  1. Dec 11, 2021 at 12:39 PM
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    Oh and it use to see winters I just stopped winter driving it last year, the liquid road salt they use around here eats everything and it’s just not worth driving a new vehicle in winter even if you undercoat them, the shits just so abrasive. The welds around my cab mounts and my lower control arms, front axles, and just about every component in the area of the front tires is flaking paint and showing rust as bad every other generation of Tacoma’s.
    Rottencotton[QUOTED] likes this.
  2. Dec 11, 2021 at 12:48 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    Check out the weather forecast for the Eastern Sierras. Kirkwood for example. Big doings coming up this week ahead!
  3. Dec 11, 2021 at 12:53 PM
    Faustc1
    Faustc1 Well-Known Member
    Army Green 2020 TRD PRO
    Thinking outside the box i salvaged two pieces of already made scrap metal. Made a rack and added some hardware for tiedowns. I love saving money.
  4. Dec 11, 2021 at 1:01 PM
    VTCAL
    2021 Sport
    That looks like "the PITS"! ;-)
    xMaverickx[QUOTED] likes this.
  5. Dec 11, 2021 at 1:02 PM
    VTCAL
    2021 Sport
    Your expressed attitude won't help much in court.
    jeosbor1 and JDSmith like this.
  6. Dec 11, 2021 at 1:03 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Thankfully it's evidence that counts. :thumbsup:
    BEAR_KNIFE_FIGHT likes this.
  7. Dec 11, 2021 at 1:07 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
  8. Dec 11, 2021 at 1:13 PM
    Tony77
    Tony77 Well-Known Member
    Anthony
    NNJ
    2020 TRD OR 4X4
    Had it done. T3 services Manahawkin NJ
    TnTHicks, playdixie, markram and 2 others like this.
  9. Dec 11, 2021 at 1:14 PM
    bluelinetaco
    bluelinetaco Well-Known Member
    North Cali - Yay Area! (707)
    2019 TRD Pro VooDoo Blue
    COOL Stuff I can't afford . . . But I bought anyway!
    how do you like those jba’s? I’m looking into them for my pro lift.
  10. Dec 11, 2021 at 1:14 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Getting sick of my battery being low or dead due to lack of driving (I work from home, and its not cold enough for ice fishing season) So I am installing a charging port to the front.
    Here I am testing it through the grill before I make the full harness, then I am going to mount it right next to the fog light I think, though I am going to check some other locations in the front too.
  11. Dec 11, 2021 at 1:15 PM
    treyfive
    treyfive Well-Known Member
    Brandon
    New York
    2017 PEARL BLUE TACOMA TRD OFF ROAD
    Nice !
  12. Dec 11, 2021 at 1:22 PM
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
    Took the Taco in for the final ToyotaCare visit. Oil Change and cabin filter change. Last of the free shit...
  13. Dec 11, 2021 at 1:22 PM
    OffroadJet
    OffroadJet Well-Known Member
    Sebastian, FL
    2018 Offroad 4x4 - Manual
    how old is your battery?
  14. Dec 11, 2021 at 1:35 PM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    Never thought of that. :rofl:
  15. Dec 11, 2021 at 1:37 PM
    5nahalf
    Erik
    Minnesota
    Under a year, Toyota replaced it last year when it was -20 degrees out for 2 solid weeks. Problem is the truck will sit in the cold for 2 weeks without driving.
  16. Dec 11, 2021 at 1:46 PM
    xMaverickx
    Jeremy
    I had the same problem after my truck sat all last winter, and again in the spring when it would sit for a week or two between adventures. A circuit breaker between my accessories and battery helped greatly with the short term parking. However when I put the truck away this winter I’m just going to remove the battery and put it in the garage.
    5nahalf[QUOTED] likes this.
  17. Dec 11, 2021 at 1:51 PM
    5nahalf
    Erik
    Minnesota
    Ok, new location. I am going to make a mounting plate from HDPE (sheet plastic) that clips into the holes that are there for the rubber liner. Should hold it pretty solid and out of view, its a weather proof plug, but its also filled with dielectric grease too. Plus now I can put the charger on the upper control arm or tire and leave it out in the rain.
    Just got to put the inline fuse in also.
    TnTHicks, playdixie, RCrumb and 6 others like this.
  18. Dec 11, 2021 at 1:53 PM
    xMaverickx
    Jeremy
    I also replaced the OEM battery with an AGM from Canada energy, still a 24F and having 3 relays with constant power was still enough to drain it in two weeks. They got it back to full strength for me and I since put that circuit breaker in. Something I should have probably had between the battery and accessory fuses which I located all into one aftermarket fuse box. I don’t think the intention of the breaker is to pop it every time the trucks going to sit but that’s what I use it for.
  19. Dec 11, 2021 at 1:55 PM
    5nahalf
    Erik
    Minnesota
    My challenger and bmw both have quick disconnects on the batteries due to sitting for 8-10 months a year. I did think of putting a high output relay in for my audio system to cut power when the truck is off, but Im not sure if cutting power might harm my DSP.
  20. Dec 11, 2021 at 1:58 PM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Installed the caliraised behind the grill light bar brackets. Hidden lightbar bracket wont work anymore without some modification, it was just easier to get new brackets. I also bought the sdhq dual behind the grill brackets in case the caliraised didnt work.
    I used the third slot on the new brackets but filled the holes a little deeper to get the bar a bit further back from the back of the grill. Perfect fit. And if you wondered, its still bright as hell even with some small bits of the grill in the way.
    Grill can come on and off with the sso bumper no problem. With the light bar in there, it makes it an issue removing the grill. I trimmed off about an inch of material from the inside of the bottom of the grill. Some long useless piece of plastic gets trimmed, and no problem with instillation now. I hate stopping to take photos , sorry.
    But, i wouldnt hesitate yo tell anyone to buy the behind the grill brackets, you still get plenty of light.
    20211211_163103.jpg 20211211_163050.jpg 20211211_163041.jpg 20211211_163029.jpg
    TnTHicks, japjoe7, playdixie and 6 others like this.
