  1. May 25, 2016 at 7:18 AM
    dimead0zen
    dimead0zen Well-Known Member
    So Cal
    Mid-Travel 2016 TRD Off-Road 4x4
    Desert prerunnin', rock crawlin' machine!
    Yes, you have to get an alignment after changing suspension...
    So here's my config:
    8 threads showing on top of the pinch ring. This puts me at a little over 2.25" lift. The below measurements are from center of hub to the fender.
    Ride: 23"3/8 (according to the Toytec lift thread, stock is 21")
    Droop: 25"5/8
    This puts me at over 2" of wheel droop, in my opinion right where you want to be in the shock's travel range. I haven't stuffed the tire yet to get my max compression measurement. What other numbers are you lookin for?
  2. May 25, 2016 at 7:26 AM
    fcasos
    fcasos Well-Known Member
    San Diego, CA
    2016 Tacoma DC TRD Off Road 4x4
    King Shocks OEM Performance Series Kit
    Thanks, will follow that. What alignment numbers did you go with (Toe, Caster Camber) after install?
  3. May 25, 2016 at 7:33 AM
    dimead0zen
    So Cal
    Tow is standard (the wheel alignment shop didn't tell me what they set it to, I think like 3/16" towed in). Caster is unchanged thanks to the new UCA's (3-5degrees positive). Camber is zero (plus or minus 1 degree).
  4. May 25, 2016 at 7:37 AM
    fcasos
    San Diego, CA
    Last question (promise), the UCAs, how much grease did you put on them? I've read anywhere from 2 to 5 pumps, how many did you do?....I am looking forward to tomorrow and getting these things on!!!
  5. May 25, 2016 at 7:43 AM
    Inferno
    Inferno Well-Known Member
    Dennis
    Boston, MA
    2016 Inferno OR dcsb
    Wheels American Racing Baja 17x8 0 offset rims with paint 4X0 modificatioin to the rims. 265 70/R17 BFG AT KO2's, Bakflip Revolver X2, Rokblokx mud flaps, Pro Traxx 4" nerf bars, avs in channel wind deflectors, bed extender, derped grill and badges, changed bed emblems from silver to solid black, OEM sill protectors with color matching inlay decals and mats. Glove box color matching inlay decals.
    I was told by dealer whenever you go into S it always goes to fourth gear. That is to protect the tranny from someone hitting it into S while going 70 MPH. Even at a dead stop it goes into 4th just downshift before you start out..
  6. May 25, 2016 at 7:43 AM
    dimead0zen
    So Cal
    No worries! I lubed the inside of the bushings before install, and did 2 pumps once installed. I used anti seize on any metal to metal surface.
    I followed this YouTube video, it is pretty much the same on 2nd/3rd gen. Bend the inside fenders to get the UCA bolt out, then bend back in place once installed.
    https://youtu.be/bbsTJgb6S_c
    Patrick16taco and TacoWocko like this.
  7. May 25, 2016 at 7:55 AM
    fcasos
    San Diego, CA
    Excellent, thanks a lot. I have been watching that video over and over since I ordered my King's, I am ready to go! Since I am doing the rear as well I will take measurements and share, not sure if there will be any difference.
    dimead0zen[QUOTED] likes this.
  8. May 25, 2016 at 7:59 AM
    acemastr
    acemastr Well-Known Member
    Aaron
    Tampa, FL
    2016 Tacoma Limited 2WD AT
    OVTune
    The manual states to put it into M 5 when towing, it doesn't start off in 5th, try it from a light, move it over so it says M 4 and pull away, you'll see it changes as usual. If you go to M 1 and move it up to 2 it'll shift to 2, then 3 and 4 etc
    *Edit* however! it does say that up to 3rd can be used at a standstill... will try it on way home, this makes sense as most AT allow this, even my old BMW 330 let me start in 2nd for icey conditions etc
  9. May 25, 2016 at 8:18 AM
    LEXICON
    LEXICON born where the prairies meet the rockies
    Courtney
    Canada
    2016DCLBBLACKTACOMATRDSPORT4X4PREMIUM
    Nothing worthy
    Pretty sure you've already figured it out or broke a tab trying..
    Just access tabs from inside engine bay.
    Low down obviously where the fogs are.
