What Has Gone Wrong With Your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jom, Mar 21, 2021.
  1. Jan 31, 2023 at 7:28 AM
    #381
    86_MR2
    86_MR2 Swallow my tranya
    North Chicagoland
    2022 TRD Off Road M/T, Neil Armstrong Edition
    Just had mine do this this morning. 3º in Chicago. Instead of using a knife spray the exterior rim of the window with some rubbing alcohol. I keep a spray bottle of this in the truck as a de-icer. Frees it up very quickly without having to risk damaging the squeegee.
    At what temperature does 91 isopropyl alcohol freeze?
    Isopropyl alcohol becomes increasingly viscous with decreasing temperature and freezes at −89 °C (−128 °F).
    I may try spraying some silicone lube on the window / felt joint then move the window up and down. Might work.
    khaki2020offroad likes this.
  2. Jan 31, 2023 at 7:44 AM
    #382
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Apparently the seams on the evaporator box aren't plastic welded correctly during manufacture. Go back to the dealer and ask them to seal it better. May have to reach higher up on the box or use a different sealer. Replacing the evaporator box is an option, but it requires taking apart the whole dash, with the added possibility of broken clips and new rattles when done.
    Make sure the evaporator drain tube is clear.
  3. Jan 31, 2023 at 8:22 AM
    #383
    khaki2020offroad
    khaki2020offroad In the woods, an ambulance, Or on the couch.
    Dennis
    Great Lakes
    2020 QS DCLB OffRoad
    Butt indentations
    Let us know if silicone works. I worried it would end up all over the glass.
  4. Jan 31, 2023 at 8:31 AM
    #384
    86_MR2
    North Chicagoland
    Was just about to do it but first sprayed alcohol on the joints to unstick any potentially stuck windows. Rears popped loose but they were frozen, so good.
    Seems the alcohol is viscous enough at these low temps to not evaporate very quickly. It remains on the windows after rolling them up and down. Alcohol is supposed to displace water so, if it gets into the felt, I'm gonna see just how long it takes for this initial fix to last before trying the silicone spray. BTW, the silicone's freezing point is -28º.
    I'm gonna just wipe the windows down to clear the alcohol. It'll take a few times but, as long as some is retained in the felt, should be okay.
    Hmmm, just read alcohol can damage rubber over the long term. Once this temp fix stops working I'm gonna do the silicone.
    Sorry for the multiple edits but, who knows what these window squeegees are made of? Rubber? Vinyl? Roast beef?
  5. Jan 31, 2023 at 8:35 AM
    #385
    khaki2020offroad
    Dennis
    Great Lakes
    Butt indentations
    WGN was saying 7° my house was 4° neighbor (NWI)
  6. Jan 31, 2023 at 8:58 AM
    #386
    86_MR2
    North Chicagoland
    Chilly sunrise at ORD.
    VTi EG6 likes this.
  7. Feb 1, 2023 at 3:28 AM
    #387
    1776Taco
    1776Taco Well-Known Member
    2019 2.7 4x4 SR
    added rear seats access cab LEER 100R Curt hitch receiver Curt trailer lights Carthart seat covers 255/85/16 Toyo MT for trails 265/70/16 W/ OR wheels for DD TRD PRO skid OR fuel tank skid Warn tubeless winch bumper Smittybilt XRC 9.5k winch HS 1/4 inch coil spacers RCI rock sliders Wheelers 1.5 AAL Bilstein 5100 rear Decked
    3 years and 55k miles later, happy to report no serious issues as of yet. However at about 40k miles it developed a leak at where the t case meets the trans. It was the rear trans output seal, t case had to be removed to access the seal, was covered under warranty. The truck has seen heavy off road and towing use. 2.7 4x4
    oil changed every 5-7k miles with 5w-30
    Rear diff fluid changed at 20k miles with Amsoil severe gear. No other repairs or fluid changes made
  8. Feb 3, 2023 at 7:43 PM
    #388
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Yeah.... Watch the speed of corrosion of body panels and other quality issues!
  9. Feb 3, 2023 at 10:38 PM
    #389
    Nomad26
    Nomad26 Well-Known Member
    Escondido, CA
    '16 MGM OR Access Cab, ‘16 MGM RAV4 Hybrid
    2016 OR AC with around 112k miles. Replaced the passenger side primary cat at 98k miles, which was a bummer. No other issues to report so far.
  10. Feb 5, 2023 at 5:07 AM
    #390
    1776Taco
    2019 2.7 4x4 SR
    Like Toyota’s never had that issue
    Yotalicious likes this.
  11. Feb 5, 2023 at 5:50 AM
    #391
    Yotalicious
    Yotalicious Member
    MA
    2023 Tacoma OR DCSB
    No issues on any of the gens I've had. First thing I do is spray a ton of NH Oil Undercoating on it when I buy it. Repeat yearly.
  12. Feb 5, 2023 at 11:02 AM
    #392
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    A buddy of mine hasn't had any issue yet from his 2021 frontier either. He always has to remind me what a pos his 2019 trd was. The frontier has no vibrations, and the power is far smoother. I've ridden in it when we took it to one of his fishing spots. To be fair, it's a nice truck, every bit as good as my sr5. I just hate getting reminded of it.
    Phlogiston likes this.
  13. Feb 5, 2023 at 11:58 AM
    #393
    Bontchimuz
    Bontchimuz Granite
    2017 TRD PRO
    TRD Exhaust failed summer 2022
    TRD Fox coilovers both front broke winter 2023
    Still love my truck but feel none of that should of happened sub 80k milkes....
