  1. May 28, 2016 at 3:02 PM
    transworldmoto
    transworldmoto Well-Known Member
    Ben
    California Coast
    2016 Access Cab TRD OR 4X4
    So far, so good. The front settled about a half inch so I'm sitting at about 2" front, 2.5" rear, which is fine since when I put my tent and other cargo on the bed rack it evens out
    FireGuy88[QUOTED] likes this.
  2. May 28, 2016 at 3:05 PM
    transworldmoto
    Ben
    California Coast
    No cutting, but I do have a but of rubbing. Now that the front has settled, I may raise it up a 1/2 inch and go with a full deaver pack in the rear. It only runs at full lock/compression so I rarely notice it unless I'm out on the trail. I also have the cmc plates I need to install but it's been hot and I've been lazy. Beer tastes too damn good to work in the heat!
    Gettin Lost likes this.
  3. May 28, 2016 at 3:06 PM
    transworldmoto
    Ben
    California Coast
    Cheers! Minimal rubbing at full lock/compression
  4. May 28, 2016 at 3:51 PM
    Aaronlammm
    Aaronlammm Well-Known Member
    Aaron
    Denver, CO
    2016 Quicksand Toyota Tacoma Trd Off-road
    Hi, so Im new here and I was just wondering if anyone knows how the back spacing and the offset will fit on the 2016 taco? Sorry if it's in the wrong thread.
  5. May 28, 2016 at 3:55 PM
    mrproduxn
    mrproduxn Well-Known Member
    steve
    Retired DoD SE VA
    Tacomas 1987,2000,2008, 2016,2012,2008
    Retired/Hobbyist old as f***
    Here is a good site. My stock wheels are 17 x 7.5 +30 offset and changing to 17 x 8 +10 offset. So the same tire will have more inside clearance and poke out farther for a wider stance.
    https://www.customwheeloffset.com/tire-wheel-backspacing-offset-calculators
    trujeks4x2 likes this.
  6. May 28, 2016 at 3:58 PM
    infernotaco9
    infernotaco9 New Member
    2016 tacoma
    3inch lift. Bfg ko2.
    Does anyone know if 2nd gen and 3rd are using the same AAL?
  7. May 28, 2016 at 4:50 PM
    Hank_Scorpio
    Hank_Scorpio Better keep the egghead. He might come in handy.
    JR
    San Antonio
    2016 BR SR5 DCSB 4X4
    08sprsnke, Tacoma_1121 and Ch78 like this.
  8. May 28, 2016 at 4:51 PM
    Boba Fetty
    Boba Fetty Well-Known Member
    Gen3 Tacoma DCLB TRD OR
    Not the best angle but best I could get with it parked in the in laws drive...
  9. May 28, 2016 at 4:53 PM
    Hank_Scorpio
    JR
    San Antonio
    Had its first scheduled service today, and also debadged. Came out looking clean.image.jpg
  10. May 28, 2016 at 4:55 PM
    Boba Fetty
    Nothing huge, just added a D-Ring hitch insert with a locking pin I picked up autozone. Not sure if anyone else has run into this or maybe if it's a problem I ran into with just this brand of locking pin, but I had to get the class V pin since when I tried the class IV, the locking mechanism was about 1 mm to shallow to fully engage when put through the hitch.
    Not a big deal, class V just has a bit of travel / play in it.
    69TACO16, Frankmig, Tucktuck8 and 4 others like this.
  11. May 28, 2016 at 5:00 PM
    Boba Fetty
    DUDE. Dude....dude that light bar is sick. I'm about to get the 32" double stacked bar that people are putting under the grill insert, which looks really stealthy, but yours is the first roof mounted one that I don't feel looks unnecessarily tall or bulky. Not sure if you already posted details about process / parts, but I'd love to hear what total cost was.
    Thing I like about the grill mounted is that running the harness for it would be considerably easier, and I wouldn't need to worry about the mounts messing up my roof...
  12. May 28, 2016 at 5:01 PM
    TastyTacos
    TastyTacos Active Member
    SoCal
    2016 DCLB OR 4x4
    Today I finally got some much needed dirt on the tires and possibly some custom pin stripes ;) I also came across my truck's 2WD twin when airing back up :D
    TT
    SilverII likes this.
  13. May 28, 2016 at 5:23 PM
    FSUNole
    FSUNole Well-Known Member
    2016 blazing blue Tacoma TRD off road
    Nice rims. Refreshing from the typical rim I see.
  14. May 28, 2016 at 5:26 PM
    Brick_26
    Brick_26 Well-Known Member
    Blaine
    KEDW
    2016 DCSB TRD Sport
    Things and stuff
    Installed my OEMaudio+ Refrence 450Q. Sounds a hell of a lot better than the factory non JBL did.
  15. May 28, 2016 at 5:31 PM
    Boba Fetty
    I definitely didn't try that first...
    See jokes on you. That's the same as having a slip clutch on a drill. Its SUPPOSED to come off under a certain amount of weight...safety feature, ya that's it, it's for safety!
    TacomaMike32, Ch78 and Vbpiper like this.
  16. May 28, 2016 at 5:36 PM
    Boba Fetty
    Does that just bolt into the stock slid spots? No welding? Would love to pick it up if it's something I could knock out myself.
    Muknight likes this.
  17. May 28, 2016 at 6:10 PM
    Boba Fetty
    What did you use to strip it first? I have some great auto soap, a clay bar, wax and sealant, but wasn't sure if there was a proper way of stripping before doing everything else.
  18. May 28, 2016 at 6:27 PM
    Azbadboyz
    Azbadboyz Well-Known Member
    2/2016 Tacoma's one bright white 2nd inferno
    Yep I know I did the same thing
  19. May 28, 2016 at 7:08 PM
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    Don't believe RAD is making the skid plate anymore. Search for "RAD Industries grille" on here and you should be able to get more info.
  20. May 28, 2016 at 7:23 PM
    flesheatingvirus
    flesheatingvirus Well-Known Member
    ABQ, NM
    2016 TRD-OR 4x4AT Access Cab - Magnetic Gray
    Tech Package
    Plugged the holes on the LCAs to stop the howl and added the flags:
