What Has Gone Wrong With Your Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jom, Mar 21, 2021.
  1. Mar 25, 2021 at 10:01 AM
    #161
    shark413
    shark413 Well-Known Member
    Mark
    Wheel center cap had one of the catch lugs bent out of shape from being installed wrong by dealer/factory (I bent it back and it is fine now). Other than that zero issues with my truck (2020) after a year of use.
  2. Mar 25, 2021 at 10:06 AM
    #162
    MR E30
    MR E30 Well-Known Member
    Michael
    Wherever it's parked
    2021 Silver TRD OR DCLB w/ AluCab and All the Mods
    For the 2016 the only issue I have had up to its current ~73,000 miles is the headliner coming slightly separated from the door molding above the passengers head. Kind of annoying, but I tuck it back in whenever I see it.
    For the 2021, well, it's too early to tell as it only has 269 miles, though the new headunit is incredibly laggy, quite the downgrade from the headunit in the 2016.
    Both of these get rented out to strangers to take on overlanding adventures, so the 2016 has proven itself to be a tremendous machine.
  3. Mar 25, 2021 at 10:55 AM
    #163
    Butl3rM0nk3y
    Butl3rM0nk3y Well-Known Member
    Brandon
    Loveland, CO
    17 Inferno TRD OR 4x4
    Soft-Topper Bed Mat Bed bolt D-Rings
    Just a thought from years ago when my 07 started getting a bit clunky like that... ended up the u-joints had been worn out. The change in direction of force on the drive shaft while alternating D and R was accentuating the play in the worn out joints, and making noises. Toggling the shifter that way is a bit of a diagnostic test. As they really started to go, there was a squeaking that paralleled wheel speed (not engine speed) in frequency.
    If that is the culprit, do yourself a favor and spend more than $20 on replacement ones that also have a good grease zerk for maintenance, like Spicer.
    Taco_mike73 likes this.
  4. Mar 25, 2021 at 11:24 AM
    #164
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Mines a 2021 with only 250 miles on it at this point. I assume its prob normal but have nothing to compare it to
    shakerhood likes this.
  5. Mar 25, 2021 at 11:48 AM
    #165
    Z28tranz
    Z28tranz Member
    Fort Walton Beach
    2020 MGM TRD OR
    I bought my 20 last July, it has 17k miles on it now and the only issue I have had with it was the android auto being intermittent. It was probably a software issue , as it works great since my 10k service.
  6. Mar 25, 2021 at 11:54 AM
    #166
    eurowner
    eurowner Duke Sky
    Scoty
    The hood skin became unglued from some of the supports. That's it, just turned 41k
  7. Mar 25, 2021 at 12:56 PM
    #167
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    Have you never driven a car with a hydraulic power steering system? They always rev higher to help the pump out. Pretty simple if you ask me and everyone else on this thread - I'm guessing you've never driven a stick either?
  8. Mar 25, 2021 at 12:59 PM
    #168
    Dkarr13
    Dkarr13 IG: Tonya_Tacoma
    Ohio
    2016 Sport MT ACLB MGM
    Too much to name for this little space
    Brother you have some bad luck, then. I have a 2016 with 55k miles and not a single thing has gone wrong, unless I did it myself. Good luck in the future, sheesh
    Jom[QUOTED][OP] likes this.
  9. Mar 25, 2021 at 6:43 PM
    #169
    A Florida Man
    A Florida Man Well-Known Member
    NW Florida Gulf Coast
    ‘13 Tacoma Limited Double Cab
    Loving my 13 Tacoma purchased three weeks ago, double cab 6 cyl. It must have been lifted cause I have to hoist myself up using the handle. Can’t figure out how to exit without using the edge of the seat as a slide. No fancy pants electronics and I doubt I’ll ever use the 4 wd. But who knows...it’s just my drive around town car.
    Jom[OP] likes this.
  10. Mar 25, 2021 at 7:00 PM
    #170
    A Florida Man
    Chckd the mileage on my new to me 13 Tacoma double cab 6 cyl today and averaged 14.7 mpg over 125 miles of in town driving. But I don’t give a shit, I like my truck. My first truck ever at 68 y/o. Yeee freaking haw!
  11. Mar 25, 2021 at 7:08 PM
    #171
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    130k
    PS Rack leaking into RH bellow
    Trans Case leaking at actuator Oring
    Carrier bearing and the U joint at it
    115k
    Upper ball joint is JBA
    90k
    Lower Ball joints and hubs
  12. Mar 25, 2021 at 7:08 PM
    #172
    Toyotafanforlife1991
    Toyotafanforlife1991 Live FREE and drive a TOYOTA!!!
    Brandon
    Dickson, Tennessee
    2016 QS Tacoma DCSB OR M/T, 1970 Toyota Land Cruiser FJ40 351W M/T, 1982 Toyota Hilux SR5 M/T, 1983 Toyota Hilux SR5 M/T (undergoing frame off restoration)
    Well I bought a brand new 2016 DCSB OR M/T and I've put on 170k miles and I've loved every minute of it honestly. Stock battery crapped out early but no biggie I wanted a larger one anyways. I bought a custom 3rd brake light so no leak. I replaced 1 wheel bearing, easy and also no biggie. And I have the dreaded timing cover leak but for me no biggie, actually kind of looking forward to pulling the engine out. Also plan on doing the clutch at the same time.
    But all in all I wouldn't say anything has gone wrong with my tacoma, it's just normal maintenance and repairs and man I fucking LOVE keeping up on the maintenance and repairs, I enjoy it, sincerely. Everytime I do a job myself on my tacoma, I instantly feel 100% better knowing I didn't have to pay 1000% markup for the dealers crappy/shoddy service.
    I will keep this truck until I die, and it will keep running forever with a little love and care.
  13. Mar 25, 2021 at 7:12 PM
    #173
    Dirtridercrf250
    I take it you turn wrench too, any ways besides the point these trucks are very easy to work on. Eng has to come out for the cover?
  14. Mar 25, 2021 at 7:20 PM
    #174
    Brandon
    Dickson, Tennessee
    Turn wrench too?
    Oh these trucks are very easy and simple to work on. They are built to be serviced and everything can be rebuilt just about. That's why I love toyota.
    Doesn't have to come out, I've seen a few reseals with it in but it's just easier to me to pull the engine out and seal it up on a stand. Looking at the service manual and how many places and nooks and cranny get sealant, it's 100x easier on a stand IMO.
    BumfukKansas likes this.
  15. Mar 25, 2021 at 8:09 PM
    #175
    Tacogeorge17
    Tacogeorge17 Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    I have a 2017 trd offroad 4x4 6spd manuel dblc shortbed bought it at 1 mile currently has 99,892 miles on it and the only issue I have had was a leaky rear diff gasket at 180 miles and Toyota replaced it. haven't had any issues since.
  16. Mar 25, 2021 at 8:39 PM
    #176
    Moabing
    Moabing Well-Known Member
    Rory
    Shit, now ill be cruising this thread.
    I got just under 5k on my 21' OR AC AT. I went from a 98 mazda 2wd to this, so everything freaks me out.
    Does any notice when you park and dont use the e-brake the truck rolls after park a bit and the shifter clicks/moves?
    Also is it just me or is the cruise control in these trucks absolute TRASH?! I feel like it down shifts 3 gears to catch up 3 mph.
    I've had what I assume to be my TSS sensor act up. My best guess is the desert dust.
    The fear is real...
    tacopa2953 likes this.
  17. Mar 25, 2021 at 8:50 PM
    #177
    Markcal
    Markcal Well-Known Member
    It's good to hear positive experiences like yours and people that DIY.
  18. Mar 25, 2021 at 8:50 PM
    #178
    Ronk44
    Ronk44 Well-Known Member
    Rockerville, SD
    2017 MGM Sport
    Leveled with Bilstein 5100 shocks, Kumho AT52 265/75 tires, Redline hood struts, R4T tailgate lock, Matt Gecko LED strips in bed and under hood, WeatherTech hood guard, OEM bed mat, Husky floor mats, Carhart seat covers, Grille replacement with Toyota letters, Sony AX6000 replacement head unit, OTT lite/mild tune, and an occasional splash of fuel additive.
    At 50k on my 2017 Sport... One dash rattle I fixed by pushing some black electrical tape in between speaker cover and dash trim. Nothing else to report.
  19. Mar 25, 2021 at 9:00 PM
    #179
    MGMDesertTaco
    Minimal stuff thankfully...
    2017 bought new with 3 miles now has a hair over 10k miles. :anonymous:
    1. at 2-3 months of ownership, battery leaked acid from covers. Thanks Johnson Controls o_O(replaced under warranty with 84 month Toyota Battery)
    2. HVAC Blower wheel stripped itself loose during 100+ AZ summer heat around 5k mile mark (replaced under warranty, then replaced under warranty again with updated recall part when it became available.)
    3. Drum brakes lacked grease on backing plates, squealed like a pig (greased backing plates under warranty):rolleyes:
    4. Drums/parking cable occasionally stick after washing the vehicle
    5. Auto trans has quirky, but normal for the truck shifting characteristics (tsb fix available if I ever get around to taking it in)
    :burnrubber:
  20. Mar 25, 2021 at 10:37 PM
    #180
    HV101
    HV101 Well-Known Member
    Harlow
    2016 Gray Tacoma SR5 Access Cab
    None
    I have 2016 AC SR5 4X4 2.7 with automatic transmission and 43000 miles, bought new in 2016 and no problems. Sometimes the trip (odometer) doesn’t reset on first push, but other than that it seems bulletproof. No major recalls or TSBs. I don’t hear too many complaints about the 2.7/automatic set up. Is the transmission less of a problem with the 4 cylinder engine? I agree doesn’t accelerate that well but I’ve had it over lots of California and inter mountain grades and it always gets me home. Good in snow and dirt roads. Any feedback from other 2.7 drivers?
