  1. May 1, 2015 at 9:12 AM
    maxpower29
    maxpower29 Well-Known Member
    Jordan
    Nova Scotia, Canada
    2011 Tacoma 4x4 2.7 5 speed SWB
    All season mats, 2nd filter delete, DT header, Jardine cat-back, URD shifter, Bilstein 5100's all around at .85 front with Eibachs + .25 passenger/.5 drivers spacers and 1.5 AAL, 0w20 synthetic, Scanguage II, extra D rings, OEM backup camera+Mirror, bed mat, Extang Solid Fold, Popnlock 5300, Pro Comp 7089's 4.5bs 285/70/17 Revo 2s, De-badged
  2. May 1, 2015 at 9:17 AM
    Manwithoutaplan
    ID
  3. May 1, 2015 at 9:26 AM
    Pigpen
    Dan
    Northwest Montana
    :crapstorm:
    Washed and waxed. I've done this twice in a little over 3 years
  4. May 1, 2015 at 9:27 AM
    Raincity
    Raincity Half man, half amazing.
    Lowermainland, B.C.
    '13 Mica Spruce DC.
    '12 DC TRD-RIP
    Mounted my phone with the Ram mounting gear. Thought about this for sometime after repeatedly being disappointed with other mounts. Works well so far, might try a shorter arm. Threadlocked it and added some epoxy to the backside to help distribute the pressure.
  5. May 1, 2015 at 10:53 AM
    8054x4
    8054x4 Well-Known Member
    south 805
    2013 DCLB 4x4 TRD Sport
    Snugtop Rebel topper Goodyear Duratracs
    New shoes and socks! 16x8.5" bronze level 8 guardians wrapped in 285/75 Goodyear duratracs! Only thing I'm not too excited about is the fake carbon fiber center caps... image.jpg image.jpg image.jpg
    idahbro and Raincity like this.
  6. May 1, 2015 at 10:54 AM
    Old School
    Old School You are ignoring covfefe by this member.
    Looks like the 101 at the Rincon...
  7. May 1, 2015 at 10:56 AM
    Lespaulkid01
    Lespaulkid01 I prefer the term "beer researcher".
    MoCo, Maryland
    2013 Double Cab TRD Sport, Pyrite Mica
    tool chest, vent visors, tuffy bed box, scangauge, Bilstein 5100's, OME 885x springs, Wheeler's HD AAL, LED map, dome, and reverse lights, Bestop Supertop.
    Don't know if you have a True Value or something around, but I use these. Home Depot doesn't carry them (at least not he one by me) but True Value has them for $1.39 each. I believe it was the 3/8" size that fits the best. slides right in and doesnt wiggle once tightened down. I put eye bolts through them and use them for tie downs. They're extruded U-nuts - i've also seen them called speed nuts.
  8. May 1, 2015 at 11:05 AM
    veronatii
    veronatii Well-Known Member
    Spencer
    PNW
    Looks great! Super White DCLB for the win! Do you have a lift?
  9. May 1, 2015 at 11:05 AM
    8054x4
    south 805
    Nailed it.
  10. May 1, 2015 at 11:21 AM
    8054x4
    south 805
    Thanks! Yep I have an OME lift, approx 3" up front and a 1.5" AAL in the rear, I need to cab mount chop though, it rubs pretty good in reverse as well as left hand turns.
  11. May 1, 2015 at 11:41 AM
    tacozord
    tacozord Well-Known Member
    2015 DCLB 4wd SR5
    Icon suspension, ARB front bumper, Pelfreybilt rear bumper, Warn 9.5-XP winch, Demello Offroad sliders
    Removed back seats. They just got in the way of storage, and the black compartments behind the seats are plain stupid.
  12. May 1, 2015 at 11:46 AM
    Manwithoutaplan
    ID
    nice ^ I need fire extinguisher so bad.
  13. May 1, 2015 at 11:48 AM
    tacozord
    2015 DCLB 4wd SR5
    Thanks. I plan on retrofitting the area much better with a level platform and u-track for tie-downs. Also, the Powertank and fire extinguisher will eventually end up in the bed. But this will suffice for now.
  14. May 1, 2015 at 11:51 AM
    Manwithoutaplan
    ID
    what time you heading out tomorrow just by curiosity
  15. May 1, 2015 at 11:53 AM
    tacozord
    2015 DCLB 4wd SR5
    Everyone's meeting at 0900 at the staging area. I'll probably leave my house around 7am, gas up at 138 and then be there by 9.
  16. May 1, 2015 at 11:54 AM
    Manwithoutaplan
    ID
  17. May 1, 2015 at 11:55 AM
    tacozord
    2015 DCLB 4wd SR5
    I also moved my fuel can from my Ford to the Tacoma. I didn't have time to buy t-slots and fabricate something permanent. So...don't tell anyone...but I use plywood and bolts. Most definitely temporary.
    Also, picked up a Midland 75-822 and Wilson Little Wil antenna.
  18. May 1, 2015 at 11:57 AM
    tacozord
    2015 DCLB 4wd SR5
    :burnrubber:
  19. May 1, 2015 at 12:00 PM
    Manwithoutaplan
    ID
    i like pilot rock . I am little burnt out of cleghorn.
  20. May 1, 2015 at 12:43 PM
    Old School
    Did you pull the little mud flaps at the front, of the front wheels?
    Hard for me to tell from your pics...