    EASY
  10. May 25, 2016 at 8:24 AM
    Gettin Lost
    Gettin Lost Backwoods Rated
    Florida
    2021 TRDOR
    KDMax tune, eibach stage 2, ceramic tint, DD SS3 PRO fogs. Toyo AT3 285s
    Love the rod holder. Wish they made one for spinning reels.
    I have never fly fished... I need to try it.
    TacomaMike32 likes this.
  11. May 25, 2016 at 8:25 AM
    TacoWocko
    TacoWocko Well-Known Member
    Paul
    NC
    2016 White Tacoma OR 4x4 LB
    Husky mats OEM bed mat Mobtown Sliders CustomCarGrill OME 887 w/Dakars LR UCAs SumoSprings
    I've been watching this video too, and I've convinced myself I can do this. I haven't found a video that inspires confidence in changing out my leaf yet, though :(
  12. May 25, 2016 at 8:34 AM
    fcasos
    San Diego, CA
    I am not planning on changing leafs but I have seen many videos where they show the process and the most important thing one should make sure to do is to clamp them together with big, and reliable clamps before undoing the bolts, other than that a couple of jacks to help bring them down would be helpful.
  13. May 25, 2016 at 8:59 AM
    JerryTaco
    JerryTaco Well-Known Member
    It's actually really easy. Hardest part is drilling out the rivet and removing one of the spring clamps if you're installing a progressive Aal. Don't have to do that step however if you're just installing a single aal
  14. May 25, 2016 at 9:12 AM
    Ecrub
    Ecrub Well-Known Member
    Eric
    Brea, Ca
    2016 DCSB TRD OR 4x4
    OBXPaul likes this.
  15. May 25, 2016 at 9:13 AM
    MrSmithsTaco
    MrSmithsTaco Well-Known Member
    Oklahoma City, OK
    2016 Super White Tacoma TRD OR
    Me in the driver seat.
    I was under the impression this wasn't so much a "sport" mode but a means of controlling the transmission better. For instance. I went off-roading with some buddy's and it kept trying to shift in and out of second. I just moved it over to limit it to go as high as second gear and it helped tremendously. It stopped hunting for the right gear and kept the torque where I needed it.
  16. May 25, 2016 at 9:26 AM
    Two Hawks
    Two Hawks Well-Known Member
    Morgan Hill, Ca.
    2016 Tacoma TRD OR 4X4 A-Cab
    Ham radio antenna,Firestone Ride-Rite air spring Snug Top topper, and a rifle rack y'all ..Moroso Catch Can, De-badged.
  17. May 25, 2016 at 9:37 AM
    opentang
    opentang you're doing a good job
    Brandon
    2020 T4R TRD PRO
    Well done! Which compressor model did you go with? Any insights you have on the install would be helpful, as I'm about to go through a similar exercise. What all do you plan to use yours for?
  18. May 25, 2016 at 9:48 AM
    AZInferno
    AZInferno Well-Known Member
    2016 TRD Sport Inferno
    I've got about 6k miles on mine, I often find myself stomping on the go pedal to get the engine to wake the hell up, frustrating to say the least. I'm sure it was designed this way for fuel economy, but if I wanted a Prius I would have bought one.
    Bobsolanki[QUOTED] likes this.
  19. May 25, 2016 at 10:08 AM
    Diablo6
    Diablo6 Well-Known Member
    '16 TRD OR DCSB 4x4
    I'm at the dealership now getting the vibration when decelerating and rear diff howling looked at, I asked about any TSBs and he looked it up and said there were none yet for my v6 TRDOR DCSB 4wd. I thought I read in another thread the transmission TSB was for the 4 cyl.
  20. May 25, 2016 at 10:17 AM
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    It's not like a manual transmission where you control the actual gear. From the manual "Selecting shift ranges using S mode restricts the upper limit of the possible gear ranges, controls engine braking forces, and prevents unnecessary upshifting." So in your case where you were having issues with it shifting between 2nd and 3rd, setting it to S-2 would prevent that but still allows it to downshift to 1st. If you start out in S-4, it's going to going to go through the normal range of gears 1-4, but not go into 5th or 6th. The manual says that going from D to S sets it to 4th or 5th depending on speed or 3rd if "AI-SHIFT" has operated while in D but I've never had it go into anything other than S-4 even when going 70MPH+.
