  1. May 10, 2022 at 6:26 PM
    Six206
    Six206 Active Member
    18 ORDC
    Some new wheels. Dx4 nitros. Already had the ultraterrains on the stock wheels.
    6052AC4C-E2D6-41AB-9EBB-9DE9EAF2CB2A.jpg C799E512-0F76-47C6-A172-C5CAA7918277.jpg 53618003-0156-412D-88AF-F3DCBC13B148.jpg
  2. May 10, 2022 at 6:27 PM
    roboturner
    roboturner Dead Eyed
    Colorado
    00 IJM AT XC 4x4 3.4L TRD | 18 CB MT DCSB 4x4 V6 Pro | 98 NW MT 4x4 3.4L SR5 4Runner
    Famous last words
  3. May 10, 2022 at 6:34 PM
    Forest Moon
    Forest Moon Well-Known Member
    Greater Lowell Area
    2021 TRD OR Army Green
    Yep, I challenge myself to get the best mpg possible on the way home every time I fill up. I was at 26 in front of my house once and by the time I backed into the driveway it was already down to about 21. For the record, I only average between 16-17.5 usually.
  4. May 10, 2022 at 6:49 PM
    Jimothy727
    Jimothy727 Member
    Jamie
    Winchester, Kentucky
    2018 TRD Offroad DCSB MGM
    Do these rub at all at full turn for you? Looking to get them on stock suspension
  5. May 10, 2022 at 6:52 PM
    Kronk21
    Kronk21 IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
    TacoGeeloor[QUOTED] likes this.
  6. May 10, 2022 at 6:56 PM
    wldct69
    wldct69 Member
    Just got new wheels put on. Gonna wear out the stock tires and then put some A/T Tires.
    JDSmith, TnTHicks, markram and 6 others like this.
  7. May 10, 2022 at 7:09 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Nothing today, but I went out yesterday too. Was chasing crappies since the bass/pike/walleye season is not open yet. Ended up with 7 bass and 2 crappies. Im going out again tomorrow for crappies again, but this time to a lake stocked with rainbow trout... so its going to be a trout day im sure.
    kas2828[QUOTED] likes this.
  8. May 10, 2022 at 7:37 PM
    TacoGeeloor
    TacoGeeloor Well-Known Member
    Chad
    Washington State
    2020 TRD OR
    There is a grommet under the driver seat. Just ran it under the carpet from there to the trim piece then back under the seat. If the radio stays I will probably go under the center console but wanted to make sure I liked the spot.
    TnTHicks and Kronk21[QUOTED] like this.
  9. May 10, 2022 at 7:46 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Looks good, but plz take of that damn air dam! :thumbsup:
  10. May 10, 2022 at 7:49 PM
    roboturner
    Colorado
  11. May 10, 2022 at 7:59 PM
    5nahalf
    Erik
    Minnesota
    While a little harder to get to, there is a nice grommet on the back of the cab between the cab and bed. You have to remove the drivers side rear cubby, then fish your arm behind the C pillar trim.
    TnTHicks and TacoGeeloor[QUOTED] like this.
  12. May 10, 2022 at 8:03 PM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    I was considering pulling the cubbies off behind the back seat and taking a look. I like that spot a little better than where I have, I will have to keep evaluating this install before I decide where to run everything. I’m thinking of going with a high db gain antenna also so I’ll be running a new wire with that. May use this spot then. Thanks for the suggestion!
    5nahalf[QUOTED] likes this.
  13. May 10, 2022 at 8:07 PM
    5nahalf
    Erik
    Minnesota
    I originally ran my antenna like yours till I found the one in the back of the cab. I have since removed my CB, but plan to install a GSMR radio in the future, but I will be putting the antenna in the front and using this grommet in the engine bay. Going to use a surface mount antenna jack so when the winter destroys another antenna cable, I can just unplug it from the firewall and put in the new one without having to rip apart the inside of the truck.
  14. May 10, 2022 at 8:12 PM
    TacoGeeloor
    Chad
    Washington State
    2020 TRD OR
    That’s a great idea too! I will have to consider this route also. I’m wanting to go with a taller antenna with a higher gain and it wouldn’t need to be on the top of the truck so I could use a mount on the front of the truck and use the surface mount like that. That’s probably the cleanest way and easy to swap out the antenna wire if/when something happens to it.
  15. May 10, 2022 at 8:19 PM
    afgixxer
    afgixxer Well-Known Member
    Tennessee
    2021 Tacoma TRD-Off Road (Cement)
    It didn’t loosen up the fabric?
  16. May 10, 2022 at 8:20 PM
    Tacogeorge17
    Tacogeorge17 Well-Known Member
    George
    Socal
    2017 black Tacoma TRD OR manual
    too bad your in Canada I would give you my stock ones I just upgrade to the Meso puddle lights
  17. May 10, 2022 at 8:21 PM
    afgixxer
    Tennessee
    That’s what I did.
  18. May 10, 2022 at 8:27 PM
    afgixxer
    Tennessee
    I’m thinking of going uninformed having matching brand parts. Really considering all CBI parts, but the C4 stuff looks good too.
    GreenTaco415[QUOTED] likes this.
  19. May 10, 2022 at 8:27 PM
    5nahalf
    Erik
    Minnesota
    You can also get water proof caps that screw onto the end to keep it protected when you dont have the antenna on. The only thing, you need to solder the cable yourself. The hole is too cramped to fit the end with a plug on it through as its right behind the HVAC box. But you can fish the cable through, then solder a plug to the end (really easy to do).
    TnTHicks likes this.
  20. May 10, 2022 at 8:30 PM
    2jzmarc
    2jzmarc Member
    Marc
    Vancouver WA
    2021 Tacoma TRD OR
    Blacked out the OEM wheels. Not sure if I like the black wheels but definitely better than the chrome. I might go with bronze or white when I buy new wheels.
