  1. Mar 25, 2022 at 10:14 AM
    huskcummerbund
    huskcummerbund Well-Known Member
    2020 TRD-OR MT
    but... why? Why not just put the TPMS in the wheels?
    Benny blanco and rgljr831 like this.
  2. Mar 25, 2022 at 10:15 AM
    -MEH-
    -MEH- Makes people wish they knew floridaman instead
    Overpriced Toyota, Ragged out old Porsche
    Yes, which is convenient if you have multiple sets.
    rgljr831 likes this.
  3. Mar 25, 2022 at 10:19 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    Got the Meso AC vent rings installed. A pretty easy job. The hardest part was cutting those stupid little nubs that hold the OEM rings in. After that, it was just a matter of aligning the rings so that they were all oriented the same way and getting everything back together. About 30 minutes from start to finish.
    I got Cement, but in retrospect the flat black might have looked better. No matter, either way the light isn't reflecting of them and annoying me.
    afgixxer, 40prcnt and roboturner like this.
  4. Mar 25, 2022 at 10:22 AM
    Kronk21
    Kronk21 IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
  5. Mar 25, 2022 at 10:46 AM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    Nope, still not seeing the point here. Do unused sensors need to be stored at pressures above atmosphere? Pretty sure replacements devices aren't shipped that way from the factory. How do you read out the bottled ones, anyway? With a TPMS programmer?
  6. Mar 25, 2022 at 10:49 AM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    they mean multiple sets of wheels that you dont want to buy extra TPMS sensors for, or swap them from set to set. It's pretty much just making your wheels not have TPMS, so you don't have to worry about them
  7. Mar 25, 2022 at 10:55 AM
    Ruminator
    Mark
    Still not clear. If you don't want to put the sensors in the wheels because you have 2 or more sets of wheels, why bother keeping the sensors active? For whatever reason, my TPMS wasn't reading pressures for many months. No big deal. No flashing lights or anything, truck didn't refuse to move. Just no pressure readings.
  8. Mar 25, 2022 at 10:55 AM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    I just added this remote unit to the 12v outlet for my winter tires and ignore the yellow light on the dash for a few months.
  9. Mar 25, 2022 at 11:04 AM
    Ruminator
    Mark
    Oh, now it's starting to congeal... There is a yellow tire pressure warning light, isn't there. Guess I was pretty good at ignoring it.
    oostroma[QUOTED] likes this.
  10. Mar 25, 2022 at 11:06 AM
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    the light stays on. People make these out of pvc pipe and just pressurize them to 35psi and throw them under a seat and the light goes away.
    Ruminator[QUOTED] likes this.
  11. Mar 25, 2022 at 11:06 AM
    oostroma
    oostroma (Boomer)
    Ontario
    My spouse was not keen on the yellow light in the dash the 1st year I installed winter tires on steel rims. Then I told her how much it cost to get another set of TPMS for the winter set.
    She learned to ignore the yellow light as quickly as I did after that.
  12. Mar 25, 2022 at 11:08 AM
    Ruminator
    Mark
    Okay, I get it now. Thanks to all for humoring me.
  13. Mar 25, 2022 at 11:16 AM
    bassmusic
    bassmusic Banned from Whatever For Whatever
  14. Mar 25, 2022 at 11:19 AM
    bassmusic
    Took her out for lunch while WFH Friday :)
  15. Mar 25, 2022 at 11:26 AM
    Weedly
    Weedly Well-Known Member
    Doug
    Collingwood, On. CAN
    2022 DC TRD Sport in Lunar Rock, 1988 RX7 Convertible
    Finally able to get my wheels and tires mounted today. A slight bit of rubbing on the front mud flaps but nothing the heat gun can't fix.
  16. Mar 25, 2022 at 11:31 AM
    oostroma
    oostroma (Boomer)
    Ontario
    If you get some flat ones that might just be enough to eliminate the rubbing. I replaced my wind sails the 1st winter because they just filled up with snow and mud as well as rubbed with my wider winter tires.
    Tlaloc1916, TnTHicks, JDSmith and 6 others like this.
  17. Mar 25, 2022 at 11:31 AM
    huskcummerbund
    2020 TRD-OR MT
    I bought winter's with TPMS installed but for some reason Subaru's have to be reprogrammed twice a year to make them work. She got used to the yellow light in winter. My Mazda never cared, though it may have had Indirect TPMS instead of Direct so the modules in the wheels may have been useless from the start.
  18. Mar 25, 2022 at 11:48 AM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    Alignment and rear shocks today.
    Night and day difference with 6112 in front and 5160 on the rear.
    SlowDecay, TnTHicks, JDSmith and 11 others like this.
  19. Mar 25, 2022 at 11:52 AM
    JackJoachim
    Jack
    North MS/Memphis
    What settings and did you do the needle bearing?
    Jerry311SD[QUOTED] and rgljr831 like this.
  20. Mar 25, 2022 at 12:12 PM
    Jerry311SD
    Jerry
    Ramona Ca SAN DIEGO
    I did the 3-4 knotch on the front. I only have 15miles on them so far.
    Im 2WD didn't have to mess with needle bearing.
    Im still on street tires. Ill put on my rims when its time for new tires.
    TnTHicks, playdixie, JDSmith and 6 others like this.
