  1. Mar 22, 2022 at 9:16 AM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    There's a CAI air box mod sticky around here somewhere that I followed. Can't find it at the moment.
    Air Accelerator (rubber funnel) + Re-usable Filter + Silicone Hose + Remove Secondary (cheesecloth) Air Box Filter
    is what I did. It DOES make a difference. When I first got my Tacoma, it had a sort of hesitation. I would start off from a stop just fine, then it would fall flat on its face for a second. Did this mod and the problem went away. Don't know if it was a direct result of the mod, or indirect by causing the ECU to compensate for what I did or something.
    The silicone hose just seemed like a good idea. Even the TRD PRO hose has corrugations, which I would think would cause unhelpful turbulence. Maybe not. Dunno'
    Take whatever money you've saved over the kit, get some red tape and TRD stickers for the top of the stock air box.
  2. Mar 22, 2022 at 9:22 AM
    hollandbt
    hollandbt Well-Known Member
    Brad
    Oklahoma
    2021 DCSB TRD Sport 4x4
    OTT tune SCS Ray10 matte gunmetal wheels (-10) Falken Wildpeak 265/70/17 Bilstein 6112 Coilovers (3/4) Bilstein 5100 rear shocks Headstrong AAL ECGS Bushing TRD Skid Plate Smoked sequential signals DSIM rock/courtesy LED lights HomeLink mirror TRD Pro Grill LED interior lights LED tag lights Leer 100XQ Topper Bed Rug Bed stiffeners Tailgate lock LED bed lights Tacoma glovebox letters Black decal overlays Black TRD Sport Decal TRD Shift Knob Rav4 radio knobs Desert Does It seat jackers
    I'm typically a fan of less is more, but the mesh portion of the sport rack looks like a perfect candidate for the TRD emblem everyone is putting on their grill.
    Forest Moon and rgljr831 like this.
  3. Mar 22, 2022 at 9:22 AM
    Kappa
    Kappa New Member
    Tail lights look sick man, and where’d you get those mudflaps?
  4. Mar 22, 2022 at 9:33 AM
    redeyehal
    redeyehal Well-Known Member
    South East USA
    2020 TRD OR
    PTR57-35170 TRD Pro Shift Knob PT857-35200 LED Bed Lighting Kit PTR03-35160 Tacoma TRD Performance Air Intake PT84K-35221 TRD Lift Kit PT27835170 Roof Rack - Double Cab
  5. Mar 22, 2022 at 9:40 AM
    mosccat
    mosccat Well-Known Member
    Mark
    Currently in Bend, OR
    2020 OR
    Wrong forum for that sex toy :anonymous:
  6. Mar 22, 2022 at 9:48 AM
    DrSouthpaw
    DrSouthpaw Dog limo
    Spur
    AZ
    2017 MGM TRD OR 4x4 DCSB
    No issues with opening or closing the cover. I can easily roll up by myself through the gap between the bed side and bed rack. I’m not sure about water seal yet because I live in AZ. I can take it through the car wash and let you know. I did add butyl tape in the front corners. The foam blocks you add do a good job with the gap between the front bed rail and the side rail caps but there is still a large gap underneath between the bed and the bed cap. I attempted to use butyl tap along the sides of the bed rack adapters but found the seal to be better without it. Also, do not use any of the supplier foam for the front rail EXCEPT for about 1 inch on each side that goes under the front of the aluminum tonneau rails (there is a small gap and the thinner foam will fill it). The front bed rail sits higher than the side rails so you will have a more flush seat of the rubber on the front of the cover by not using foam across the front rail.
    0980E322-7469-4E05-AC31-623FB452AE5D.jpg 16E552C7-03BF-48A8-A5E8-478C65F600EE.jpg 78460426-A306-4261-B54A-1FCCEB8E80B7.jpg C3716652-356D-4625-B46B-8CDE482C857A.jpg
  7. Mar 22, 2022 at 9:50 AM
    Siebermd
    Siebermd It’s all about the journey
    Virginia Beach
    2016 TRD Off Road
    Alu-Cab canopy Camper, Dobinson's Suspension
    I made a cup holder Radio Charging station. Always handy and always charged.
  8. Mar 22, 2022 at 10:02 AM
    Foushee
    Foushee Well-Known Member
    Sean
    Texas
    2018 Inferno TRD OR DCSB MT
    Just getting started.
