  1. Jul 23, 2022 at 10:20 AM
    TacoTomek
    TacoTomek Well-Known Member
    2021 TRD OR
    I have the same Billsteins. Thoroughly impressed with the bump handling at speed.
    Mlofthou[QUOTED] and BattleKat like this.
  2. Jul 23, 2022 at 11:02 AM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    DDI seat hackers paired with quikfix in the back. Sits so much nicer now. 20220722_164422.jpg
    Monster0Frankenstein and ebsoria like this.
  3. Jul 23, 2022 at 11:03 AM
    LRockTRD22
    LRockTRD22 Well-Known Member
    Mark
    2022 TRD Off Road
    Any leaks that you know of? I’ve read some reviews where people say it leaks pretty bad. But, I often wonder if it is more of an install problem than an actual problem with the product. Some people just don’t do it right.
  4. Jul 23, 2022 at 11:11 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    Fox 2.0 resi to replace the Bilsteins 5100
  5. Jul 23, 2022 at 11:19 AM
    DustyMcTaco
    DustyMcTaco Well-Known Member
    2018 Tacoma TRD Sport
    Meso Taillights and other Meso stuff
    Took her out for a surf
  6. Jul 23, 2022 at 11:42 AM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Just added her A arms plates. Free custom cut by the guys at RCI to fit my TRD PRO skid plate.
  7. Jul 23, 2022 at 11:52 AM
    TacoTomek
    2021 TRD OR
    I’m not sure, only just got it and haven’t seen any rain. The seals all sit nice and tight. The weak spots are the two front corners to either side of the bulk head, and the tail gate. You could probably take some time with a little strategic extra weather stripping, and get it reasonably water resistant. As it sits, I fully expect water getting in at the bulkhead and tail gate, but it should drip down under the bed mat and out the back.
    This guy took it through a car wash. That’s about what I would expect. See 19:30 https://youtu.be/Uat7CIFzye8
    MGMDesertTaco and tacoshell88 like this.
  8. Jul 23, 2022 at 12:15 PM
    ppat4
    ppat4 Well-Known Member
    Paul
    Kelowna, BC
    2016 Tacoma TRD Off-Road Access Cab
    Just added toolbox and roof-rack to haul my fishing boat 100's of miles into the backwoods every week. Goodrich K02s, Bilstein 5100 front and back, no lift.
    Biggest OEM issue I have experienced, is the engine air filter. Tried a FRAM, and a few other brands, and all of them choked the engine. Only because the dealer here did not have an OEM filter in stock at the time.
    Brutal loss of power. I have never experienced that before in 35 years with 4 different 4x4's. It was just sucking on high elevation climbs. So badly that I was putting my dirty OEM filter back in mid-trip and it performed better than a clean after market filter.
    So I was finally able to get a new OEM engine air filter, and bingo the problem was solved. Back to normal performance. The other filters I assume are just too dense and restrict the air flow. Same as your home A/C and furnace system. You put in too dense of a furnace filter, and it restricts air flow and eventually wears on the furnace motor.
    davidstacoma likes this.
  9. Jul 23, 2022 at 12:34 PM
    LRockTRD22
    Mark
    2022 TRD Off Road
    Looks pretty nice to me. I really like how low profile it is and the way it rolls up without blocking the entire back window. I imagine it can’t be used with a bed extender though. Not a big deal.
  10. Jul 23, 2022 at 12:36 PM
    LRockTRD22
    Mark
    2022 TRD Off Road
    I have a K&N filter in mine. Seems fine, but I haven’t taken it up to any significant altitude to check the performance there. Hopefully it won’t be a problem. I guess I can take along the stock OEM one just in case.
    MGMDesertTaco and Jerry311SD like this.
  11. Jul 23, 2022 at 12:50 PM
    ppat4
    Paul
    Kelowna, BC
    I would bring the old one just in case. I have a 4,000 ft elevation climb I do twice per week to get to my fishing spots. So a 4,000 ft climb in about a 15 mile stretch. Speed limit is 70mph.
    Tried 3 different brands of after market filters and all were just brutal. Every day here in summer, some 18 wheeler or RV or some overloaded truck will overheat and set on fire going up that stretch.
    A lot of vehicle burn spots up that hill. When I come home from a trip and I am heading downhill, I usually pass 3 - 5 broken down vehicles that are heading up the hill.
    ClassyTacos and Jerry311SD like this.
  12. Jul 23, 2022 at 1:01 PM
    Egbeem
    Egbeem Well-Known Member
    Iowa
    2022 Lunar Rock TRD Sport
    Got some new decals from Etsy. Flat black and metallic gold.
    Installed with soapy water went good, the 4x4 portion is a black decal over the gold 4x4 and so was difficult to get all the bubbles out as the black decal acts as a sort of seal. I’m debating on ordering some that have the gold just die cut instead of with the black outline overlaid on them. Turned out great for now though.
    rgljr831, kas2828, jeejay and 17 others like this.
  13. Jul 23, 2022 at 1:06 PM
    NACAircrew
    NACAircrew Well-Known Member
    My pronoun is Chaz
    TRD OR/4R Trail
    Raptor lights/Meso everything/Predator steps
    looks awesome! I removed all my badges and decals, Toyota overdid it on the branding IMO.
    Jerry311SD and scouterjan like this.
  14. Jul 23, 2022 at 1:16 PM
    LRockTRD22
    Mark
    2022 TRD Off Road
    I don't think I will ever understand the whole debadging thing. I guess it's just personal preference. It was the same thing with my Camaro. The first thing a lot people did was remove all the badges. I don't get it. But, each to their own.
  15. Jul 23, 2022 at 1:16 PM
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    I had this 1 on my prev truck and loved it. The only drawback I found was you can't have it partially open in other positions 1/4, 1/2, 3/4 but that is the same with any rollup.
  16. Jul 23, 2022 at 1:27 PM
    bimmerlev
    bimmerlev Well-Known Member
    Lev
    Los Angeles, CA
    25' Tundra
    Just slapped on the WaterPORT Weekender. It has a great amount of pressure, this will come handy quite a bit. =)
  17. Jul 23, 2022 at 1:44 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    Installed my Millercat today, time to update the front skid
  18. Jul 23, 2022 at 1:49 PM
    TacoCrush22
    TacoCrush22 Well-Known Member
    Knoxville
    2022 Blue Crush TRD Sport DCSB
    Coming soon
    Finally got music transferred to USB and voice controller works for everything except playlists. Don't know why. They are in folders like everything else. Good enough for now though. Not as exciting as new wheels or anything but now I got 5000 songs on this little thing!
  19. Jul 23, 2022 at 1:53 PM
    scouterjan
    Jan
    I put black overlays on my badges and ordered all black box decals but once 1 removed the bed decals I said screw it, I like it without them
    Jerry311SD likes this.
  20. Jul 23, 2022 at 2:00 PM
    ET_Quila
    ET_Quila Well-Known Member
    ET
    Ohio
    2033 4Runner Trd Off Road
    Finally got a few more things completed. Bed rack and soft topper combo, warn 10k winch, and Relentless HC tire carrier. I do need to take the bumper off again and cut the besides about 3/4" higher so I can raise it up a bit.
    A4E623CD-4135-4639-B37F-B0D0F096B948.jpg B2D1A970-D320-4CAD-8381-15608862679B.jpgAFDF1ADE-047F-4930-B1DE-E1114052E44F.jpg
