  1. Jun 28, 2022 at 6:13 AM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    Learned something interesting today, needed to replace my TSS sensor panel on my Trd pro grille as mine took a good rock to it and cracked it, so instead of purchasing a new one, say from Taco Vinyl, I looked at theirs for $ 69.99 and matched the part # that's injection molded into the back of the part to one on Amazon and purchased it for $24.99. Wow what an upcharge for a vendor. Thanks Amazon
    Now all i have to do is figure a way to waterproof the sensor better to stop it from getting wet and not working. Foam just doesn't cut it.
    Suggestions or ideas?
    RIX TUX and oostroma like this.
  2. Jun 28, 2022 at 6:16 AM
    DustyMcTaco
    DustyMcTaco Well-Known Member
    2018 Tacoma TRD Sport
    Meso Taillights and other Meso stuff
    ooooh
    I’ll be getting one of those soon! I have a bkue ridge one and everything falls out all the time
  3. Jun 28, 2022 at 6:57 AM
    ViktorBreezeway
    ViktorBreezeway Brown Coat
    2017 Quicksand TRD OR DCSB
    Glad I'm not the only one with that issues.
  4. Jun 28, 2022 at 7:01 AM
    DustyMcTaco
    also the net one looks like i could put my kids up there when they need a time out
    AwesomeLaw68 likes this.
  5. Jun 28, 2022 at 8:01 AM
    AbnMP13
    AbnMP13 Well-Known Member
    Shelby
    2020 TRD Crew Long Bed
    i wanted one of those too but they didn’t have a camera bracket for that specific grill.
    afgixxer[QUOTED] likes this.
  6. Jun 28, 2022 at 8:11 AM
    cybrnook
    cybrnook Well-Known Member
    SE Michigan
    2022 TRD Off-Road Manual Transmission
    Sprayed my Formula 3000 on over the weekend, not too bad. Looking forward to doing this every year. Honestly, I enjoyed it :)
    tsitVfPuY0U2V7dCkL_Tb0btv7AK2I0r79E7Fuic_73772c1f75036ea2a67f050415c3eade4ff0e2c8.jpg
    CLNIh16Gow28Uh7BI_8qfE5WN0-6_SUiLpTM3JcB_7f7a8171e448cba7e08359119e7b80b0b3f6d680.jpg
    1M6CA0LbmJuRp5GfFpHDuwW4M90DaiS4Ii3xsPtc_0f737e23d73cdfd16e7c5f3cc863cba738f89241.jpg
    1U3In_ttxQ7ZdCGYpXTY0IRKwhNcTS0THDIuA-Do_ef8659218f50b1c7c14a9db25df591868dcd9aa6.jpg
    p_mwbt0byu3LcxBPL4XVTufqed6KbxdQXxUjAm0H_552b3df7329a2fa0dcbd6f22a746816e2daa67e0.jpg
    BFrq47L0u11G_w5zaCA76hRNZBrzMqvpjRzE0A_m_c610ae46e050244fd6301375065278f0fc087743.jpg
    Make sure to check your fittings before you start, gutentight is spec:
    oAyAGo2F-7e9BkI6CeWj5AC3A4XtuFV0KiBM9iSZ_5c8ffa92cf49b29313c8d58d2805133f66d11c58.jpg
  7. Jun 28, 2022 at 8:47 AM
    AwesomeLaw68
    Lawson
    Brand new.
    This is a nice looking Grille., Where did you get that from ?
    What did you do to waterproof the front TSS pre-collision sensor ?
  8. Jun 28, 2022 at 8:56 AM
    AbnMP13
    Shelby
    Works for me until I turn up my stereo. My sub vibrates them down.
    MGMDesertTaco and AwesomeLaw68 like this.
  9. Jun 28, 2022 at 9:52 AM
    gen2eng
    gen2eng Well-Known Member
    Indiana
    2022 TRD Offroad DC 4x4
    Depending on locale, a Shell station may not be using Shell produced fuel, but it will be using the Shell licensed additives (secret sauce).
    Next time you see a tanker dropping fuel at your favorite station, take a look at who operates it. Most fuel distribution hubs are taking base fuel from the lowest priced source, even mixing them, and then simply blend the licensed additives as it's loaded into the tanker. So, more than likely the Krogers, Sam's, etc. are just base fuel without additives while the Shell, BP, and Marathons are adding their fuel system cleaning additives. The licensed additives are strictly controlled and samples taken at the terminal before the tanker leaves to ensure they are within tolerances.
    This is the typical case for Indiana whereas I would expect gas stations closer to fuel refineries to potentially stick with the branded stock.
    I had the opportunity to tour a terminal near Oklahoma City and it was an eye opener for sure. It was neat to learn how they manage use of the same pipeline to move gasoline and then a heavy oil and diesel next. They have mechanisms in place to detect the change and switch to different tanks and capture the mixed product in-between to be sent back and refined again back into pure stock.
  10. Jun 28, 2022 at 10:15 AM
    TheBrettster
    TheBrettster Well-Known Member
    Brett
    2022 Barcelona Red TRD OR
    That's really interesting! I was under the impression "Top Tier" was actually better fuel and not just additives (secret sauce). I've also never really thought about how a pipeline could carry different types of fuel. Appreciate the info!
  11. Jun 28, 2022 at 10:23 AM
    Tacospike
    Two Trucks
    Good to know
  12. Jun 28, 2022 at 11:00 AM
    45longcolt
    45longcolt Well-Known Member
    DFW Area
    2020 Off Road
    This sounds like a job for Flex Seal.
  13. Jun 28, 2022 at 11:10 AM
    flatironsoverland
    flatironsoverland @FlatironsOverland
    Erie, Colorado
    Working on one as we speak :thumbsup:
    tacoshell88[QUOTED] likes this.
  14. Jun 28, 2022 at 11:20 AM
    flatironsoverland
    Erie, Colorado
    We've heard that a lot. Never once had something fall out of my personal truck (unless the wind blew it out like a hat or something)
    Factory approved use.
    afgixxer likes this.
  15. Jun 28, 2022 at 12:02 PM
    JFanaselle
    JFanaselle Well-Known Member
    Joe
    Murrieta, CA
    2020 TRD Off-Road DCSB 4x4
    Nice work! :cheers:
    I absolutely love my CaliRaised premium roof rack. I'm surprised that more people don't run this rack! The brightness of the side lights did leave a little to be desired (they're certainly not "alley lights"), but they're great for lighting up the ground/general area while camping. The ones on the driver side sit below my CVT awning when it's mounted to the rack, which is really nice for lighting up the area under the awning for cooking, etc. I don't think I've ever used the rear ones other than while on a dusty trail during the daytime, to help people behind me see my location a little better.
    I did something similar to your wiring setup, but I didn't use the KC wire hider. I ran two 12 gauge wires (coated with thick black silicone insulation) up the driver side and tucked them deep into the channel between the windshield and weather strip. Then I installed black heat shrink tubing over 4-conductor 16 gauge bonded trailer wire, and ran it up the passenger side tucked in the same way. They terminate into waterproof connectors on the roof, which came in handy when I had to have the windshield replaced. I was able to just unplug them all, and pull the wires out of the gap and roll them up into the engine compartment for the day.
    6mtTRD likes this.
  16. Jun 28, 2022 at 12:18 PM
    the_wanny
    the_wanny Overlanding is just you cosplaying being homeless
    콜로라도
    20 Taco TRD Off Road, 16 Lexus LX570
    Passenger side replacement headlight came in, and all is back to normal with my Taco. Big thanks to the parts guys at Sparks Toyota in Myrtle Beach, SC for making the return and replacement process hassle free.
    1600EDB0-116E-4677-A845-0430905A66A5.jpg 14A1B8DC-7E9F-406E-A3C9-A18BF82053E0.jpg 0732FBCE-B912-4A45-B372-C46DB452BE6B.jpg
  17. Jun 28, 2022 at 1:04 PM
    cammerv8
    cammerv8 Well-Known Member
    2019 Silver Tacoma Trd Sport DCSB
    Bed inlays stickers
    if you can get a buff-pad. try to run it see how better it is. if not get one of those Plastix "headlight" restore bottles with a microfiber you can polish the section to get it as good as you can. then you can make and assessment.
    i manage to hit a orange barrier and tough i had to replace or repaint the whole bumper., i just use the plastix it remove all the orange and was lucky no paint pealed off.
    thomasburk[QUOTED] likes this.
  18. Jun 28, 2022 at 2:56 PM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    I would note that base fuels also have additives (detergent) because it is regulated they do so. The proprietary blend of detergent and amount in excess of the required minimum is what differs by station.
  19. Jun 28, 2022 at 3:30 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    The black you see in the image is missing paint, the car that hit me was red. I opened a claim, I'll probably take it in next week to get an estimate since I'm taking vacation time next week, I will see what they tell me about wait time, etc. I would prefer to remove the bumper cover leave it with them, and drive the truck home-anyone ever hear about someone doing that?
  20. Jun 28, 2022 at 3:32 PM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Cleaned off about 7 layers of dust. :oops:
