  1. Jun 25, 2022 at 5:10 PM
    Cappy
    Cappy Well-Known Member
    Georgia
    Good luck with your new to you F150. My previous truck was a 2002 F150 FX4 Super Crew. Kept it for 16 years and the only issue was a fuel pump that I had replaced after buying my Tacoma. Loved the truck and sold it because I no longer needed a full size truck. Hope you enjoy yours as much as I enjoyed mine.
  2. Jun 25, 2022 at 5:11 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    I didn’t realize that salt was left in the water. I thought it was only used to basically clean the softener beads. I’m sure that spraying salt on the truck would be good.
  3. Jun 25, 2022 at 5:59 PM
    MGMDesertTaco
    Calcium and magnesium minerals cause hard water spots. A softener will add salt to make the water feel more slippery, but won't remove the hard minerals that cause etching. A deionized water system will remove hard minerals as the resin absorbs the calcium and magnesium. However, the life of the resin will be limited depending on your water hardness and total dissolved solids. An in-line carbon filter and softener will prolong the life of the DI resin too. Ideally, you'd have a second inline carbon filter after the softener, but before the DI system, because salt will also shorten the life of DI resin.
    A 50/50 mixture of distilled vinegar and distilled or deionized water will remove spots if they're not etched into the clear. You'll need to polish them out with a random orbital polisher if they're etched. Also, spraying a drying aid on the wet panels before drying will buy you some time. I like Adams detail sprays and spray wax.
    https://www.amazon.com/Adams-Detail...gid=pla-518019100477&ref=&adgrpid=68995954464
    https://www.amazon.com/Adams-Spray-...t=&hvlocphy=9061147&hvtargid=pla-584134694622
    I use a DI Rinse Pro 100, but I also have a whole house water filter and softener system through Aqausure in addition to a wall mounted sediment and carbon filter after the softener, but before the DI system.
    https://clean-garage.com/spot-free-...MI5N6Qt_LJ-AIVqsLCBB3KpgjZEAQYASABEgIcYfD_BwE
    https://dirinse.com/product/d-i-rin...MI5N6Qt_LJ-AIVqsLCBB3KpgjZEAAYASABEgIkd_D_BwE
    https://aquasureusa.com/collections...h-iron-reducing-fine-mesh-resin-48-000-grains
    https://aquasureusa.com/collections...house-water-treatment-system-1-500-000-gallon
    (DI tank not pictured as it's kept indoors during hot summers and carried out and connected as needed.)
    Uparmorjoe, TnTHicks, japjoe7 and 9 others like this.
  4. Jun 25, 2022 at 6:06 PM
    Kronk21
    Kronk21 IG @uniquely_Us_adventures
    Monte1
    2021.DBLCB.LB.GRN
    King 2.5 with reservoirs, CBI sliders, RCI skids, Leer camper shell, Methods, K02, switch-pro
    Okay so thank you a hundred times! That is a fantastic response and super helpful! Truly appreciated! I’m going to look into that Adam’s detail spray for sure… I need something like that setup our water is terrible. Turns everything salt white and ruins shower heads..
  5. Jun 25, 2022 at 6:23 PM
    PFL_Customs
    PFL_Customs Pulling pitch
    2019 Tacoma Off Road
    PFL Customs roof rack, Body Armor Hi-line bumper. X20 Gen 2 Smittybilt winch, PFL Customs bed rack. Dirt bound rack supports.
    I washed my truck 3 times since 2019, everytime its a full detail, ceramic coating, and I put a layer of undercoat on, well... everything under the truck,
    So far no rust no anything really, every now and then I will hit the leaf springs with the power washer because they get squeaky. Crazy when I do the yearly wash dirt falls right off paint in fantastic shape.
    Now I do have my roof wrapped for protection. Plastics have a clear film on them and the again have the 3 year ceramic coating but do it once a year. It also helps the truck is the color if dirt but yeah im a few months into this years wash, just drove it 3100 miles to Alaska.
    Ive put 70k on it since new in 2019 drove it across Mexico, the US twice, Canada once. I do wipe down the kings as well every 10k and grease everything
  6. Jun 25, 2022 at 6:29 PM
    PFL_Customs
    The "and I think I'm done" quote.... then you browse tacomaworld and find 709 things you dont need but need and in a few years you have a offroad machine sent from the gods sitting in the driveway.....
  7. Jun 25, 2022 at 6:41 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
    Honestly my gf coordinated the install so what you’re saying is a bit over my head lol I just know we have like two tanks and a salt basin I have to refill every so often and a filter for the sediment
    Edit: loooove Adam’s stuff
  8. Jun 25, 2022 at 6:46 PM
    Kronk21
    Monte1
    2021.DBLCB.LB.GRN
    That’s awesome! Love the build are those water on the roof? I am so jealous I wanna drove to Alaska. It’s on the to do list..
    PFL_Customs[QUOTED] likes this.
  9. Jun 25, 2022 at 6:51 PM
    E.T.
    E.T. Well-Known Member
    Los Angeles
    2016 MGM OR TRD AC Field Truck
    So how was the sound reduction to you? I picked up an orange noodle at SFI (1.99) last week, stuffed it in, and the cab seems to be quieter. I'd also put foam in the vents when I put soundproofing on the back wall of the cab a couple of years ago.
    oostroma likes this.
  10. Jun 25, 2022 at 6:54 PM
    PFL_Customs
    Yes they are pressurized water tubes about 8 gallons 7 to 9 minutes of flow on a low flow shower head. And the drive was amazing highly recommend doing it.
    Kronk21[QUOTED] likes this.
  11. Jun 25, 2022 at 6:58 PM
    E.T.
    Los Angeles
    Where'd you get the console cover?
    PFL_Customs likes this.
  12. Jun 25, 2022 at 7:17 PM
    JDKred
    JDKred Well-Known Member
    JD
    16 MT KDMax Tuned
    Finally did the 2lo mod!
    Took about an hour.
    Very cool functionality
    Bob1971 likes this.
  13. Jun 25, 2022 at 7:25 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    it slows them down or you can use a clamp that uses a socket - better
  14. Jun 25, 2022 at 7:33 PM
    RIX TUX
    this is better than the clamp and only about 18-20$
  15. Jun 25, 2022 at 7:38 PM
    TacosMan
    TacosMan Well-Known Member
    E.T.[QUOTED] likes this.
  16. Jun 25, 2022 at 7:51 PM
    virginiamarine
    virginiamarine Well-Known Member
    Northern Virginia
    FJCruiser/Double cab Tacoma
    Mod day today. Pic heavy!! My list:
    - TC UCA
    - TC LCA
    - Toytec 700 springs
    - Toytec block to level out rear
    - Denso iridium plugs
    - Oil change
    - Alignment
  17. Jun 25, 2022 at 8:08 PM
    PFL_Customs
    this is absolutely incredible good job!
  18. Jun 25, 2022 at 9:03 PM
    Goatfrog
    Goatfrog Well-Known Member
    Bill
    Pittsburgh, PA
    2020 Red DCLB TRD Off Road
    Finally installed my CaliRaised hidden bumper light bar. Then because the state I live in is very restrictive regarding exterior vehicle lighting, I installed a magnetic light bar cover to make sure it is truly hidden.
    Pretty happy with how it turned out.
    69D5DD81-695C-4E79-8F30-82EC7856F5BB.jpg 3ACAFCB9-F54A-441C-8FF5-77830C047982.jpg 5D851288-FB28-4328-84E5-3BFB58AA5D69.jpg 8FE8E9F6-4F26-4BDF-A3C8-61010F924239.jpg
  19. Jun 25, 2022 at 9:11 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    It's interesting to see a Taco with all those mods and yet stock wheels, nice
    Kolter45 and PFL_Customs[QUOTED] like this.
  20. Jun 25, 2022 at 9:17 PM
    MGMDesertTaco
    I've had one sitting in a box for almost 4 years. I keep forgetting about it. Are you using the included switch or something else like a switch pro or auxbeam control panel?
    Goatfrog[QUOTED] likes this.
