  1. Dec 13, 2021 at 3:31 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    I have a set of 720 lumens XPRs siting in my garage catch all drawer. I'll sell them to you on the cheap, they have never been out of the box. PM me if you want them. These are the more expensive ones on the site.
    TnTHicks likes this.
  2. Dec 13, 2021 at 3:49 AM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Removal of the bolt.
    For the passenger side you will have to bend the sheet metal slightly towards the tire. You will not damage anything, just make sure you are only grabbing the sheet metal, not anything that runs behind it. Also on the passenger side you will have to remove a line form a clip on the back side of the sheet metal.
    Driver side you will have to move/massage some lines, hose clips and battery cables form the lower left hand side of the battery (lefthand side facing the battery, like you standing in front of the truck looking at the battery.) Pulling the bolt forward while gently moving the UCA will help. If you can get a punch in the rear most mount hole of the UCA and tap it in with a hammer, that will help also.
    to put the bolts back in, I get them started with a long punch from the front, doing a little tap in then checking in the wheel well for placement, while installing the washers, once you have the front UCA mount in the rest is pretty much smooth sailing. Just have to get past the tight spots on the driver and passenger at the sheet metal.
    CemenTRDgen and Btcomcast like this.
  3. Dec 13, 2021 at 3:57 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    I'm never in the back so I haven't paid any attention. I'll check when I leave for work.
    afgixxer[QUOTED] likes this.
  4. Dec 13, 2021 at 4:46 AM
    huskcummerbund
    huskcummerbund Well-Known Member
    2020 TRD-OR MT
    You do know I answered that exact question 6 comments later, right?
  5. Dec 13, 2021 at 5:18 AM
    Jammers1971
    Jammers1971 Well-Known Member
    James
    2019 Tacoma TRD Off-Road 4x4
    3.5 lift, 315/75-16, DIY hybrid front bumper, skids, sliders, ditch lights, hood struts, tailgate lock, bed rack, custom exhaust, horn meant for an actual truck, neoprene seat covers
    Yup, have 1.25" spacers on it.
    toku58 and CemenTRDgen[QUOTED] like this.
  6. Dec 13, 2021 at 5:30 AM
    Jammers1971
    James
    1.25" spacers and Tuff Country UCA's.
    The ball joint boots that come with them don't fit the ball joint, so I'm either sourcing my own or putting the JBA's on. But the Tuff Country's do give a LOT of caster. AZTP was able to dial in 5deg with the alignment.
    Def check out Arizona Toy Pros, they were extremely knowledgeable, helpful, and hit the mark on the alignment. Have a quality alignment rack and was fast and efficient. My alignment was WAY out due to the lift/UCA's, he did align twice, once to get it close enough to spec to read, once to dial it in.
    Call as soon as you are ready to book alignment though. Alignment appointments are scheduling 2-3 weeks out currently.
    Ryuguyu51890 and kas2828[QUOTED] like this.
  7. Dec 13, 2021 at 5:56 AM
    Kronk21
    Kronk21 IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
    Nice that is a fantastic setup!!
  8. Dec 13, 2021 at 6:03 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    And bounce while in that position?
  9. Dec 13, 2021 at 6:40 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    Of course they’ll bounce because they don’t fold all the way down without taking off the headrest
  10. Dec 13, 2021 at 6:46 AM
    huskcummerbund
    2020 TRD-OR MT
    So I got excited that I might be able to make the headrests fit better behind the seat by folding down the metal bits and ran outside instead of doing work to do that.
    Then I realized the folding function is part of the seat and not the headrest. I'm sad now.
  11. Dec 13, 2021 at 7:29 AM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    That puts James Bond's flipping plate to shame...
    E.T.[QUOTED] likes this.
  12. Dec 13, 2021 at 7:55 AM
    LkdTaco
    LkdTaco Well-Known Member
    2019 TRD PRO
    I am not on here a lot, but saw this pic. You have a build thread for your truck? Looks sweet from the back!
    Friar_Fresh likes this.
  13. Dec 13, 2021 at 8:06 AM
    ryanvar42
    None
    he has a channel too. just click his name and follow the links etc
  14. Dec 13, 2021 at 9:14 AM
    bc.trd
    bc.trd Active Member
    I used a pry bar, no channel locks and it looks fine. No ripped metal and no issues taking it out. Bolt installed back in same position.
    TnTHicks, JDSmith and AmateurTaco1313 like this.
  15. Dec 13, 2021 at 9:14 AM
    charklos
    charklos Well-Known Member
    2021 TRD Sport
    Installed an AVS hood protector, compliments of
    @SoCalSport
    +15hp!
    RCrumb, TnTHicks, FireMedk and 12 others like this.
  16. Dec 13, 2021 at 9:20 AM
    MNFinn7300
    MNFinn7300 Well-Known Member
    Erik
    2021 Tacoma SR DCSBV6
    Softopper, Diode Dynamics Fog lights, BD Spot lights
    Picked up a multimeter and some fuzes from harbor freight. Not exciting but another step towards building my my DIY capacity.
    JDSmith likes this.
  17. Dec 13, 2021 at 9:28 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Looking good!
    ArmyGreen4x4[QUOTED] likes this.
  18. Dec 13, 2021 at 9:49 AM
    Jyruiz
    Jyruiz Well-Known Member
    Juan
    La Mirada, CA
    2021 DCLB Off-Road 4x4
    Hit 10k miles so I changed my in cabin air filter.
    JDSmith and markram like this.
  19. Dec 13, 2021 at 10:32 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    Honolulu, Hawaii
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I’m at 28k and I haven’t changed mine yet lol
  20. Dec 13, 2021 at 10:37 AM
    treyfive
    treyfive Well-Known Member
    Brandon
    New York
    2017 PEARL BLUE TACOMA TRD OFF ROAD
    where do you put the micro SD card? do you have to take the unit out? Just checked my software and it's from 2016..Think I may upgrade
