  1. Jul 11, 2022 at 8:15 PM
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    I too would like to know the answer to this
    TexasWhiteIce[QUOTED] likes this.
  2. Jul 11, 2022 at 8:21 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    Yep. Looks like they put them on the wrong side
  3. Jul 11, 2022 at 8:30 PM
    JLD124
    JLD124 Some Guy
    Josh
    Out West
    22 OR 6MT
    Plates came in and I finally got around to reorganizing the MOLLE racks to fit a smaller shovel and fire extinguisher.
  4. Jul 11, 2022 at 8:51 PM
    CmdrTrekk
    CmdrTrekk Dante & Me
    Reno, NV
    2018 Inferno TRD OR
    Got a really good trash can for the back seat that I'm kind of excited about. ;) Tinted the front windows and windshield strip Glovebox and Console dividers MESO Hi/Lo LED Dome and Sylvania map lights Upgraded Sylvania down road halogen headlights Toyota Bed lights Tailgate Power Lock Anytime Backup Camera on front with switch MESO Customs Puddle Lights w/ switch OEM Roof Rack TRD Air Filter K&N Cabin Air filter MESO Customs Gasshole MESO Customs pocket switch plate ARB Awning w/ sides and back Taco Vinyl radio knob Mountain Hatch Tailgate Panel Midland MXT275 with clean set up and Ghost Antenna on roof Tonneau Cover - full fold up Cali-raised Lower bumper light bar Baja Designs ditch lights Icon Add a leaf 2” rear lift Bilstein 5100 OME 2” medium weight coil spring (settled at 1.5” lift all around) Rear diff breather relocation TacoMods ECT gear shift button KTJO4x4 A-Pillar Handle KTJO4x4 B-pillar handles RAV4 spot mirror Exhaust Re-route The last Mobtown Hidden Hitch Rear Bumper Greenlane Off road Aluminum low profile front bumper RCI Full skid plates + Cat guards Fuel Tank Skid plate Heated seats Battery Upgrade to larger AGM Soundskins sound dampening kit Randy Ellis Rock Sliders Remote Start and GPS Goodyear Wrangler UltraTerrain AT 31" tires Fumoto Valve oil pan upgrade TRD Radiator Cap Rough Country Speedometer Calibrator Oversized Cupholders Total lift: 1.5” body lift .5” ground lift On the list: Re-Gear? Speaker upgrade? Greenlane Bumper Wings?
    After making a big boo boo crash crash scrape scrape on the rocker panels and door in March, I got them repaired and finally installed the Randy Ellis rock sliders today. For anyone not familiar with (or familiar) Randy Ellis, this is a pinch-weld design mostly used on RAM and JEEP trucks. I know, it's sacrilege but it works. The design creates a box off of the pinch weld of the body and then rivets into the door sill. It's nuts how hard it was to drill these holes, we killed two Dewalt batteries and rendered all our bits useless. That alone made me believe in the strength of the pinch weld. My friend tested these out first (older design). They are sturdy AF. You can stand on them, you can jack the truck up off of them and everything. I know that you all love the frame-mount ones, so please don't @Me because I also think those are great but I wanted a different design and function.
    The new design does leave a little to be desired in terms of flush fitment though. Might not be a bad thing but the old design wrapped around the rocker panels very tightly (which apparently made install a pain compared to these). These have a lot of uneven gaps due to the definitely not straight or flat truck body. The gaps would make it a lot easier to clean though when there's dirt and rocks inside and it does leave them floating away from the body which might be better for actual impacts. You also can only see the gaps up close or with the door open and every other rock slider is full of gaps.
    Use wise, they stick out further than I personally wanted, but will also make a great step for getting access to the roof (I used to stand on the door sill and slide all over the place). I kinda wish I had ordered them without the tube but then they'd no longer be a step. And most other rockers stick out like that too, so it'll take me some getting used to. Get a nice calf massage on the way out of the truck though! Will have to figure out where to put my grip tape to avoid ripping pants and leg hairs.
    In all, 10 bolts and 16 rivets per side. The rivets could probably be hammered and painted to blend in better.
    Side note: Does anyone else hate the poorly written instructions that come with stuff like this?
    EDC6EC1B-4B06-4537-A34A-E103679055A2.jpg 382C524A-49B2-4E4D-B7C9-1BF284237AE7.jpg 5902B188-1533-4943-9B07-CB0A3C3C868D.jpg F739D2D6-8A06-408C-AED4-29AEC6CC8961.jpg IMG_0338.jpg IMG_0336.jpg
  5. Jul 11, 2022 at 8:58 PM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Thanks, I ordered my SOS bumper at the beginning of November. That was the part that took the longest.
  6. Jul 11, 2022 at 9:12 PM
    CmdrTrekk
    Reno, NV
    2018 Inferno TRD OR
    Thanks! they will never be this clean and shiny again
  7. Jul 11, 2022 at 10:34 PM
    Dirtyleg
    Dirtyleg "Don't wanna Taco bout it!"
