  1. May 13, 2022 at 10:16 PM
    Travace
    Travace Well-Known Member
    Not so Much what I did to my truck but what it did for me me. Towed my boat to the lake20220513_173350.jpg
    Combatcom, markram, TnTHicks and 12 others like this.
  2. May 13, 2022 at 10:31 PM
    ilyace
    ilyace Well-Known Member
    2020 MGM TRD 4x4
    I had this wretched transmission slip going from 2nd to 3rd, usually most noticeable while making slow corner turns. When the truck would be ready to downshift out of the turn, it would like shift into neutral, rev super high and then kick into gear, all within a second (resulting in thump and jolt). Also had instances of not shifting into 1st when applying gas from a stop. More recently I could literally hear a whine coming from the transmission. It drives much smoother now.
    Here were my original issues, in a thread dedicated to this 3rd gen transmission problem: https://www.tacomaworld.com/threads...tly-from-factory.405642/page-60#post-27281240
    thomasburk[QUOTED] and AXL like this.
  3. May 13, 2022 at 10:33 PM
    WestEndSal
    WestEndSal Active Member
    Travis
    2021 Army Green Off-Road
    I have those as well, they are a major improvement over the stock bulbs.
  4. May 13, 2022 at 10:33 PM
    Jadamjr
    Jadamjr Well-Known Member
    Jonathon
    Phoenix,AZ
    2017 DCLB TRD OR
    Hey guys, I have a sway bar end link that loosened. I went today to tighten the nut and it’s seized. I’m thinking I’ll have to cut it off and replace it because my truck makes a loud clunk and sounds like shit. Any of you ever had this issue? Any way around replacing the end link? Any suggestions on a stronger end link?
  5. May 13, 2022 at 11:00 PM
    robin303
    robin303 Well-Known Member
    Robin
    Houston Tx
    21 TRD Sport
    Damn, I like that. :thumbsup:
    Travace[QUOTED] likes this.
  6. May 14, 2022 at 4:18 AM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
  7. May 14, 2022 at 5:12 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Take the sway bar completely off. Live that no sway bar life.
    Otherwise, your threads are most likely fucked if the sway bar has been pounding on the links for a while. Rockauto.
    Tacodog likes this.
  8. May 14, 2022 at 5:52 AM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Well doesn't this count . I drive with em on to work which makes me money to buy things and stuff lol for my taco morning y'all
    drvn, cammerv8, TnTHicks and 5 others like this.
  9. May 14, 2022 at 7:27 AM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    You peeled the tape, before it dried. Right?
    RCrumb and Benny blanco like this.
  10. May 14, 2022 at 7:31 AM
    thomasburk
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Thanks I checked out that thread. I'll be opening up the transmission this summer for sure I'm due for a oil change. Hey, does the transmission pan gasket need replacing on pan removal? Assuming it does...
  11. May 14, 2022 at 8:24 AM
    Barrydd
    Barrydd Well-Known Member
    2021 TRD Off Road DCLB Barcelona Red
    Installed an aluminum skid plate.
    cammerv8, Nyobtub, TnTHicks and 9 others like this.
  12. May 14, 2022 at 10:19 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Hauled a bunch of wood chips from a ground up stump at our park. Used them to make the kids a neat little hang out area in the woods behind the house.
    TnTHicks, markram, robin303 and 13 others like this.
  13. May 14, 2022 at 10:36 AM
    Forest Moon
    Forest Moon Well-Known Member
    Greater Lowell Area
    '24 OR 6mt Supersonic Red
    Replaced the front door speakers this morning. Went with Alpine R-S69.2's. I know everybody does Kicker but this is what sounded best to me using Crutchfield's comparison app on their website. I actually bought them about 2 years ago for my last truck but never got around to installing them. They look a little plain without the grill on:
    Road Kill Speaker Enhancer - I was trying to figure out how to use this foam kit, but it didn't seem to work with the window glass being behind the speaker.
    Also installed the driver's side door molle panel from Taco Vinyl. First project with the rivet nut setter. I was gathering up some items to install on it but it's just too damn hot outside right now.
  14. May 14, 2022 at 10:43 AM
    ilyace
    2020 MGM TRD 4x4
    not entirely sure bud. The procedure I had done at the shop didn’t involve cracking the trans open (as far as i know). I just did a top off, not a drain and flush. Only being at 42k myself, I was performing the 40k routine maintenance when my truck first started driving like a hiccup. Did my diff fluids, and while I was down there I set up my Icon rxt to setting 2 from 1. So at first I thought I had messed up my driveline/pinion angles. Did some down the list troubleshooting, got my alignment checked and made sure my torques and diff fluid levels were good. So it was just down to transmission. I’m tellin ya it was so noticeable in the way the truck drove. There’s videos on youtube. I was convinced I was the first ever 3rd gen to have really bad axle wrap without using blocks under my leaf springs lol. It drove me nuts for almost a month till I had the time to take it into my mechanic. Thank god I did. The truck drives like brand new now.
  15. May 14, 2022 at 12:01 PM
    MGMDesertTaco
  16. May 14, 2022 at 12:59 PM
    TRDTaco420
    TRDTaco420 Chum is Fum
    The Bear
    Tacoville - Canada Eh!
    2019 Mid. Blk. Met. ACLB TRD Off-Road
    Kewl shizz
    Forget the boots. Spray on shoes.
    cammerv8, ClassyTacos and 45longcolt like this.
  17. May 14, 2022 at 1:59 PM
    Forest Moon
    Greater Lowell Area
    There was some kind of tubular structure running through back of the speaker hole. You would have to notch the back of the inside foam piece around this. Most of the adhesive area would be lost. Not sure if enough would have been left for it it stay put. Then you would have to make a notch along the top for the window to slide up and down. The idea of the kit is to create a seamless funnel to channel all the sound out the front. I didn't see how this would have been possible.
    I ended up using a Dynamat speaker kit. It's just 2 12"x12" pieces of sound dampening material. It's meant to do 2 speakers, but you could easily use a full kit for each speaker. I figured it was better than nothing.
    MGMDesertTaco[QUOTED] likes this.
  18. May 14, 2022 at 2:02 PM
    MGMDesertTaco
    Thanks, I'm just going to deaden the doors and call it good enough then.
    venezian and Forest Moon[QUOTED] like this.
  19. May 14, 2022 at 2:06 PM
    oostroma
    oostroma (Boomer)
    Ontario
    2017 TRD OR access cab- BBP colour
    TRD emblems, tinted windows, OEM running boards, AVS vent shades, RMAS upgrade, LED lights in front and rear, interior LED lighting upgrade, LED lighting in bed, touch control dash mount for LED lighting, auxillary 12v and USB jacks in bed, replace all speakers with Infinity, custom mod with Bose tweeters, TRD Pro illumination mod...
    If you Dynamat the plastic door panels as well this will improve the base as well as reduce road noise.
  20. May 14, 2022 at 2:27 PM
    flatironsoverland
    flatironsoverland @FlatironsOverland
    Erie, Colorado
    If you’re still looking for an attic net, we’ve got one for sale on our website in the signature below :thumbsup:
