  1. Aug 23, 2021 at 5:54 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Got my 2nd spindle guesset done for now, still going to make some guessets that go out to the tie rod and leave some room to do a future double sheer heim setup
    JDSmith, TnTHicks, Tacman19 and 5 others like this.
  2. Aug 23, 2021 at 6:11 PM
    MNFinn7300
    MNFinn7300 Well-Known Member
    Erik
    2021 Tacoma SR DCSBV6
    Softopper, Diode Dynamics Fog lights, BD Spot lights
    New placement of one of the bed lights to the top of my Softopper. still need to wrap with electrical tape, but it's a lot brighter having one up top.
    Obligatory picture of the truck with the air dam removed.
    JDSmith, TnTHicks, DAS Taco and 8 others like this.
  3. Aug 23, 2021 at 6:16 PM
    18Tacos
    18Tacos Well-Known Member
    New Port Richey, Florida
    18’ Tacoma SR5 DCSB Silver Sky
    3” lift, 265/70/16 Wildpeak ATs on stock dipped SR5 wheels (for now). Meso stuff (puddle pods, Gasshole, stage 1 taillights) Pro grille, 5% tint, some other stuff
    Thats the nicest looking Tacoma interior I’ve seen.
    DAS Taco, philliam1 and oneinthestink like this.
  4. Aug 23, 2021 at 6:28 PM
    E.T.
    E.T. Well-Known Member
    Los Angeles
    2016 MGM OR TRD AC Field Truck
    Sorry, no. All gases (nitrogen, oxygen, CO2, air, methane, argon, etc.) obey the ideal gas law (PV = nRT). Pressure (P) x volume (V) = amount of gas (n) x a constant (R) x temperature (T). R is the same for all gasses. Heat a gas up in a certain volume and you increase pressure. Chill it down and you decrease pressure.
  5. Aug 23, 2021 at 6:38 PM
    dlb97as
    dlb97as I'm in the Black helicopter you're running from!
    Don
    NE Florida
    2018 Cavalry Blue TRD Pro
    Compiling the list!
    Sorry, yes. Look at the temperature differences that nitrogen expands and contracts at compared to air. We use nitrogen in our aircraft tires for this reason and because oxygen can react with some of the chemicals in rubber.
  6. Aug 23, 2021 at 6:40 PM
    oneinthestink
    oneinthestink How I like it…
    Treasure Valley
    GX 460
    Guy thinks he's a pilot or something. Talking about air. Psshht who needs air. :p
  7. Aug 23, 2021 at 6:45 PM
    nhpoke
    nhpoke Well-Known Member
    jason
    nh
    21 DCLB OR AG
    R is not the same for all gases.
    It's not VASTLY different for N and O (which is 99% of the gases we're talking about), but it certainly isn't the same for everything.
    https://www.engineeringtoolbox.com/individual-universal-gas-constant-d_588.html
  8. Aug 23, 2021 at 6:56 PM
    AY_ARONTRD
    AY_ARONTRD Well-Known Member
    Aaron
    Murrieta ,CA
    2019 DCLB Cement OR 4x4
    Through the hilift back on the swingout today
  9. Aug 23, 2021 at 7:02 PM
    PasoSteve
    PasoSteve Well-Known Member
    Denver, CO
    2020 Tacoma TRD Off-Road Silver
    SCS Ray 10's, Clazzio Leather Seats with bun warmers.
    Nitrogen is used because the molecules are larger. They will not penetrate the rubber as easily. This means you won't lose air as quickly from normal seepage. It typically has more filtration done during the process to remove water vapor which can degrade rubber and corrode wheels. In reality it's just an easy way for the shops to make more money off you. Top it off with a regular compressor.
  10. Aug 23, 2021 at 7:04 PM
    IndyTac
    IndyTac Well-Known Member
    Indianapolis
    2019 TRD OR DCSB w/JBL
    Total Chaos bed stiffeners CaliRaised bed tie-downs CaliRaised 0-degree, bolt-on rock sliders Meso Customs Gas Hole JDM console and dash organizer Ceramic front tint Ceramic windshield coating Ziebart underbody and rust proofing Taco Garage Dashtop Multi-Mount (DMM) Black SR5 Grille Surround Swap Tacos4cheap Grille Badge Redarc Tow Pro Liberty Brake Controller Car Solutions Anytime Camera Mod TacoMods Radio Knobs Desert Does It Seat Jackers
    Ordered my A.R.E. shell. Now I just have to wait 15 to 17 weeks for it to arrive. Backlogs are crazy.
  11. Aug 23, 2021 at 7:16 PM
    oneinthestink
    Treasure Valley
    GX 460
    Damn. Hopefully it comes in sooner, I am seeing some people quoted longer than it ends up taking them, also seeing the opposite....
    IndyTac[QUOTED] likes this.
  12. Aug 23, 2021 at 7:17 PM
    Tacogeorge17
    Tacogeorge17 Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    Looks dope! I have the bdm-4 nmo but I am waiting on my rock lights from Baja designs and they are saying 7 more weeks out on top of the 5 I’ve been waiting
  13. Aug 23, 2021 at 7:18 PM
    IndyTac
    Indianapolis
    He said it could be as soon as 10 to 12, but they’re telling people 15 to 17 as worst case. He seemed to think it would closer to the latter than to the former.
    oneinthestink[QUOTED] likes this.
  14. Aug 23, 2021 at 7:21 PM
    nhpoke
    jason
    nh
    21 DCLB OR AG
    If true, then you should just overfill your tires by 20% using "compressed air".
    Since the oxygen leaks out "more easily" than the nitrogen, the oxygen will leak out leaving your tires filled with 100% nitrogen.
    At higher pressures, if the oxygen leaks out more easily, it will leak even faster.
    I do agree that nitrogen fills are probably better filtered.
    I also agree that it's pretty much a gimmick for shops to charge you more money.
    Nitrogen atoms are technically slightly smaller than oxygen atoms. It's required based on it having a smaller atomic number. Nitrogen has fewer protons. Nitrogen has fewer neutrons. Nitrogen has fewer electrons. It is a smaller atom.
    Neither really exist in their singular form, so now we need to analyze bonds to figure out molecular size, which is slightly beyond my expertise, but differences are going to be miniscule (on the order of 10^-10).
    Benny blanco, MiTacoTRD and robin303 like this.
  15. Aug 23, 2021 at 7:32 PM
    BeatnikFink
    BeatnikFink Well-Known Member
    2021 TRD Off Road
    I finally got my license plate in and put it on
  16. Aug 23, 2021 at 8:52 PM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    :worthless::worthless:
  17. Aug 23, 2021 at 8:58 PM
    BeatnikFink
    2021 TRD Off Road
    It's just a boring plain AZ license plate lol. Haven't decided if I'll do a vanity plate or not on the Taco. My Jeep has Obi Wan and the Mustang I traded was Han Solo. So far every other character of note I've tried is taken so I'm at a loss.
    MGMDesertTaco and ghostleaf like this.
  18. Aug 23, 2021 at 9:19 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    Did you try jar jar? I bet it's available
  19. Aug 23, 2021 at 9:33 PM
    MGMDesertTaco
    Service Arizona website says JARJAR is taken, but J4RJ4R is available...
    N8diggity, ghostleaf and nhpoke like this.
  20. Aug 23, 2021 at 9:45 PM
    stokesrm
    stokesrm Well-Known Member
    Rich
    Murrieta, CA
    2018 Inferno Tacoma TRD Off Road IG: @inf3rnotaco
    Matte Black Tailgate Letters, TRD Pro Grille, SCS Ray 10s, BFG K02 285/75/R16, King Coilovers, Icon AAL, Total Chaos UCAs, Prinsu Roof Rack, Blacked Out Emblems
    @Baja Designs S2 Pro chase lights, wired to the sPOD BantamX.
    Tacomags, ohcjam, TnTHicks and 22 others like this.
