What happens when you overheat your car
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ziggylife420, May 31, 2020.
  1. Jun 4, 2020 at 10:31 AM
    #41
    Taco Wake
    Taco Wake Well-Known Member
    South Carolina
    Car Part (www.car-part.com) is a website that searches junkyards. Looks like there are several good options in Tennessee for the 2.7, running $2500 to $2700 for "A" grade engines with 60k miles or so.
  2. Jun 4, 2020 at 10:49 AM
    #42
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    damn. $12k? are you at the toyota dealership service department?
  3. Jun 4, 2020 at 10:56 AM
    #43
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Its not necessarily junk. Repair the fitting and see how it runs. I'm not saying there's no damage. But if it starts/runs, drive it till wont run any more. Save your $12000. Worst case, head gasket blows sometime down the road. Which is not in itself catastrophic either.
    Put in new oil and antifreeze. Turn it over. If it starts, great, nothing is warped enough to interfere. Then if it doesn't blow white or blue smoke out the tail pipe, you're golden. White means water is getting into cylinders, blue'ish means oil is.
  4. Jun 4, 2020 at 12:52 PM
    #44
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    I would stay away from Jasper, I've heard a lot of bad things on them in recent years. I think in this case (if the truck in question were mine) I would go with a good Junkyard 2.7 over a rebuilt/remanufactured engine. In general these engines don’t give much trouble for hundreds of thousands of miles and I think a factory built 2.7 will have better quality and longevity than a rebuilt engine. I also suspect that a used engine will be significantly cheaper than a reman. If you go with a used engine, I would pull a valve cover (or look down the oil fill tube, not sure what you can see on a 2.7 from there) before you install it and inspect. If all looks good and it looks like it has been taken care of then I’d say you’ll be just fine. Most places offer at least a 30 day guarantee on a used engine.
    I personally know a guy that is on his third Jasper engine, so I’ll just leave it at that.
  5. Jun 4, 2020 at 3:02 PM
    #45
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    07 sport 4x4[QUOTED] likes this.
