  1. Jun 29, 2022 at 2:05 PM
    ChilliTaco
    ChilliTaco Well-Known Member
    Richard
    Alberta, Canada
    2017 AC TRD OR AT MGM
    It’s only 3” or so. I’m not doing any serious crawling, just spend a lot of time on heavy mud/clay that tends to tear up the rocker, so this is hopefully a budget solution.
  2. Jun 29, 2022 at 2:41 PM
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    How did you wire them then? Thank you!
  3. Jun 29, 2022 at 2:57 PM
    DuffyBank
    DuffyBank Well-Known Member
    I used the diode dynamics harness but cut the lead for turning the lights on independently and instead used an add a fuse on the power outlet #2 fuse to power that side of the switch and the switch illumination.
    WhiteTaco20[QUOTED] likes this.
  4. Jun 29, 2022 at 3:42 PM
    WhiteTaco20
    Perkasie, PA
    I want to do the same also but I've never wired a switch before so I'm kind of confused. lol
  5. Jun 29, 2022 at 3:54 PM
    Late Camaro
    Late Camaro Well-Known Member
    Central Ohio
    22 TRD Sport Barcelona Red Access Cab MT
    Brought it home 3-16-22
    Those appear to be the same ones I have on mine. I replaced the hardware with stainless, hoping it holds up better against Ohio salt/brine. They make washing the roof easy, and should help avoid door dings…..
    ChilliTaco[QUOTED] likes this.
  6. Jun 29, 2022 at 3:55 PM
    E.T.
    E.T. Well-Known Member
    Los Angeles
    2016 MGM OR TRD AC Field Truck
    They also send pigs through pipelines. Pigs are packages with various purposes such as cleaning the line, checking wall thickness, etc. Early pigs were made from straw, barbed wire, and leather and squealed when traveling through the pipes, hence the pig name. They are now called Pipeline Inspection Gauges or Pipeline Intervention Gauges to justify calling them PIGs. Where you inject the pig into a pipeline is called a pig launcher.
    The more you know....
  7. Jun 29, 2022 at 4:01 PM
    ChilliTaco
    Richard
    Alberta, Canada
    Also called sender, and receiver at the destination. Launcher (in Canada) is mostly the mechanical unit that automates or assists with sending.
    gen2eng and E.T.[QUOTED] like this.
  8. Jun 29, 2022 at 4:29 PM
    AwesomeLaw68
    AwesomeLaw68 Well-Known Member
    Lawson
    2022 Tacoma Off-road edition
    Brand new.
    i can deal with that. And have it painted
  9. Jun 29, 2022 at 4:29 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Got the Rigid 360 SAE Fog Kit in yellow! They sure do look awesome, exactly what I expected of Rigid. Hit up @sidetracked for excellent deals! Literally would not have bought these for a while longer if it weren’t for his price. Legit kit at a much better price :cool:
  10. Jun 29, 2022 at 5:00 PM
    Cappy
    Cappy Well-Known Member
    Georgia
    Yes. I received a recall notice from Toyota in the mail. Didn't need to show it to the dealer. They looked up my VIN and said my truck qualified. I wouldn't think it would matter where it was made but I'm not 100% sure. I'd check with the dealer if I were you just to be sure.
    DustyMcTaco and oostroma[QUOTED] like this.
  11. Jun 29, 2022 at 6:02 PM
    Cappy
    Georgia
    White letters out :bananadance::dancingbacon::broccoli::jellydance::kona::locked::taco:
  12. Jun 29, 2022 at 6:05 PM
    Bob1971
    Bob1971 Well-Known Member
    Tim
    KY
    White 2020 Trd OR
    Bed cover, step bars, SCS SR8 wheels
    I have to add a smart pig that can be tracked in the pipeline. The naming always cracks me up smart pig and dumb pig.
  13. Jun 29, 2022 at 7:16 PM
    jcayce
    jcayce Well-Known Member
    Texas
    17 DCSBTRDOR4X4
    We traded ours in right before "dieselgate." I kick myslef every once in ahwile about that. (Although I was already a little paranoid about the HPFP grenading and sending shrapnel through the system. I filled up at the same high-traffic diesel pump for every fill, kept all fuel receipts, etc. and was looking into adding the pre-pump filter modification before my wife could not stand it anymore. I guess I bought some piece of mind instead of paying for a Tacoma...for a couple of years at least, then our 4Runner showed up on the fuel pump recall...)
  14. Jun 29, 2022 at 7:21 PM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    Powerbrake install done!
  15. Jun 29, 2022 at 8:04 PM
    DustyMcTaco
    DustyMcTaco Well-Known Member
    2018 Tacoma TRD Sport
    Meso Taillights and other Meso stuff
    yup we used to catch pigs every month at the Kinder Morgan terminal worked at years ago. The smart pigs were around 7 feet long and looked like a robots dick. Little wheels on suspension all around them that would record when they dipped outward, pinpointing an anomoly. The carhodic protection crew would then inspect the anomaly and determine if the pipe had been damaged or if there was excessice wear/thinning of the walls. Pretty sketchy opening those pig traps to pull them out of the line knowing only one hydraulic MOV was standing between you and a line running at 4,000 barrels/hr. A little flag would swing up when the pig hit the trap. To alert the operators catching the pig, the station that launched it would typically pack the line upstream with a 500-1000 barrel slug of water. That would be a sure sign to get ready for it.
  16. Jun 29, 2022 at 8:05 PM
    DustyMcTaco
    How was the install? Easy breezy or difficult?
  17. Jun 29, 2022 at 8:11 PM
    aturk
    Tony
    Charlotte, NC
    You have to cut the dust cover, grind the knuckles, replace brake lines, bleed both inner and outer parts of the new caliper, besides that it’s just a normal brake swap.
    It’s easy but also time consuming. Took me about 3 hours.
  18. Jun 29, 2022 at 8:18 PM
    Jbrentb
    Jbrentb Well-Known Member
    Jake
    Wilmington NC
    Black 2016 Trd OR Dcsb
    17x9 mayhem prodigy’s with -6 offset duratrac 265/65-17, fox2.5 coil overs, fox 2.0 rear shocks, OME uca, custom vf tune, Urd spec-u exhaust, high flow catted dump tubes, mbrp muffler, S&B cai, Green lane off road skid and stump bumper, ss3 fogs, pro grill and tail lights, tint, led interior reverse and plate lights, bhlm retrofit HID headlights, Meso turn signals, gashole, and coin holder. hardtop on bed and mat. Blacked out meso everything!!!
  19. Jun 29, 2022 at 9:38 PM
    Bkicks333
    Bkicks333 Well-Known Member
    James
    Trd offroad 4x4
  20. Jun 29, 2022 at 9:47 PM
    TacoSRSX
    TacoSRSX Well-Known Member
    Martin
    Ventura County / San Fernando Valley - CA
    2021 MGM SR 2.7 2WD SX
    Ionic Pro 4" tube steps Desert Does-it Seat Jackers ECT PWR always on Kicker Tweeters replacement Tyger roll-up vinyl cover Bed mat
    Let's see,
    I finally added a gas tank lid holder, went with the one that just pops in, easy peasy.
    Also did truck things, this is my final load after moving apartments.