    Aaron
    Chesapeake, VA
    2018 SR5 4x4; CAB-4 Full Doors, BED-Standard 6' 3.5"
    El Taco Blanco
    Swapped out my OME nitros for Bilstein 5160’s, new OEM shackles with polyurethane bushings, removed the 2nd overload and medium leaf from my Dakar’s as well as cleaned and greased everything up. Not bad for a Monday!
    :cheers:
    4E3E4B67-61D3-4E7C-BA98-5DF35950A33B.jpg A40A0714-0E52-45C6-B655-B108F9A4FA02.jpg DDA6891F-EBDA-4137-BAE7-61604C65D645.jpg E80CA36B-F144-4943-A9ED-0B2421722C86.jpg 0F2575CC-3B2F-4B9E-95FF-4F15F693ED70.jpg C5F3AD3F-232B-482F-8503-9FC0677C718E.jpg 77A3739B-09EB-48AC-AE81-987364663961.jpg 31C53E6F-64F3-4081-AEB3-CD1A9925C4C3.jpg
  8. Jul 12, 2022 at 1:59 AM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    The tire carrier is coming along nicely. The hand made drop down table and propane mount needs painting is all.
  9. Jul 12, 2022 at 3:49 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    They are nice, I'd be interested to see how they hold up being tied into the body. As for the Jeeps, I believe you are referring to what is known as boat sides which are at a much steeper angle deflecting the rocks/hits outward away from the frame/body. Also with jeeps the body mount sliders usually have a skin or top mounting material that gets riveted to the panels up the side of the doors for added strength. It looks like these are riveted to the step in. Some real world testing would be cool.
    drizzoh and CmdrTrekk[QUOTED] like this.
  10. Jul 12, 2022 at 7:40 AM
    mic_sierra
    mic_sierra Toshiba HDDVD is the future
    Elsewhere
    '21 DCSB TRD Sport 4x4 Auto
    x2 They're tied into the pinch weld which concerns me for anything other than aesthetics. I would think those would move if someone over 200 lbs. used it as a step getting in and out.
  11. Jul 12, 2022 at 7:48 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    I hope you trimmed those u-bolts before dropping the truck back on the ground..
  12. Jul 12, 2022 at 8:04 AM
    BHC
    BHC Well-Known Member
    Pro Grill was due today, but it's delayed per UPS
    Diamondback cover in about 2 weeks
  13. Jul 12, 2022 at 9:03 AM
    digitalzombie
    digitalzombie Well-Known Member
  14. Jul 12, 2022 at 9:24 AM
    CmdrTrekk
    Reno, NV
    2018 Inferno TRD OR
    Great info! I wasn't super familiar with how the Jeeps are built in/designed just that they exist. Will def. have to see how they work. They definitely would've deflected the rock that creamed the rocker panel originally though or at least scratched them up, lol.
    ClassyTacos[QUOTED] likes this.
  15. Jul 12, 2022 at 9:26 AM
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Why??
    Tacospike likes this.
  16. Jul 12, 2022 at 9:36 AM
    Tacospike
    Two Trucks
    What did you get? I've been looking for a while but seeing mixed reviews all over the place
  17. Jul 12, 2022 at 9:37 AM
    Tacospike
    Two Trucks
    MiTacoTRD likes this.
  18. Jul 12, 2022 at 9:44 AM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    They'll definitely deflect objects and act as a step but I don't think they'll be a true slider that can support the truck's entire weight. If that's what you're after. If this is strictly for the city, they'll be fine. And they're still higher than the frame rails so they won't protect that either
    drizzoh likes this.
  19. Jul 12, 2022 at 10:28 AM
    CmdrTrekk
    Reno, NV
    2018 Inferno TRD OR
    You might be right about the sliding part, but that's not my goal, true and I likely would not test that theory just out of my own general fear of rock sliding, lol. But they should be able to take it. You might try reading about them first before just making a blanket comment (https://www.randyellisdesign.com/store/p33/Toyota_Tacoma_Rock_Sliders_Body_Armor_Gen_2_&_Gen_3_#ROCK5205.html). But deflecting side impacts and being used as a jack point (if I ever need it/get one) is all within its ability that I intend to use, as seen here https://www.instagram.com/p/Ccl1p3av5ls/.
    Not sure how you got "Strictly for the city" out of deflecting though. I don't encounter a lot of things to deflect in the city other than J-walkers.
    In general, I dunno why people need to be like "I see that you did a bunch of research and spent money on this thing but let me just tell you that you made a bad choice/that thing won't do what it says it will" like stfu if you don't know.
    CenCal805 likes this.
  20. Jul 12, 2022 at 10:55 AM
    4x4Gaspar
    4x4Gaspar Active Member
    Brendan
    2018 white Tacoma trd sport
    How did you get 3” with 6112? You add a spacer or stronger springs? They rated for 2” max
