  1. Oct 16, 2021 at 8:20 PM
    matas2u
    matas2u Active Member
    4x4 trd sport 6”Lb
    Bilstein 5100 all around Spc UCA 17x9 0 offset Raceline 947B
    King suspension installed
    airmax233, Goatfrog, MAS and 20 others like this.
  2. Oct 16, 2021 at 8:26 PM
    Rabbitguy91
    Rabbitguy91 Well-Known Member
    Southern Oregon
    2020 DCSB 6MT
    Damaged it! Not me per se - but I was rear ended waiting for a protected left turn. Of course, the other driver had no proof of insurance and no current license - good times. Thankfully it was low speed and no one was injured. I have it recorded on my dash cam and at first glance the truck looks “fine.” However, a closer look reveals damage to all three of the OEM bumper pieces. Going to have to take it to the shop and get it checked out.
  3. Oct 16, 2021 at 8:29 PM
    Jeff Dartfrog
    Jeff Dartfrog Well-Known Member
    Jeff
    Chandler AZ
    2019 Cavalry Blue TRD Off Road
    My son-in-law & I were working on the Taco today. We did the OEM tailgate lock and Matt Gecko bed lights plus ran power to the bed so I can add a 12v Blue Seas System power center.
    While he was under the truck he found the following tool jammed in between 2 leafs of the drivers side leaf springs!!! How in the hell could that happen? I’ve only had the truck a few months. This is the first time under the vehicle. Surely, someone must’ve realized they misplaced their “pick” tool!!
    Unbelievable!!!!
  4. Oct 16, 2021 at 8:35 PM
    Rabbitguy91
    Southern Oregon
    2020 DCSB 6MT
    35E90228-83C7-485B-BC74-BDB62531EBB2.jpg 9B9F2287-DE64-4322-989F-E736765BE4A2.jpg
    The damage isn’t very visible but I looked under the bumper and there are some cracks in the bumper cover pieces and indents in the center black piece. I am going to look in to my uninsured motorist coverage; I hope I am not on the receiving end here. I’m glad today I decided to leave a half an hour early for the kids soccer game, otherwise he would’ve been late.
    /s
  5. Oct 16, 2021 at 9:16 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Thats like a $30 tool too. Good score :)
  6. Oct 16, 2021 at 9:16 PM
    Cereal_killer
    Cereal_killer Well-Known Member
    Dan
    '18 Off-road, ‘96 V6
    Yeah
    Rock lights, I ran them on thir own relay triggered off the bed light switch circuit. Added a GM/Delphi 2 relay weather sealed box (2nd relay not yet wired but is planned out for some other cool shit) and those $26 Amazon rock lights I heard about here.
    The box is just zip tied there to the clutch rez for now, I forgot to buy the mount for the box so that's coming along with more wire and parts for that other mod I mentioned. All electronic parts and wire from Ballenger Motorsports!
    Edit: cooler photo!
    Bedawson, Goatfrog, MAS and 7 others like this.
  7. Oct 16, 2021 at 9:27 PM
    Jeff Dartfrog
    Jeff
    Chandler AZ
    Snap-on brand!!
  8. Oct 16, 2021 at 9:28 PM
    tcoffin
    tcoffin Well-Known Member
    2017 Tacoma
    Yeah, how did you do that
  9. Oct 16, 2021 at 9:30 PM
    5nahalf
    Erik
    Minnesota
    So I know whos that tool is. The tech that did you fuel pump recall stuffed it into the leaf for "storage" while he was putting the tank back up and forgot to get it back out. That long hook is perfect for removing the clips that hold the fuel lines onto the pump when they drop the tank.
    Goatfrog, Chako, MIDTNTACO and 3 others like this.
  10. Oct 16, 2021 at 9:35 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Does the a not have the pass through third brake light window?
  11. Oct 16, 2021 at 10:18 PM
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    I did the same.
    BobbyTacoTRD[QUOTED] likes this.
  12. Oct 16, 2021 at 10:19 PM
    afgixxer
    Tennessee
    really? Mine are very bright and my map lights definitely don’t flash. Make sure your dome light is in all the way.
    usmc2msu[QUOTED] likes this.
  13. Oct 16, 2021 at 10:46 PM
    Jes963
    Jes963 Well-Known Member
    Fontana CA
    2018 Tacoma Trd pro
    Installed blacked out turn signals
    Goatfrog, MAS, FlywtrJoe and 8 others like this.
  14. Oct 16, 2021 at 10:47 PM
    baldbeardedtaco
    FL
    I sold the fiberglass cap and I feel a bit naked (close to 3 yrs since I’ve seen the bed rails). Washed it before seller arrived and helped the guy install and wired him up. Had to remove the stuff in the bed (bags/cases) until I get the smartcap installed. Unfortunately had some roof panel damage in transit and it’s waiting to be picked up so the replacement can be processed and sent out. Went from 2 caps to none just like that. Called my SA to schedule the 3rd brake service campaign next Saturday while I’m topless.
    next day I took my da and some compound to the rear window to tackle the horrendous water spots. Will put on some c4 to the trim and the turtle wax/hybrid ceramic spray on the glass tomorrow. I pulled the header rail and front header to visualize the tonneau plugs (have had for over 2 yrs but wasn’t going to remove the cap for just this). When I put on the fiberglass cap it came with square foam pads for the header but likely have to remove for the plugs. Marked out the cut line and heard some unpleasant noises on side bed rail cap removal. 1st night to drop 10-20 degrees so I stopped and will wait till tomorrow when it heats up hopefully. I’m not a hardcore leak inspector, I didn’t care before and won’t here either but since I had the plugs and it fills that spot nicely that’s about all I’ll do (no goop, no silicone, no butyl/putty for me).
    MAS, Rabbitguy91, TnTHicks and 3 others like this.
  15. Oct 16, 2021 at 10:58 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
  16. Oct 16, 2021 at 11:06 PM
    VTCAL
    2021 Sport
    The WEATHER here will do worse than that overnight!
  17. Oct 17, 2021 at 3:17 AM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    A minor lift was the last of a list of things I wanted to do. Not sure what's next other than driving everywhere and enjoying myself
    Goatfrog, TVphotog97, MAS and 19 others like this.
  18. Oct 17, 2021 at 5:37 AM
    El Cucuy
    El Cucuy Well-Known Member
    Paul
    2020 TRD PRO Super White "CHINGAO"
    stockish for now
    $3.15 is the average here in the FL panhandle but I manage to get just under $3 at SAMs or on base when I go to work
    robin303 likes this.
  19. Oct 17, 2021 at 6:04 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    Nice!
    codyjphoto[QUOTED] likes this.
  20. Oct 17, 2021 at 7:14 AM
    banjoGrampa
    banjoGrampa Well-Known Member
    David
    East Tennessee
    2019 TRD Sport 4x4 DCLB
    OME/ Bilstein 2" lift, Deaver aal Pro/Heritage grill TRD PRO wheels w/ Goodyear Ultraterrain 265/70/17 Westin HDX DROP NERF STEP BARS LEER 100R shell Custom bed platform High flow air filter/air accelerator Marine Corps graphics A-Premium mud guards Emblem black-out Rove R2-4K Dash cam
    Install step nerf bars or sliders.
    gabbo2112 likes this.
