  1. May 10, 2022 at 8:03 PM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    I was considering pulling the cubbies off behind the back seat and taking a look. I like that spot a little better than where I have, I will have to keep evaluating this install before I decide where to run everything. I’m thinking of going with a high db gain antenna also so I’ll be running a new wire with that. May use this spot then. Thanks for the suggestion!
    5nahalf[QUOTED] likes this.
  2. May 10, 2022 at 8:07 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I originally ran my antenna like yours till I found the one in the back of the cab. I have since removed my CB, but plan to install a GSMR radio in the future, but I will be putting the antenna in the front and using this grommet in the engine bay. Going to use a surface mount antenna jack so when the winter destroys another antenna cable, I can just unplug it from the firewall and put in the new one without having to rip apart the inside of the truck.
  3. May 10, 2022 at 8:12 PM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    That’s a great idea too! I will have to consider this route also. I’m wanting to go with a taller antenna with a higher gain and it wouldn’t need to be on the top of the truck so I could use a mount on the front of the truck and use the surface mount like that. That’s probably the cleanest way and easy to swap out the antenna wire if/when something happens to it.
  4. May 10, 2022 at 8:19 PM
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    It didn’t loosen up the fabric?
  5. May 10, 2022 at 8:20 PM
    Tacogeorge17
    Tacogeorge17 Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    too bad your in Canada I would give you my stock ones I just upgrade to the Meso puddle lights
  6. May 10, 2022 at 8:21 PM
    afgixxer
    Tennessee
    That’s what I did.
  7. May 10, 2022 at 8:27 PM
    afgixxer
    Tennessee
    I’m thinking of going uninformed having matching brand parts. Really considering all CBI parts, but the C4 stuff looks good too.
    GreenTaco415[QUOTED] likes this.
  8. May 10, 2022 at 8:27 PM
    5nahalf
    Erik
    Minnesota
    You can also get water proof caps that screw onto the end to keep it protected when you dont have the antenna on. The only thing, you need to solder the cable yourself. The hole is too cramped to fit the end with a plug on it through as its right behind the HVAC box. But you can fish the cable through, then solder a plug to the end (really easy to do).
    TnTHicks likes this.
  9. May 10, 2022 at 8:30 PM
    2jzmarc
    2jzmarc Member
    Marc
    Vancouver WA
    2021 Tacoma TRD OR
    Blacked out the OEM wheels. Not sure if I like the black wheels but definitely better than the chrome. I might go with bronze or white when I buy new wheels.
  10. May 10, 2022 at 9:39 PM
    mrkothegigolo
    mrkothegigolo Active Member
    What grill is that?
    GreenTaco415 likes this.
  11. May 11, 2022 at 12:03 AM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    Recently, I added rail posts to my double slide. The rail was designed to support the platform I built for the open half of the bed. I finally got the stainless tie down anchors and installed one on the backside of each post to finish the platform build.
    TnTHicks, robin303, The Mink and 13 others like this.
  12. May 11, 2022 at 2:14 AM
    jt13077
    jt13077 Well-Known Member
    CNY
    2021 Black DCSB TRD OR
    Looks great! I’ve been thinking about doing this. Did you use the decals, plasti dip or…? Thanks
    2jzmarc[QUOTED] likes this.
  13. May 11, 2022 at 2:55 AM
    Paulndot
    Paulndot Well-Known Member
    2020 TRD Off Road
    Was the tailgate lock replaced at some point?
  14. May 11, 2022 at 3:25 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Another route for getting wiring/ antennas in or out of the cab is through the AC drain hose grommet. Its in an easy location and the hole in the fire wall is a good size once you remove the grommet. Put it back of course. I have my antenna and compressor/lockers wiring going through the grommet.
    Here is the video where I show the antenna wiring.
    https://youtu.be/D7DotMlaXaQ
  15. May 11, 2022 at 4:36 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    On mine, there was an extra nipple sticking out of the AC grommet. I cut the end off of it and now I had a sleeved input point for my coax.
  16. May 11, 2022 at 5:35 AM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    very nice location. I never thought about using that location to go through the firewall. Thanks for the info!
    ClassyTacos[QUOTED] likes this.
  17. May 11, 2022 at 5:56 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I highly recommend the decals. I got a lot of miles out of those before I finally changed out wheels this year. Plus its easy to replace a section when a tire shop gets a little to aggressive with the bead puller. :mad:
    My personal favorite - flatsixgraphics on etsy. They have a metallic charcoal color that looks a lot sharper than the standard black.
    Edit: this is what they looked like after three years of neglect and abuse:
  18. May 11, 2022 at 6:28 AM
    ElGringo
    ElGringo Well-Known Member
    2019 Cement Grey
    The whole tailgate was replaced. I'm assuming the previous owner lost the key.
    Paulndot[QUOTED] likes this.
  19. May 11, 2022 at 6:38 AM
    TOYOTA STORY 3
    TOYOTA STORY 3 Member
    2019 Super White Tacoma TRD
    Fab Fours Hybrid Front Bumper.
    BlarBlarjosh[QUOTED] likes this.
  20. May 11, 2022 at 7:40 AM
    2jzmarc
    2jzmarc Member
    Marc
    Vancouver WA
    2021 Tacoma TRD OR
    Thanks! I did the vinyl decal that someone’s wife sells here. Pretty easy job if you’re patient.
