What Has Gone Wrong With Your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jom, Mar 21, 2021.
  1. Jan 30, 2023 at 7:37 AM
    #361
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Update:
    Just swapped the throw out bearing at 85k. My best guess is that it saw some water from wheeling. I need to tear it apart to verify.
  2. Jan 30, 2023 at 7:41 AM
    #362
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Front diff LH CV shaft seal leaked at less than 17,000 miles.
    LH wheel cylinder blew out at an ORV park at less than 21,000 miles. Had to get a ride from friend in a Jeep to a nearby O'Reilly's for parts and fluids.
    1776Taco likes this.
  3. Jan 30, 2023 at 7:45 AM
    #363
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Ouch. Damn
  4. Jan 30, 2023 at 7:46 AM
    #364
    Chokeu1
    Chokeu1 Well-Known Member
    jeff
    Central Texas
    2017 sR5 4x4 v6
    Billstein 5100 in front on 4th notch
    2017 79K miles.
    3rd brake light fixed under warranty
    Passenger rear brake bulb
    Other than that just regular maintenance including:
    Plugs at 60K
    Drain and fill ATF every 30K
  5. Jan 30, 2023 at 7:47 AM
    #365
    CTtoNoVa
    CTtoNoVa Well-Known Member
    2017 DCSB TRD OR Magnetic Gray
    Pop N Lock
    My gas tank door is warped somehow and keeps bulging out despite not being hit, no accidents or frame damage. I read about this somewhere, but it is super annoying. I have to keep bending it downward to ensure the tabs don't hit the body when closing it. It's bizarre...
  6. Jan 30, 2023 at 7:48 AM
    #366
    willtill
    willtill Well-Known Member
    Maryland
    2018 Cement Off Road V6 Access cab
    Ya. Not happy with the Tacoma. This is my second 'Taco. I hope nothing else goes tits up on it. I think I've had enough failings with it.
  7. Jan 30, 2023 at 7:49 AM
    #367
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    Try putting some wd40 on the fuel door hinge every few months
    Canadian Caber and 3JOH22A like this.
  8. Jan 30, 2023 at 7:50 AM
    #368
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Did you also read it's caused by lack of lubrication on the fuel door hinge? My dealer sprays white lithium grease on fuel door hinge as part of oil changes. "Lube" part of lube, oil & filter.
    Canadian Caber and turbosnail like this.
  9. Jan 30, 2023 at 7:53 AM
    #369
    CTtoNoVa
    Pop N Lock
    Yes, I have been spraying it with WD-40, but it keeps bulging outward and shifting up. It is also really difficult to manipulate/bend.
    3JOH22A[QUOTED] likes this.
  10. Jan 30, 2023 at 7:55 AM
    #370
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Yes once the hinge rod is bent out of shape, it's difficult to get it back to the original shape.
    LeakyAC, tonered and CTtoNoVa[QUOTED] like this.
  11. Jan 30, 2023 at 7:59 AM
    #371
    Hairless_Ape
    Hairless_Ape Well-Known Member
    South Jersey
    2021 F150
    Simply put, the strips are trash. EVERY single time is rains (or snow melts) and then it drops below freezing over night, my windows are frozen to the strips. I have to run a knife between the window and felts, back side of the blade so as not to damage them. The Tacoma is the only vehicle I've owned that was made in the last 25 years to ever have the windows freeze, and it does it at least once a week in the winter.
  12. Jan 30, 2023 at 7:59 AM
    #372
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    And it will bend again a lot easier since the material lost strength the first time.
  13. Jan 30, 2023 at 10:02 AM
    #373
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    get leaks coming from the a/c system when it's running hard in high humidity on the passenger floorboard. it appears to be condensation.
  14. Jan 30, 2023 at 10:02 AM
    #374
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    it's also too loose. mine rattle around especially when it's very cold
    khaki2020offroad likes this.
  15. Jan 30, 2023 at 10:04 AM
    #375
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    Both my 2nd gen and 3rd gen do this.
    SH10151 likes this.
  16. Jan 30, 2023 at 10:05 AM
    #376
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    This is normal.
  17. Jan 30, 2023 at 10:07 AM
    #377
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    i took it in to the dealer and they put some sealant on it. it reduced the moisture by 90%. no more drips but sometimes will feel a bit wet especially if i'm running the a/c with the window cracked which is probably not the brightest idea.
  18. Jan 30, 2023 at 4:14 PM
    #378
    Blue-steel
    Blue-steel Well-Known Member
    80k miles and just paint flaking off around window frame (super white paint)
  19. Jan 30, 2023 at 4:32 PM
    #379
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    No real problems.
    I did have the FP recall and I was one of the few owners that actually felt a difference it was starting to stutter...........
    None of my mods have gone south either.
    But I'm just getting to 20K miles now in 2023. We usually drive other cars around and well the the turbo Honda CR-V gets 35mpg on the highway with our short trip junk in it (but that thing HAS had problems, like AC dying)
  20. Jan 30, 2023 at 7:47 PM
    #380
    Mitbo72
    Mitbo72 New Member
    TIM
    2018 4x2 Dbl. Cab, Long Bed 3.5L V6
    none
    2018 4x2 Dbl. Cab, Long Bed 3.5L V6: Error code P11EC at 36700 miles. Nearly $7k in repairs due to Cylinder 1 issues. Luckily covered under warranty, 20 days to repair. Then before hitting 37000 miles the super white paint flaking along the entire drivers side rear door. My second Tacoma, not happy, don’t enjoy it as much as my 2nd gen. Will be replacing it with another Subaru.
