  1. Sep 24, 2021 at 11:21 AM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Meso v5 switchbacks came in today.
    Holy shit that wiring harness... gonna have to take a crack at deciphering it over the weekend.
    Btcomcast and tclavell like this.
  2. Sep 24, 2021 at 11:25 AM
    codenomics
    codenomics Doof Wagon
    Bryan
    DFW Texas
    2019 Black Tacoma SR
    None (yet)
    The SR model has them
  3. Sep 24, 2021 at 11:35 AM
    Otto Mation
    Otto Mation Old on the Outside, Young on the Inside
    West Texas
    2018 TRD Sport 2019 Limited
    It is just the plastic mount that came with it. I have another that I will take a pic of and upload in a minute. I used double sided tape but did not trust it to hold so this is what I did. Just remove the six bolts that hold the cubby to the bed liner. The cubby will slide out where you can install the bracket at your work bench. You can then tape and drill two small holes in the cubby. I used a couple of stainless 10-24 button head screws with stainless lock nuts with nylon inserts with a couple of small fender washers on the back side. That way you can do the entire install from the bench and get it perfectly centered and lined up. The auto grade double sided tape will hold it where you want it while you drill the holes and keep if from working loose over the years.
    Edit: Added pics and the fire extinguisher decals are on ebay. Also you have to put the mount in the back of the cubby, not the bottom as it sits in the truck. Otherwise you can't pull the extinguisher from the mount to get it out. Don't ask how I know that. :):)
    ETBA, devale, echoboom and 13 others like this.
  4. Sep 24, 2021 at 11:39 AM
    ghostleaf
    ghostleaf enjoy the ride
    Hawaii -> PNW
    2020 TRD OR DCSB 4X4
    removed the tacoma badges and the v6 badge.
    super happy with how clean it looks with those badges gone. need to take better pictures later.
    i used a heat gun and fishing line. heat was the key, came off easy and in one piece. then i used the heat gun and my fingertips to roll the badge adhesive off. after that i used a cloth and a some wd40 / goo gone to remove the remaining residue.
    washed the rig and then cleaned up the light surface swirls i had made with chemical guys scratch and swirl remover. (i had used it to take out some light surface stretches from where i took off the TRD bed stickers months ago and it worked great)
    devale, TnTHicks, Soul Surfer and 7 others like this.
  5. Sep 24, 2021 at 11:48 AM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    Install was a success. Pretty cool to have proximity unlock included.
    MNGTaco, devale, TnTHicks and 4 others like this.
  6. Sep 24, 2021 at 11:56 AM
    LtWiggle
    LtWiggle Active Member
    Kansas
    2019 TRD OR DCSB
    Toyota called me to schedule the 3rd break light recall on Tuesday so I took it in this morning. At least they are being proactive about it.
    Soul Surfer and 907rx7 like this.
  7. Sep 24, 2021 at 12:00 PM
    Tacospike
    Two Trucks
    Try not to over think it.
    Just a plug to the turn signal
    and some DRL power wires. High / Dim DRL wires
    E.T. and tclavell like this.
  8. Sep 24, 2021 at 12:02 PM
    scobelA
    scobelA Active Member
    Scoobs
    Florida Panhandle
    2021 Mag Gray TRD Sport
    Whoa that looks super clean. #goals. What kind of tires are those?
    ghostleaf[QUOTED] likes this.
  9. Sep 24, 2021 at 12:06 PM
    ghostleaf
    Hawaii -> PNW
    i went with the falken wildpeak 265/75r16 and they’ve been great for me.
    still on stock OR suspension so didn’t want to go bigger than that tire size.
  10. Sep 24, 2021 at 12:06 PM
    tjb1
    tjb1 Well-Known Member
    2021 Tacoma TRD Sport
    What are the benefits to this over the stock headunit?
