What Has Gone Wrong With Your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jom, Mar 21, 2021.
  1. Mar 21, 2021 at 6:20 PM
    #81
    Showtime
    Showtime Well-Known Member
    Nick
    Wisconsin
    16 Tacoma TRD Sport
    16 sport 94k. a/c line popped off, 3rd brake light was leaking.
  2. Mar 21, 2021 at 6:42 PM
    #82
    DrewMaca
    DrewMaca Well-Known Member
    Drew
    2016 TRD Sport 4x4 Double Cab
    A few issues - but overall I’m very happy.
    Driver’s side heated seat doesn’t work
    Tailgate lock isn’t as it should be.
    The paint from the factory seems really thin.
    Lost a mud flap.
    Had a squeaky clutch pedal, but that has quieted.
    Junkhead likes this.
  3. Mar 21, 2021 at 8:24 PM
    #83
    MadKatt
    MadKatt In need of serious help..
    Frozen Midwest Tundra
    2019 TRD OR DCLB Calvary Blue
    Not one issue on my 19 very happy with the truck.
  4. Mar 21, 2021 at 8:32 PM
    #84
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    1) 2018 TRD Sport, 25,000 miles - Nothing has gone wrong
    2) 1996 4x4, 414,000 miles - Very little has gone wrong
    Junkhead, TroutBum and playdixie like this.
  5. Mar 21, 2021 at 8:34 PM
    #85
    CDNTacoma2019
    CDNTacoma2019 Well-Known Member
    Ontario, Canada
    2019 SR5 DCLB 4x4
    That and the mm radar sensor recalls are the only issues I have had with my 2019.
  6. Mar 21, 2021 at 8:42 PM
    #86
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I get too many compliments. It’s embarrassing.
  7. Mar 21, 2021 at 9:09 PM
    #87
    Mid Life Crisis
    Mid Life Crisis Active Member
    2017 OR with 40,000 km - one of the license plate light bulbs went out and I had trouble getting my hand in there to replace it.
    BumfukKansas and FishnTx like this.
  8. Mar 21, 2021 at 9:38 PM
    #88
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Third Brake Light Leak
    "Super" White Paint Peeling Off
    50k miles
  9. Mar 21, 2021 at 10:22 PM
    #89
    MauiBrian
    MauiBrian Kapalua fun
    Brian
    Maui
    2018 SR lightly modded
    2018 here. Had a rough running/misfire issue prior to fuel pump recall completion. Once recall was done, truck runs nice and smooth. Fuel economy even increased according to IP.
    ATF was 1/2 qt. Low (no performance issues though) and differential was 1 qt. Low (again no issues noted) Did PM at 20 K.
    That's it....
  10. Mar 21, 2021 at 11:14 PM
    #90
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    High pressure fuel pump failure around 45k and then a front cover/valve cover oil leak around 50k required tear down of the front/top of engine which resulted in essentially all of the gaskets being replaced for valve cover/front cover/intake/etc. Other than that the “problems” are “characteristics of the vehicle.” However, most importantly, it has never left me stranded, and has gotten me up some gnarly shit from Anza Borrego to Death Valley. Think I’m gonna finally give in and get some bigger tires for a little more ground clearance though.
    4x4spiegel and Junkhead like this.
  11. Mar 22, 2021 at 3:30 AM
    #91
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    Rough idle fully warm in gear @ stops only when ambient air temp is over 60° & never colder. Never while coolant temp is below 190° or ambient air temp under 60° been to 4 dealers still doing it.
    2018 DCLB OFF ROAD 3.5 auto trans 56,000 miles always used Ethonol free fuel
    Any ideas?
  12. Mar 22, 2021 at 4:03 AM
    #92
    JNG
    JNG Shitposter extraordinaire
    2019 Silver TRD OR DCSB 4x4 AT P&T
    I should add that my truck does have 2 recalls on it. The fuel pump and the radar. I have not bothered to go get either repaired under recall as I have had zero issues with either pump or radar.
    GillyLink likes this.
  13. Mar 22, 2021 at 6:18 AM
    #93
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    That one missed me, plus I did a DIY pad for my faux Pro grill. No issues.
  14. Mar 22, 2021 at 9:21 AM
    #94
    DustyTaco31
    DustyTaco31 Well-Known Member
    2018 Quicksand Taco TRD Sport
    well my 2018 DCLB Sport has been a champ, no issues
  15. Mar 22, 2021 at 9:37 AM
    #95
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Wow, I impressed! I run 91 non-Eth in my generators, but the truck gets the regular crap.
  16. Mar 22, 2021 at 9:41 AM
    #96
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    2019, had a little over 2 years now. Just under 12K miles. The only thing that was really a problem is I found the tranny fluid a little low, something like 10 to 12 oz. Been a great truck so far.
  17. Mar 22, 2021 at 10:30 AM
    #97
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    I have to keep refilling the gas tank. It's been refilled over 100 times now, think I could Lemon Law it?
  18. Mar 22, 2021 at 10:41 AM
    #98
    BOSS-DS2
    BOSS-DS2 Well-Known Member
    Sam
    Texas
    2016 Tacoma 3.5L A/T DCSB
    Motofab 3” Spacer lift Spidertrax 1.25” wheel spacers Yokohama G003 M/T 285/75/17 (34”) MBRP 3” Turndown PowerStop slotted & drilled rotors Tekonsha P3 brake controller
    Rear differential was leaking at around 100k miles. Drained, torqued and refilled.
    Replaced battery at 120k miles
    Did it’s first ATF change at 140-150k (just emptied the pan via drain plug)
    Routine 10k mile oil changes
    Routine engine air, and cabin air filters every 5-10k miles.
    Weird rust specks were appearing on only the drivers side front and back door sill. Unsure of its origin, but a clay bar got rid of it.
    Brake pads and their pin retaining holes were worn out at around 150k miles, make clunking noises when stopping (new brakes waiting to be installed when I get time).
    Factory head unit did randomly power down twice, but that was around a year ago and never did it again.
    I live in the south so I have no issues with rust, but for those who do I would advise against having Toyota service the frame. Unless they have changed their practice they merely spray over the rusty areas, encapsulating the rust and moisture which makes the problem worse down the line.
  19. Mar 22, 2021 at 10:43 AM
    #99
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    2016 Sport
    2qt low trans fluid
    3rd brake light leak
    license plate lights filled with water
    slow shifting from R to D because of low fluid
    thats all I had in the 16
    my new 21 with 700miles is at toyota for a few days now trying to figure out the driveline vibration.
  20. Mar 22, 2021 at 10:43 AM
    #100
    BOSS-DS2
    Sam
    Texas
    If I did the math correctly I have filled my tank over 500 times. Ouch.....
