  1. Jul 15, 2022 at 3:38 PM
    d0ugh0ck
    d0ugh0ck Well-Known Member
    NJ
    I did the ac drain line extension. Is it a problem if the hose touches the heat shield of the exhaust? I have some tape.
  2. Jul 15, 2022 at 3:40 PM
    BHC
    BHC Well-Known Member
    did the same a few other things
    summerdaze[QUOTED] likes this.
  3. Jul 15, 2022 at 4:48 PM
    tacoshell88
    tacoshell88 Not that well known member
    Michelle
    Somewhere along the Mexican border
    2021 DC Cement TRDOF
    Happy Friday! So, no issues with fitment. Only issues I had was not having the T55 star bit but I bought a inexpensive set at harbor freight.
    Also, I had put together the side pieces backwards bc I’m a dufus before actually installing the panel on the truck so it was a quick fix. Definitely make sure the double holes are on the bottom. Don’t make the same mistake I did lol.
    Here’s a finished pic. Just finished it up today.
  4. Jul 15, 2022 at 6:24 PM
    Jerry311SD
    Jerry311SD Well-Known Member
    Jerry
    Ramona Ca SAN DIEGO
    2019 tacoma TRD Quicksand
    KDMaxx tune K&N drop in AFE catback Oil catch can Bill's 6112/5160 Dynomat whole inside of cab TRD skid plate
    New center caps today.
    AMMO461, japjoe7, markram and 20 others like this.
  5. Jul 15, 2022 at 6:29 PM
    Bkicks333
    Bkicks333 Well-Known Member
    James
    Trd offroad 4x4
    One of the guys that was underwhelmed with the not sporty engine :rofl: I'm glad he got what he really wanted instead
  6. Jul 15, 2022 at 7:17 PM
    LRockTRD22
    LRockTRD22 Well-Known Member
    Mark
    2022 TRD Off Road
    you mean you didn't buy your Tacoma to go racing? I thought that's what they're known for. People...:crazy::notsure:
  7. Jul 15, 2022 at 7:22 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    right, the trd sport bed decal means its a race car. I will not elaborate
    LRockTRD22[QUOTED] likes this.
  8. Jul 15, 2022 at 7:27 PM
    A-ron
    A-ron YotaWerx Authorized Pro Tuner - Colorado
    Aron
    Colorado
    21 TRD Sport - Cement
    YotaWerx Blackhawk 2.1 Tune, TRD Lift, DV8 front bumper, DD SS3 Pro Fog Lights, DD Stealth Light Bar, 4Runner Wheels, Leather Seat Covers, Morimoto Tails, Meso sequential mirror lights, Ect button relocated to shifter,
    Many things over the last few weeks.
    -Talons Garage Cat Protection Plate
    -Meso Puddle Pods
    -Meso V5 Switchbacks wired to DRL
    -Re-wired grill lights to turn on with DRL
    -AVS in channel vent visors
    -Vinyl Hood Wrap
    -Red delete-new black bed decals and covered the TRD on the 4 runner wheels center caps with matte black vinyl.
    -Course Motorsports no drill phone mount with behind dash fuse tapped charger.
    The never ending journey continues with this modification money pit. Good times!
  9. Jul 15, 2022 at 7:34 PM
    LRockTRD22
    Mark
    2022 TRD Off Road
    Would love to have those puddle pods, but, wow! The install requires WAY too much for me! Half the truck has to come apart just to install two little lights. But, they are really nice.
  10. Jul 15, 2022 at 7:48 PM
    codyjphoto
    codyjphoto Well-Known Member
    Cody
    2015 gx460
    A bunch of junk
    Link to the panel? I want one for my canopy
  11. Jul 15, 2022 at 8:03 PM
    A-ron
    Aron
    Colorado
    It’s really not that bad. I would say reading all of the posts about the install and door boots makes it out it be much worse than it is. Once I fished the boots once for the puddle pods, the second time around for the switchbacks wired to the DRL’s took about 20 minutes per door. And that’s removing all panels, mirrors, switches to run wires and pit everything back together. Just make sure you test all lights before re-assembly. Definitely worth the time
  12. Jul 15, 2022 at 8:13 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    My quest for switches continues…
    Next will be cutting out the 3 stock ones and installing the @MESO 6 switch panel. Then comes the part where I actually make them do something…..
  13. Jul 15, 2022 at 8:18 PM
    _FREEDOMTACO
    _FREEDOMTACO Brewmaster
    Greg
    2017 TRDOR DCSB 4x4 M/T
    Yeah I’m pretty salty about it, I am seriously considering charging back the amount I was charged due to the damage. He also put the top hats on backwards.. I usually do everything myself but I did not have access to a sprint compressor…
  14. Jul 15, 2022 at 8:20 PM
    _FREEDOMTACO
    Greg
    Thanks for the feedback, he also put the top hats on backwards that I had to correct during install… I have the guys number and can contact him through text, what should I say? Deeply saddens me that it is a veteran owned business..
    & yes it’s the same on both sides
  15. Jul 15, 2022 at 9:28 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Finally got around to drilling and bolting my fishing rod racks on securely. They were mounted using the mounts they came with, but it was horribly unsecure. Sure the racks locked, but you could just loosen the finger bolts and remove the racks with my expensive rods still in it. Now the racks are bolted through my bed rack (carriage bolts) and when closed and locked the wing nuts are inside the rack and cant be touched.
    markram, 20tacoma17 and blu92in99 like this.
  16. Jul 15, 2022 at 10:02 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    What did you need a compressor for with preassembled coilovers? Unless you swapped out the springs you should be able to adjust ride height while they're still installed on the truck.
    _FREEDOMTACO[QUOTED] likes this.
  17. Jul 15, 2022 at 10:03 PM
    _FREEDOMTACO
    Greg
    Swapped out the original springs for 700lb springs
  18. Jul 15, 2022 at 10:05 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    Ahh. Still though, a shop should use a wall-mounted unit for springs this beefy, which will leave the adjustment collars easy to adjust. Really not cool. I would never let a vehicle I've worked on leave like that. :/
    DustyMcTaco likes this.
  19. Jul 15, 2022 at 10:19 PM
    Kolohe07
    Kolohe07 Well-Known Member
    David
    Haiku , Maui, Hi
    2022 Access cab Sport 4x4 Celestial Silver
    I striped the decals and badges off my 2022 Sport, the third day I had it.
    It looks soooo much better without the BS
  20. Jul 15, 2022 at 10:33 PM
    MGMDesertTaco
    Anyone else install one of these dash panels from Fitztaprint via Etsy or another brand (meso, guild outfitters, ect)? Appears I need to pick up a dremel tomorrow to notch the dash support itself and the rear power window switch mounting hole as the mounting bar tabs are different on each side of the switch. Wondering if the other brands require as much cutting? :annoyed::sawzall:
