  1. Feb 22, 2022 at 9:39 PM
    skierd
    skierd Well-Known Member
    David
    Fairbanks, AK
    2021 F150 XL STX Screw 4x4 2.7
    wireless CarPlay is tits.
    rgljr831 likes this.
  2. Feb 22, 2022 at 9:49 PM
    Duckinatruck
    Duckinatruck Well-Known Member
    2019 OR DCLB
    Are those the stock fenders? They look wider, like a Raptor fender.
  3. Feb 22, 2022 at 9:53 PM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
    Does that also support heated mirrors? I'd pick them up just to see if I preferred the curved edge to the separate mirror on the SpotterMirror setup.
    I had a 2001 Jetta with blue tinted mirrors and it helped big-time with jerks and their brights, plus made me feel fancy driving my knockoff Audi A4.
    Not a huge fan of the giant blinker myself, but could learn to love it if the mirror was dope.
  4. Feb 22, 2022 at 9:57 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    You could always not plug in the blinker
  5. Feb 22, 2022 at 9:57 PM
    MGMDesertTaco
    Nice upgrade, congratulations! :cool:
  6. Feb 22, 2022 at 9:59 PM
    BudFriendguy
    Zak
    Don't you come at with that common sense bullllshit!
    usmc2msu, dleriche, Underdonk and 6 others like this.
  7. Feb 22, 2022 at 10:07 PM
    Coldies
    Coldies Well-Known Member
    Travis
    San Diego
    2020 TRD Off-road 4x4 DCSB
    No, they’re McNeil +3 fiberglass I put on and had painted. I’ve got +5’s I still need to put on cause I’m rubbing still on bigger stuff along with my bedsides but fiberglass is a major pain in the ass to install so I’m lagging
  8. Feb 22, 2022 at 10:09 PM
    Duckinatruck
    2019 OR DCLB
    Well, they look really good.
    rgljr831 and Coldies[QUOTED] like this.
  9. Feb 22, 2022 at 10:17 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    Yes, heated mirrors.
  10. Feb 22, 2022 at 10:24 PM
    bimmerlev
    bimmerlev Well-Known Member
    Lev
    Los Angeles, CA
    25' Tundra
    I definitely hear a hum... I got Revolution gears, which are supposedly quieter then Nitro... It's not loud enough to bother me considering my roof racks wind makes more noise hahhaa but I probably wouldn't want it any louder then it is. I have very sensitive hearing with cars (used to be a racecar mechanic) so my opinion may be different...
    ThisIsCovy[QUOTED] and rgljr831 like this.
  11. Feb 23, 2022 at 1:53 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Installed the curt 7pin to 5pin trailer harness plug and if it works like I’m hoping I’ll be tapping into for switched power for the Garmin mini2. The garmin hardwire kit needs constant, switched and ground and I already have 10awg ran to the back for the fridge and hoping this trailer plug tap would keep me from running a single wire back for switched. I went with the 5pin over 4 for no reason other than I already have a 4 so why not have a 5 instead of 2x 4pin. Anyone have thoughts on fusing the switched wire tap to the trailer plug (was my first thought) or if it’s redundant? The hardwire kit has 1 inline fuse already but I think for the constant wire only.
    Went a bit extra/over the top on some gatorbacks- But having an issue on the rear brace brackets not lining up. Waiting for a response to secure that last mounting bolt. I like them, heavy duty, looks good, more coverage but not a good start when the bracket looks off and not lining up with the holes
    TnTHicks, playdixie, markram and 6 others like this.
  12. Feb 23, 2022 at 3:29 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    They do support heated mirrors, they work great. Install was a breeze. Only two wires need to be spliced, you would be tapping into the factory blinker wires in your mirror now. They have several options you can those from. The built in turn signal is in no way blinding as someone mentioned earlier. I love mine.
    Here is the install video.
    https://youtu.be/DGt3_QJYz1s
    TnTHicks, Impoy47, playdixie and 8 others like this.
  13. Feb 23, 2022 at 6:06 AM
    fullsend420
    fullsend420 Member
    Palo Alto, CA
    2017 Tacoma TRD OR DCLB MGM
    TRD Air Intake TRD Cat Back Exhaust System TRD Grille TRD Skid Plate SnugTop XTR Gen 2 Cap w/ (full) BedRug WeatherTech Side Window Deflectors Headstrong’s Bilstein 5100/Coil Kit w/ Dakar’s - Bilstein 5100s - OME 888 Coils - OME Dakar Leafs - Heavy Duty - OME Carrier Bearing Drop Bracket - Light Racing UCAs Method Race Wheels 705 BF Goodrich KO2 LT285/70R17 Yukon 4.88 w/ Sierra Master Install Kits Hypertech Speedometer Calibrator
    Advanced Trucks, Inc. in Morgan Hill. High praise for this shop. They’ve done all the work on my truck. Superb customer service and quality work. Michael Goulart is the guy to talk to at ATI.
    Want part #s?
  14. Feb 23, 2022 at 6:51 AM
    DesertTaco21
    DesertTaco21 Well-Known Member
    Kyle
    2021 Bule Tacoma TRD Off-Road
    None yet
    Clean wiring! You should be fine with the one fuse already there but I'd check and make sure your draw isn't above what it's fused for. You may need to jump to a higher amp fuse depending on what you're drawing off it. I did see you mention running a fridge but I don't recall the amperage of the fuse that it normally has
  15. Feb 23, 2022 at 7:03 AM
    Tacocement5
    Tacocement5 Well-Known Member
    Northwest Indiana
    2021 Toyota Tacoma TRD Off Road
    Where did you pick this up? Looks nice. Really getting sick of the Red bedside sticker on my cement OR.
    AmateurTaco1313 likes this.
  16. Feb 23, 2022 at 7:16 AM
    Circuit Rider
    Circuit Rider Well-Known Member
    Terry
    Custer, Kentucky
    2021 Tacoma 4X4 TRD OR
    ARE topper. Mud guards, factory steps, third bed rail behind cab, tacorail accessory holder, ram mount tablet mount, hood wrap and retro stripes. Bug shield and window shields. Molle seat cover on tear seat.
    playdixie and MGMDesertTaco like this.
  17. Feb 23, 2022 at 7:18 AM
    RunUp
    RunUp Well-Known Member
    the resale of these things is insane right now. good call upgrading to a full size - can't beat the extra room
    skierd likes this.
  18. Feb 23, 2022 at 7:51 AM
    notbryon
    notbryon Well-Known Member
    Bryon
    Steelton, PA 17113
    2017 TRD Sport AC
    Installed the TRD skid and TRD tow hook (to be sand blasted and repainted red along with the drivers side loop in the spring)
    D9E6292A-1D8A-45F0-92E5-2FC10F52446A.jpg D5C42B9D-700E-4922-8B2D-F93E3B9B15DB.jpg
    Coldies, TnTHicks, playdixie and 7 others like this.
  19. Feb 23, 2022 at 7:53 AM
    bluelinetaco
    bluelinetaco Well-Known Member
    North Cali - Yay Area! (707)
    2019 TRD Pro VooDoo Blue
    COOL Stuff I can't afford . . . But I bought anyway!
    Oh part numbers! Yes please! Thanks. Morgan hill isn’t far from me in Redwood City.
  20. Feb 23, 2022 at 8:19 AM
    jdmjustin
    jdmjustin Well-Known Member
    Justin
    SW MO
    2018 BBP Tacoma Sport
    Motegi MR149 17x8.5 Falken Wildpeak 265/70/17 Toytec Aluma 2.0
    I ordered the clamshell bushing. Installed my lift over the weekend, and within 300 miles my diff needle bearing was not happy. My truck has 45k on it at time of install. Went ahead and picked up the removal tool, a cv seal (just in case). I'll need to swing by the dealer and purchase some 75w-85 gear oil, unless someone else has another more easily accessible option? I looked but none of the part stores around me carry that specific weight.