    50K on the OD or: How I Stopped Worrying and Learned to Love Out of Warranty Repairs.
  9. Mar 22, 2022 at 10:05 AM
    BudFriendguy
    BudFriendguy TRD BRGLR
    Zak
    Portland, Oregon >> Cleveland, Ohio
    2021 TRD Sport ACLB 4WD 6MT V6 Voodoo Blue
  10. Mar 22, 2022 at 10:07 AM
    Ruminator
    Mark
    Is this for some sort of Hello Kitty build?
    Apparently, it would be a first. Closest I could find was a Pretty in Pink version.
    Damn shame someone did that to an Access Cab.
    scouterjan and rgljr831 like this.
  11. Mar 22, 2022 at 10:11 AM
    BudFriendguy
    Zak
    That AC is the color of shackle I wanted. Nobody makes one far as I can tell so I'll have to get some custom powder coat done -- maybe the same time I remove the bumper to get it re-coated since I messed it all up with some cutting/welding a while ago.
  12. Mar 22, 2022 at 10:15 AM
    saltybum
    saltybum Well-Known Member
    Bob
    Space Coast
    2022 Tacoma Access
    Just go get a couple bottles of hot pink nail polish. Done!
    BudFriendguy likes this.
  13. Mar 22, 2022 at 10:25 AM
    BudFriendguy
    Zak
    Sounds like somebody needs more fiber in their diet.
    https://www.amazon.com/dp/B00CM9E4VS
  14. Mar 22, 2022 at 10:28 AM
    Out2gtcha
    Out2gtcha Well-Known Member
    Brian
    Omaha, NE
    2020 Quicksand Off Road DCLB 4x4
    Finally got the new Retrax Pro XR installed. WELL, WELL worth the expense. This thing is SO smooth, it works with one finger both ways. It takes up a small bit of bed rolled up, but with my LB Taco its not that bad and I can even stash a lot of stuff under the canister including my compressor. There is about 8" or 9" space under the canister.
    Its fairly water tight as well at the cab end, as I've sealed things well, but there are a few leaks around the tail gate, but I knew that going in with the amount of space around the OEM gate.
    UpTopp bed truss up next......
    TnTHicks, markram, TSAVO and 13 others like this.
  15. Mar 22, 2022 at 10:38 AM
    Tacko21
    Tacko21 Well-Known Member
    custom from cali raised
    CaliRaisedLed and Out2gtcha like this.
  16. Mar 22, 2022 at 10:38 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    They make a voodoo blue shackle. I'm surprised you didn't get one, like I did.
    BudFriendguy[QUOTED] likes this.
  17. Mar 22, 2022 at 10:56 AM
    the_wanny
    the_wanny Overlanding is just you cosplaying being homeless
    콜로라도
    20 Taco TRD Off Road, 16 Lexus LX570
    I would skip spending $$ on any aftermarket intake hose that just seems like a wasted effort. If someone's gonna spend the $100 for a reusable filter and the TRD rubber flow accelerator AND another $170-200 on a hose, then they should just buy the $350 TRD Cold Air "system".
    I still am skeptical about any of it making a meaningful difference, but to each their own. I did the flow accelerator because it was cheap and the reusable air filter because of the ease of maintaining it. Not expecting meaningful gains of any sort. I don't even think it sounds any different, either.
    rgljr831 and Out2gtcha like this.
  18. Mar 22, 2022 at 10:57 AM
    Out2gtcha
    Brian
    Omaha, NE
    There are a lot of things the people who run this forum seem like........but stupid isn't one of them.
    Politicize away and see what happens.:fingerscrossed:
  19. Mar 22, 2022 at 11:17 AM
    Ruminator
    Mark
    Sorry if I got the economics wrong. I admit to not looking up the current prices for everything. I did the mod years ago.
    I think I was about as neutral as one could be. I said "Here's what I did, because I had THIS particular problem, and I know it makes A difference because it cured my problem." I didn't make any claims about "meaningful gains" or even knowing exactly what effect the changes I made had on the system.
    ...but as that well-worn saying goes "To each their own."
    rgljr831 likes this.
  20. Mar 22, 2022 at 11:18 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    IMO, replacing the intake hose with the HPS silicone tube did improve air flow which provided for a bit quicker acceleration. another benefit is the engine actually made some noise under the hood which I like.