  11. Sep 24, 2021 at 12:33 PM
    ArmyGreen4x4
    ArmyGreen4x4 Active Member
    2021 Trail Edition Tacoma Army Green
    -Removed Bed Cooler and Storage in favor of more bed space and OEM mat. -OEM bed lights installed. -LED interior light installed. -OEM tube steps installed -OEM bed step installed -Air Dam Removed -TRD Skid Plate Installed -OR Grille Installed -Sill Protectors Installed -TRD Pro Headlight Swap w custom wire harness from @PuppyPunter -Clazzio Leather Seat Covers Installed -Rear Molle Panel -Jerry Can/Water Can Mounts -Diode Dynamics SS3 Pro fogs in Amber (Backlit) Wish List: -TRD Lift Kit or Icon Lift -Interior Chrome Delete
    -Swapped limited grille for OR Grille (personal favorite)
    Took about 15 minutes carefully done to ensure no broken clips. Very happy with the look and the Dog approved too. Cost me $50 for the OR grille and if anyone wants to buy my limited grille pm me.
    -Installed Door Sill Protectors
    Also very easy just cleaned up surfaces and applied the protection stickers using “dry” method. Happy to protect the sills which had already sustained some scuffs and scratches. Looks like it was a factory option on some models. $30
  12. Sep 24, 2021 at 12:34 PM
    VoodooBluTaco12
    VoodooBluTaco12 Well-Known Member
    Dylan
    2021 Voodoo Blue SR5
    Been busy so sort of a later post but let’s see if I remember everything! 1) Viper Cut and CMC 2) Prinsu Rack and Apache Case Mount 3) 20% ceramic tint all around 4) Meso Dual Color Map Lights 5) Vinyl wrap of hood and mirror caps (thanks to a buddy of mine) 6) Went on my first off-road trip this past weekend to Packsaddle Lake 7) Hit 10k miles!
    devale, TnTHicks, tomgru and 14 others like this.
  13. Sep 24, 2021 at 12:36 PM
    ghostleaf
    Hawaii -> PNW
    huge improvement, looks great! :thumbsup:
    …and give that pupper all the cuddles.
  14. Sep 24, 2021 at 12:46 PM
    Scotfree
    Scotfree I drive slow
    2021 sr 4x4 2.7
    Genuine stuff…
    devale, TnTHicks, Soul Surfer and 3 others like this.
  15. Sep 24, 2021 at 12:47 PM
    Blacked out taco
    Blacked out taco Certified mall crawler
    James
    Arlington, Wa
    19 tacoma
    Dirty5’s club. Need to get new wheels my -38 scs f5’s are rubbing too much :bananadead:
    devale, TnTHicks, playdixie and 11 others like this.
  16. Sep 24, 2021 at 1:08 PM
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Teardown, AGAIN!!!:annoyed:
    devale, TnTHicks and playdixie like this.
  17. Sep 24, 2021 at 1:09 PM
    Blacked out taco
    James
    Arlington, Wa
    19 tacoma
    full bumper?
  18. Sep 24, 2021 at 1:19 PM
    Otto Mation
    West Texas
    Well, I agree if you mean with a fire extinguisher. My son watched the car in front of him on I-10 in West Texas lose control and run off the road, hit a rock bank, then rolled and caught fire. He along with several other cars pulled over and jumped out and were trying to remove the unconscious driver from an upside down car that was on fire. One of the guys that pulled over to help had a fire extinguisher and was able to put the fire out and my son was able to cut him out of the car. There is no doubt that they saved his life and if one of them did not have a fire extinguisher, I am not sure that would have been possible. I vowed that day to always carry a fire extinguisher and a trauma kit in my trucks.
    Edit: I found the pics.
    482128e9-93bf-4d24-a426-4a7ef8a66b1e.jpg 8b87ef0f-ca58-47c7-97da-810e7f703d41.jpg 1c5ecdb7-a615-4e09-b171-31fc03b2ef06.jpg
    sierra141, echoboom, MAS and 25 others like this.
  19. Sep 24, 2021 at 1:25 PM
    kas2828
    kas2828 Well-Known Member
    Austin
    Arizona
    2020 TRD Off-road 4x4 DCLB
    Great looking tacoma. Welcome to the 35 club. I hope to be there in the next year or two.
  20. Sep 24, 2021 at 1:37 PM
    BIG EYE
    BIG EYE Well-Known Member
    David
    San Diego, CA
    Sold
