put your truck in 4Lo but the front end won't 'lock' if you will. That's a much more cost effective solution in my opinion.
