  1. Aug 15, 2022 at 6:44 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
  2. Aug 15, 2022 at 7:12 AM
    JDAISE
    JDAISE Well-Known Member
    Jeremy
    Lancaster, Pa
    17' SR5
    DOBINSONS 3" DIRT KING UCA True North Fab Front bumper DIY rear bumper 285/75/16 FALKEN WILDPEAK ATW3 METHOD 701 Diode Dynamics Fogs
    My DIY bumper was finally finished and I can add to later if I needed.
    RyanDCLB, kas2828, CorsoTaco and 46 others like this.
  3. Aug 15, 2022 at 7:52 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Gotchu
  4. Aug 15, 2022 at 7:59 AM
    T.Barn
    T.Barn Well-Known Member
    Todd
    Hampton Roads, Virginia
    2010 AC 4x4 6MT
    Love it. Set up perfectly, well done.
  5. Aug 15, 2022 at 8:07 AM
    big110
    big110 Well-Known Member
    support the delete looks great!
    stftaco likes this.
  6. Aug 15, 2022 at 8:59 AM
    WaitingOnMyR1T
    WaitingOnMyR1T No longer waiting…
    Josh
    Portland, Oregon
    2020 White TRD Pro - Magnuson S/C & Rivian R1S
    Are you planning on mounting your license plate on the spare?
  7. Aug 15, 2022 at 9:27 AM
    JDAISE
    Jeremy
    Lancaster, Pa
    17' SR5
    I actually have it mounted underneath the tire on the bumper with zip-ties till I have time to get little tabs fabricated for the plate.
  8. Aug 15, 2022 at 9:35 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
  9. Aug 15, 2022 at 9:55 AM
    Pilvr83
    Pilvr83 Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    I noticed a lot of people are de-chroming. I am cheap; I used Toyota touch up paint to simulate chrome removal around the ignition switch.
  10. Aug 15, 2022 at 12:14 PM
    thomasburk
    thomasburk Keep on Truckin'
    Tom
    Tampa, FL
    2020 OR DCLB AT
    Great idea, only problem for me is that is exactly where my knee goes. That tray looks to have a sharp edge.
    TartanEagle likes this.
  11. Aug 15, 2022 at 1:35 PM
    shiftd
    shiftd Well-Known Member
    Pennsylvania, USA
    2020 Tacoma TRD Pro
    Crossed over 10k miles on Sunday
  12. Aug 15, 2022 at 3:17 PM
    themcnertney
    themcnertney Well-Known Member
    Dan
    Akron, OH
    2016 Toyota Tacoma, Off Road, 6 speed manual
    Putting up the rest of my patches finally after getting my truck back. Here’s a few.
    NateJ, Vinny C, BJK1280 and 8 others like this.
  13. Aug 15, 2022 at 3:38 PM
    trdo-r
    trdo-r Well-Known Member
    17 TRD Off-Road
    Noo bewts! General Grabber ATX in 245/75R16 on stock suspension and stock wheels.
  14. Aug 15, 2022 at 3:45 PM
    My1Yoda
    My1Yoda Well-Known Member
    Alex
    2022 Lunar Rock Tacoma TRD OR
    Loving the patches!
  15. Aug 15, 2022 at 3:47 PM
    CMENTTACOKID
    CMENTTACOKID Member
    18 Tacoma DCSB Off Road Cement Gray
    I dig this. Most satisfying feeling ever
  16. Aug 15, 2022 at 3:49 PM
    themcnertney
    Dan
    Akron, OH
    Kids really enjoy them.
    Yota_MGM, Vinny C, BJK1280 and 5 others like this.
  17. Aug 15, 2022 at 3:49 PM
    CMENTTACOKID
    CMENTTACOKID Member
    Came out really nice! Does the weight of the wheel make it sag a little? I know that’s a common problem on Jeeps
    rgljr831 likes this.
  18. Aug 15, 2022 at 3:53 PM
    My1Yoda
    Alex
    Nice!!!!!
  19. Aug 15, 2022 at 4:13 PM
    Late Camaro
    Late Camaro Well-Known Member
    Central Ohio
    22 TRD Sport Barcelona Red Access Cab MT
    Brought it home 3-16-22
    I added a 3” strip of window tint to the bottom of my 22 windshield, it blocks hood glare, and changed the amount of ambient light that turns on the “auto” headlights. I like the strip of tint, so the first alternative was to alter the point the sensor turns the headlights on. I changed the setting to the least sensitive setting (-2). This setting still had the lights coming on too early, so the next option was to alter the sensor. Part searches had the Tacoma sensor at $90+, while other, newer Toyota models where less than $14, so I took a chance, and purchased one of the cheaper parts. I removed the Tacoma sensor, and compared it to the Camry part. The two parts had a different number of pins, but the tinted dome, the part above the dash, looked to be the same size, and assembly style. I removed the cheap part first, a little prying with a small blade screwdriver, and it popped off, the same for the stock Tacoma part. The cheap dome fit the stock sensor just like the original part did, and it already had less tint than the stock dome. I installed the new hybrid assembly and tried it, improvement, but the lights were still coming on too early. The second idea was to remove some of the tinted dome material. I used a file to make the outside of the dome thinner, then sanded it with fine grit crocus cloth, then buffed it with rubbing compound - this result is seen on the Right of the first photo (stock and cheaper part numbers are also shown). After measuring the modified dome thickness, I realized I could remove material from around the center concave shape. A couple of drill bits, turned by hand, made it easy to remove material in a controlled manner, stopping as soon as the bit touched the center of the dome, then on to a larger bit, and repeat. The second photo shows the concave side of the finished part. This result is working great, I may change the sensor sensitivity, as the lights are coming on after roughly 1/2 of traffic has their headlights on.9B11B580-7358-4515-A67B-8C3E55634A27.jpg937AE4BA-E2B1-4AB8-A985-58B2AD0B61F4.jpg
  20. Aug 15, 2022 at 4:17 PM
    ljh824
    ljh824 Regular Guy
    Lou
    Kabul, Afghanistan / Oviedo, Florida
    -21 AG Sport 4x4 DC
    Gonna install my Garmin dash cam this weekend. Got a polarized lens cap and the dongle to link to the mirror. Any tips on the install from the knowledgeable?
