  1. Feb 6, 2022 at 6:19 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i figured the baffle is more to keep it from sloshing around on the trails if it starts to fill. (should empty it before the trail to have as little oil in there to begin with) but it also increases the surface area of the inside of the can that the vapors can latch onto and begin to gather up as droplets. if it is a very light mist, most of the flow will go in one side and out the other, preventing the can from doing much good so having this helps. Other ideas i've seen are stainless steel wool pads like this;
    Both options are stupid cheap - but figured to use a stainless streel drain mesh to see if it does what i think it will do.
  2. Feb 6, 2022 at 6:20 PM
    rgljr831
    rgljr831 The less you bet, the more you lose when you win
    Ron
    Monterey/Pacific Grove
    2021 TRD Off Road 4x4 DCSB Not_Silver Bullet
    285/75/r16 Nitto Trail Grappler M/T’s, Extang 2.0 hard tonneau tri-fold. Billstein 5100’s front/rear with OME 886 coils and Headstrong off-road 3 leaf progressive AAL. All speakers replaced with Kicker CS Series. BulletPoint Taco Bar with stubby CB mic holder and two-way FRS/GMRS radio holder. Uniden PRO505XL 40 ch CB. RCI engine and transmission skid plates. RCI sliders. Garmin Mini Dash Cam 2. CMC by Milogen Fabrication.
    Absolutely! :thumbsup:
  3. Feb 6, 2022 at 6:27 PM
    huskcummerbund
    huskcummerbund Well-Known Member
    2020 TRD-OR MT
    In my opinion, Automatic High-beams is synonymous with auto-dimming headlights. I believe oostroma mistook my response as referring to automatic headlights instead of automatic high-beams. It's perfectly normal to get those two confused in a forum setting where we all generally try to anticipate at least some variance in terms.
  4. Feb 6, 2022 at 6:28 PM
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    Got 1/4 of the way done with predator step delete .... :taco:
    Took a nice bite on the fender flare ... thankfully didn't catch it with the tire that would've sucked.
    Wifey was in the truck when it happened so real sliders should be an easier sell now :rofl:
  5. Feb 6, 2022 at 6:32 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Looks like a couple of you have stumbled on a neat life hack today...
    Step 1: tell the wife you want [mod x]
    Step 2: take the wife wheeling
    Step 3: break off whatever [mod x] will/would have replaced while wheeling
    Step 4: "well dangit honey, it looks like I just don't have a choice now..."
    Step 5: install [mod x]
  6. Feb 6, 2022 at 6:33 PM
    LiquidArrogance
    2021 SSM Sport 4x4
  7. Feb 6, 2022 at 6:37 PM
    huskcummerbund
    2020 TRD-OR MT
    In general the point of a catch can is to reduce the amount of oil vapor making it into the intake charge on an engine that uses a positive crankcase ventilation (PCV) system. This is especially useful with engines that use direct port injection, like the 3.5L 2GR-FKS, since there is no fuel coming down the intake runners to wash the back of the intake valves off. The oil vapor starts to cake up on the back of the valves and reduce performance after a while but the catch can helps to reduce that. I'm not sure if the 2.7L version is direct injected or not though.
    davidstacoma and Shveet like this.
  8. Feb 6, 2022 at 6:42 PM
    Stigman
    Stigman Well-Known Member
    2020 Cement TRD OffRoad
    Not talking about the catch can. I understand the benefits. Talking about the custom mesh that was installed.
    Shveet likes this.
  9. Feb 6, 2022 at 6:43 PM
    huskcummerbund
    2020 TRD-OR MT
    Yeah, steps in general are not going to survive long when flogging the truck sufficiently. IMO sliders are the only way to go if you're actually going to drive the truck the way it looks like it should be driven. Looking over options for sliders though I'm not all that impressed with most of the options available. I may just wait until I break mine off then build something stupid skookum.
  10. Feb 6, 2022 at 6:46 PM
    huskcummerbund
    2020 TRD-OR MT
    Ah, my bad. I misunderstood the question. In that case, I doubt the mesh will have much of an effect due to the lack of surface area. If I was doing this, and I might now that I'm thinking about it, I would look at going the same route that Shveet suggested with the stainless steel wool. Combining the two would keep the wool at the top of the canister and might produce the cleanest air for the intake. I think that would be the Cockford Olie.
    Stigman[QUOTED] likes this.
  11. Feb 6, 2022 at 6:47 PM
    dleriche
    dleriche Wanee Warrior
    D.J.
    Leander, TX
    2019 White ORD DCSB AT
    Nice. Just ordered my full plate bumper this week. Mind if I ask how long yours took to arrive? Just so I can set some reasonable expectations.
    BudFriendguy[QUOTED] likes this.
  12. Feb 6, 2022 at 6:47 PM
    Rottencotton
    Rottencotton Well-Known Member
    Stinkin Rincon
    Superwhite 2019 Tacoma SR 4x4
    I bought some of these but after putting one in the can I decided it took up too much space and took it back out. It collects oils as it is.
    Shveet[QUOTED] likes this.
  13. Feb 6, 2022 at 6:50 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    dont use the fiberouse version of the wool. good chance the loose fibers might get brought in on the intake side and into the rest of the air intake and that'd be a disaster for another day.
    But otherwise, i've slowly looked into what the Subie guys do with their turbo setups (can apply the same logic for our use case). lots of info there and it's just figuring out what is the "best" method at the end of the day.
    My "issue" with the wool is that it will reduce the volume inside the can (there is still lots of room in there) it's simply remembering you wont have the full capacity.
    Technically could compensate with a larger reservoir/ can.
  14. Feb 6, 2022 at 6:51 PM
    huskcummerbund
    2020 TRD-OR MT
    I mean, you could take a page out of Oscar's book:
    https://www.youtube.com/watch?v=FZ4qeJly1g0
  15. Feb 6, 2022 at 6:54 PM
    ColdTaco49
    ColdTaco49 Has a well-used member
    Fairbanks, Alaska
    2022 TRD Off Road DCLB Lunar Rock
    Treated my truck with a little respect and moved my weights from the garage to the basement so I could park inside. should be able to save on my electricity bill too since I’m not having to plug in overnight in the winter. Double bonus now my wife doesn’t have an excuse to not workout.
  16. Feb 6, 2022 at 6:55 PM
    huskcummerbund
    2020 TRD-OR MT
    Agreed. I think the beefier steel wool (not sure how the wire thickness is rated, but I'd go with "thick") would be sufficiently robust enough to handle that. After a couple times draining the tank I'm pretty sure I'd get a good feel for the appropriate draining intervals, especially if I'm measuring the discharge each time.
  17. Feb 6, 2022 at 6:59 PM
    BudFriendguy
    Zak
    97 days from ordering to shipping. Another ~7 days for delivery.
    Not too shabby all (COVID) things (COVID) considered.
    dleriche[QUOTED] likes this.
  18. Feb 6, 2022 at 7:09 PM
    dleriche
    D.J.
    Leander, TX
    Thanks for answering. Very reasonable. Good call with that color matched trim.
  19. Feb 6, 2022 at 7:21 PM
    ironicallyjesus
    ironicallyjesus Well-Known Member
    Jesus
    Atlanta, GA
    2021 Silver SR SX 3.5L ACLB
    The screw for the gas cover came out less damaged on yours than mine haha. Good job
    Adk46er[QUOTED] likes this.
  20. Feb 6, 2022 at 7:50 PM
    VTCAL
    VTCAL Well-Known Member
    2021 Sport
    rotated tires changed oil threw out the old air freshener.
    It must be nice to live where there are no deer waiting to jump out from the ditches.
