  1. Aug 3, 2021 at 9:26 AM
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    No problems at all actually I just dislike the idea of a spring perch/spacer lift on what is a good stock suspension setup. I just couldn't hold out for the Eibach springs any more - too impatient.
    I will say that getting the spring perches off/on took a while until I just decided to try using a dead blow hammer at which point they came off really easily.
    Out for tires and alignment now!
    TnTHicks, markram, playdixie and 3 others like this.
  2. Aug 3, 2021 at 9:35 AM
    SanFelipeRat
    SanFelipeRat Well-Known Member
    Tony
    2021 TRD Off Road / Crew / 4x4 / long bed / Army Green
    5:29 Gears, Cat Back 3" exhaust
    What are we talking about?
  3. Aug 3, 2021 at 9:38 AM
    Benny blanco
    Benny blanco Mr. Jiggletits
    Ben Day Ho
    Whoville<>Trollhättan
    21 Cement TRD OR MT
    Some stuff
    How much it would cost someone to have you do this
  4. Aug 3, 2021 at 9:39 AM
    ETBA
    ETBA Well-Known Member
    Erik
    Texas
    2021 TRD Off-Road
    Ordered an Alu-Cab Canopy, should be able to pick it up next week.
    :fingerscrossed:
  5. Aug 3, 2021 at 9:56 AM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    The approximate cost to do a bed setup like yours. Similar to this:
  6. Aug 3, 2021 at 10:22 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    the shop that did it is SMP_Fab on instagram. Last I saw, they were working out a cost
  7. Aug 3, 2021 at 10:57 AM
    Aqualoon
    Aqualoon More stickers!
    Minnesota
    2019 Off-Road DCSB Cavalry Blue
    Swing case installed!
    TnTHicks, Stg246, devale and 7 others like this.
  8. Aug 3, 2021 at 11:01 AM
    Wicker24
    Wicker24 Well-Known Member
    2018 TRD Off Road
    Got my sub and amp installed in my mrmarv custom box. Sounds amazing!
    TnTHicks, devale, SouthFLTaco and 7 others like this.
  9. Aug 3, 2021 at 11:18 AM
    ghostleaf
    ghostleaf enjoy the ride
    Hawaii -> PNW
    2020 TRD OR DCSB 4X4
    just installed the esi rok block tailgate gap cover.
    999F0F90-892F-4E4A-8126-F727B109D653.jpg F7C3C44D-AF2C-442D-8733-6CD0B5819D0B.jpg
    TnTHicks, devale, Abominator and 9 others like this.
  10. Aug 3, 2021 at 11:21 AM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    Truck looks great! Did you adjust the preload to increase lift height?
  11. Aug 3, 2021 at 11:26 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    That should be a Factory thing, awesome use of that empty space!
    Jeff Dartfrog and s.e.charles like this.
  12. Aug 3, 2021 at 11:33 AM
    SanFelipeRat
    Tony
    The box is sealed and massive strong. This is a prototype, so i'm guessing its worth about $2K. Steve will scan and reproduce these. I'm guessing around $1,500 mass produced.
    I have spent another $2K/2.5K on Fab, so this feature (box and cage only ) is worth about 4k-4.5K installed and finished.
    Jeff Dartfrog, dlb97as and FatGandalf like this.
  13. Aug 3, 2021 at 11:36 AM
    SanFelipeRat
    Tony
    I have spent another $2K/2.5K on Fab, so this feature (box and cage only ) is worth about 4k-4.5K installed and finished. The cage can be found here
    2021 TRD Off Road / Crew / 4x / LB / Army Green "500xChase" | Page 5 | Tacoma World
  14. Aug 3, 2021 at 11:56 AM
    s.e.charles
    s.e.charles Well-Known Member
    struggling with the flat springs thing so i got my truck weighed today. door sticker says 5,600# GVW
    tire sticker says "not to exceed 1,150#" load
    ticket from weigh station says 4,800# MGV
    i asked about the reading and the booth guy told me the system rounds up to "the next 20#" and that my actual weight was 4,783#.
    truck had a full tank of gas & me inside (plus cap tools partial build in the bed)
    Q: do these numbers make sense?
    thinking about getting a second weight (from alternate source)
    thanks
  15. Aug 3, 2021 at 12:00 PM
    WRREGL
    WRREGL Well-Known Member
    North Alabama
    2018 TRD sport
    Work in progress
    Ordered a set of colorlugs. Cheaper and easier option to black out chrome lug nuts. Can’t wait to get them.
  16. Aug 3, 2021 at 12:01 PM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Sounds about right except the tires. What tire sticker are you looking at?
    Tires should be rated between ~2300 and ~3500 lbs each depending on load range.
    Edit: I think the 1150 lbs is the trucks load capacity, 5600 gvw minus the wet weight of the truck. The "tire sticker" threw me off
  17. Aug 3, 2021 at 12:03 PM
    Adobada Tacos
    Adobada Tacos Well-Known Member
    Anthony
    Portland, OR
    2021 White Tacoma TRD Offroad
    Installed the roof rack.
    TnTHicks, devale, Aqualoon and 13 others like this.
  18. Aug 3, 2021 at 12:03 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    From the factory that's the spare tire cavity.
  19. Aug 3, 2021 at 12:20 PM
    s.e.charles
    sorry; trying to give the best information i can glean.
    Q; if i take the GVW = 5600 & subtract 1150 load, i get 4450 #.
    my weight ticket says 4800 #.
    if i subtract 4450 from 4800, i get 350#
    Does this mean i am 350# UNDER-weight?
    just not sure how to interpret the numbers.
    this is all stemming from my rear springs being almost flat, and i am trying tp put the fix into perspective*
    * i know: take junk outta da back !
  20. Aug 3, 2021 at 12:34 PM
    echoboom
    echoboom Well-Known Member
    Los Angeles
    2017 Black TRD Sport
    Does anyone have a preferred tire pressure gauge they would recommend? Not looking for the most hard-core $25 kind; Average price that I’m seeing on Amazon right now is around 12 to 15 bucks. seems a little high, but always curious for something great.
    Thanks
    MGMDesertTaco likes this.
